Question about Gateway 450ROG Notebook
He power comes on, the status lites come on and then go off. The fan stays on but no display.
What should i do?
  • 685 Answers
Try taking the battery out and leaving it out for a little bit and then plugging it back in
Posted on Nov 19, 2008
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
Mitsubishi hc3000 wont start
this is a problem in your power board.
thi unit is getting OFF due to heating problem
Jun 29, 2008 | Mitsubishi Office Equipment & Supplies
Won't come on, if plugged in and battery light
the reason why the light stays on is because the battery is charging. you can go to control panel in the power options and see the status of your battery. you might have a battery issue.
Jan 23, 2010 | HP Pavilion dv9000z Notebook
Dell 8200 green power lite comes on green hard drive lite off
Check your fans o see if they are running and if the PC isn't getting too hot because that will cause it to stop and not boot up.
Dec 29, 2009 | Dell Dimension 8200 PC Desktop
Ruud IFC Furnace Blower comes on and stays running, never lites
Check on the circuit board for an automotive type fuse that is probably blown. These fuses blow because of a short in the control wiring. If the fuse is blown a lot of furnaces run the fan all the time as a diagnostic. You will have to find the short or it will just blow again.
Oct 04, 2009 | Heating & Cooling
Bradford White LP water Heater Power vent Will not stay lite. I took off the pipe to the power vent and it will stay lite for a little while. Then it turns off and turns back on. The pipe is not pluged....
does the fan come on, if not there is a problem with the circuit board, if it does then there is a problem with the gas valve or a wire from the gas valve to the fan , if the fan doesn't come on the gas valve is told not to open to light thru the circuit board,
May 03, 2009 | Water Heaters
Tv turns on and than red status light comes on and shuts down
it sounds like the 3300uf caps on the power supply have gone bad.look at them and see if they are pregnant. if so change them. while you have the shield off see if any other caps are pregnant, if so you might want to think about having the chassis repaired.
Dec 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Fans not come on, engine lite on, just bought
The fans come on about 220-230 degrees F,(hot) is the light the check eng light?
Oct 20, 2008 | 1996 Nissan Sentra
Gateway 450ROG laptop does not boot
I have a similar problem with my 450rog but I get 3 beeps on startup - everything runs: fan and drives but the screen is blank and the computer dead.
Gateways tech dept told me it was a faulty memory module but I bought a new one and it made absolutely no difference.
So must be something moreserious.
Good luck
PM
Jun 23, 2008 | Gateway 450ROG Notebook
Gateway 450ROG Notebook Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
