Question about X2Gen MG19MY 19" LCD Monitor
BROKEN MONITOR BASE
The arm piece that is attached to the monitor that goes into the base is broken. there is 4 little holes in the back is that for a wall bracket.
  • 165 Answers
The 4 holes on the back are standard and you may find on the web, a monitor mount. You could also search ebay for the exact same monitor with a broken screen and get it very cheap and use the base off it.
Posted on Nov 01, 2008
The stand of my E173FPs monitor is broken. What can I do?
Sorry to hear that the stand had broken on your monitor.
many times there is a mounting in the center of the monitor back that accepts a standard 4 screw mounting, which almost any brand monitor will fit on, many of these type stands will adjust in height and also sometimes rotate to a portrait if you should like to read documents with the narrow side to the top.rotated 90 deg. some monitors do not have this option the mount is called (VESA mounting holes, 100mm (Behind attached base plate) but eBay is a great course for this type of part. I should have one of the Dell original mounts in my older parts area. but i see (Problem with Dell E197FP LCD Monitor) and (E173FPs) both in this unsolved problems, and knot knowing exactly the broken area, not sure of all you need to repair the broken area in question. Sprint6@zoominternet.net for personal help with this unit.
Dec 03, 2013 | Dell E197FP LCD Monitor
I lost the instruction Manuel and I need to convert the crib into the toddler bed
First I unbolted the four arms that hold the metal bed support up and pushed it down as flat as I could. I had to do it a couple of times and go kind of slow, to get the loose arms tucked away as best I could. They still stick up a little above the rest of the frame.
After much wrestling with the wooden front panel (gate) of the crib (the one I need to remove), here is what I did:
1. Find the wooden piece that crosses the bed just behind the gate. This is an approximately 1.5-inch by 3/4-inch piece. On ours, it's just above and in front of the drawer under the crib.
2. Find the metal screw at one end of this cross piece. You will see that it is on the outside of the bed, on the short end of the bed, in line with the cross piece.
3. Unscrew it. Note that this screw actually threads into a threaded piece inserted into the cross piece in a little hole on the back side of the cross piece, about 3/4 inch from the end. If this little silver metal piece falls out, you will need to find it and put it back in the hole with the threads facing the screw hole. The piece is the size of a pea.
4. Anyway, use an allen wrench to remove the screw, without losing that little inserted thingy.
5. I'm not saying this is textbook, but I then forced the end of the crib away from the rest of the crib while moving the gate up and down and pulling gently toward me (to pull the gate from its track). You have to move the end of the crib to create about a 1/2-inch gap before the gate will pop free.
6. The gate has two pins on each side, so when you get it freed on the site that you removed the screw on, the other side will come off without removing the second screw on that side.
7. I then got the drawer back on its tracks properly (it jumped the tracks a bit in the process), pushed everything back together the way it was, and screwed the screw back in. (if the screw wont thread, either you lost the aforementioned little silver piece, or that little silver piece is turned in the hold the wrong way)
8. With the gate removed, the crib (now toddler bed I guess) has four little tabs where the gate was once attached. Two I had to unscrew, and the other two I grabbed with a pliers and pulled out.
It wasn't elegant, but I certainly have an intact toddler bed now.
Hope helps. Good luck.
Oct 04, 2010 | Toys
Having a problem getting charger to nstay lock in to razor
1. a Piece of tape to hold the locking arm down works
2. for a more long term fix, I drilled a very small hole thru the locking arm when it was held down with tape, I now put a small nail thru the hole and it holds down the arm.
This solution has been working for me for about 2 years, total cost 3 cents for the nail.
Feb 13, 2010 | Braun Syncro 7526 Electric Shaver
How do you take the base of a envision H170L
Can't find too much info on this monitor. Look for a crease/gap in the plastic around the neck of the stand. Most likely a plastic cover is covering the screws you need to unscrew. You'll probably just have to pop it off.
You may have to first remove the flat part of the base (if looks like it separates from the neck). Check the bottom of the base for tabs or plastic clips holding it to the neck. If the flat part of the base doesn't come off, just look for the plastic covers mentioned above to reveal the screws that are holding the base on.
Jan 12, 2010 | Envision H170L Monitor
Frigidaire dishwasher - upper spray arm trouble?
I do not have a problem w/the upper arm not spinning. Rather, the upper arm keeps falling off of my frigidair dishwasher. The owner's manual suggests the upper arm is a single unit. However, the upper arm component is comprised of 3 parts. The parts are an arm that distributes the water, the base that screws to the top of the dishwasher, and a small plastic type washer that rides in the base and literally holds the arm to the base. The plastic washer has two small clips that tend to wear or contrast with age; thus letting the arm fall off on a very frequent basis.
Potentially, the small plastic washer piece may have broken in the base assembly and is not allowing the arm to turn. As water flows into the arm from a hole in the base; suggesting the plastic washer may be jammed with a foreign item seems less likely. The base unit screws to the top of the dishwasher and can be removed by hand (the base is a little tight). There are no mechanical pieces to my third (upper) arm; movement of the arm is accomplished with water flow.
You may wish to remove the arm assembly and check for a broken washer or a foreign item in the assembly. As a side note, I found that I can unscrew the base and remove the assembly without removing the top dish tray. The fit is a little tight but the tedium of pulling and reinstalling the top tray can be eliminated by unscrewing the assembly w/the tray slid forward for assembly access.
Hope all you have is a foreign item that is locking the washer.
Nov 03, 2009 | Frigidaire Dishwashers
How do you remove the wiper arm on a 94 Dodge Ram 1500? The arm will not fully extend with the hood open or closed but maybe that doesn't matter. Can't get to the wiper motor without removing the arms to...
throw a grenade at it and hopefully the arms will fly off, whatever happened to a nut on a threaded flange to hold wipers on. No wonder imports own the market.
Aug 15, 2009 | Dodge Ram 1500 Cars & Trucks
Cannot attach base to samsung lcd monitor sw2233
Llay the monitor face down on the floor (I put it in the styrofoam from the package) and then put it up against a solid surface. Then push the part into the socket before attaching the round base.
I tried pushing down onto the monitor while holding it upright but that didn't work. When I called Samsung tech support the solution above is what they told me to try and it worked.
Mar 19, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Acer 1717 monitor- removal of base
At the base you want to remove - in order to pack the monitor - if you se at the rear left and right there are a tiny opening about 3 cm long,put inside a screw driver and it will open very easly the plastic cover.Then inside there are four screws,two on each side,remove them and the arm of the screen will be dis-attached.
Dec 21, 2008 | Acer Al2416WD LCD Monitor
How to remove the base from the monitor
For monitor or TV bases that have four clips, I found if two people each take two opposite clips, and use thumbs to push in the clips, we can pop the base off fairly easily. It is impossible with one person, since thumb and forefinger can't exert sufficient pressure on the clips.
Jul 18, 2007 | Acer AL1717 17" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
158 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
