Question about Electrolux EW1000i Front Load Washer
How do i repalce bearings in my washing machine
How can i replace the bearings in my washing machine
I'm not the technician, but I ever "underestimated" the load after I opened the back-case. I figure it out, it's so easy, which was Not. I agreed it's not a novice work, you must be very careful for every details. This is not as simple as it seems.
This was according to my experience, because I had my experiences for two different Electroluc generations. Technically, they're similar.
TOOLS:
+/- screwdriver,
spanners of 7, 8, 10, 12 and 17 (mm),
a set of "L" spanner (hexagon-spanner),
a chisel (dull one) around 1/2 meter and 1cm thickness,
rope (make sure it's a strong and thick one) -or- chain-lifter is better,
duct tape for paper-usage (usually yellow one) + a marker,
hammer (medium to big size),
a sharp screwdriver (thickness=3-4 cm),
---rest tools are provided, in case if you need so.
How to start:
Step One - Preparation
Unplug the electricity-plug. Unplug the hose where water comes in. Unplug the water-dump hose. Unplug the ground cable. Move the machine to an adequate space.
Step Two - Opening Back Case
This is easier part, 2 bolts on right/left bottom were Electroluc specialties, usually covered by white caps. It's very easy to detect. Rest, unbolt all bolts at back-case.
Once they're all loosen, remove upper case by pushing to the front and lift it up.
Unscrew the bolt holding the back-case at the upper chassis-bone, there were 4 of them. Then open the case by using a gently force to loosen it from the chassis. You will notice the drum now.
Step Three - Removing dynamo
First, you have to open the bolt holding center of the drum.
Remove the drive belt by slowly releasing it from the pulley (wheel).
Remove the wheel by rotating each angle and use gently pull, don't harsh in pulling it out, rotate with each pulling power, ---or it will be torn apart, because the wheel is fragile and lame.
You're done with the drum for this step, next is the dynamo.
Dynamo:
First unplug the cables that were attached on it, mark each slot/cables with duct tape and write down for each slot. This is for easy re-installment for future set-up.
There are 4 bolts that hold the dynamo. Before that put a cushion for safety, so the dynamo won't fall down and we just want to make sure there will be no damage with the dynamo.
If you have a T-spanner, that would make the job faster, loosen a bit and thrust gently hand-stroke for each rotating, do this again fairly with same stroke for each bolt. Once the dynamo is loosen, put it on safe place.
Step Four - Miscellaneous
In my experience, there were 3 main hoses that were connected to the drum. The jet (upper), the soap (nearby above on rear drum), and the coin (below and connected to finding-thing tank).
Before you take out the below one, unplug that two hoses that connected to round-stuff. The hard one is the below one, it takes some time, due to the limited space it has and how smart you use your tool under such condition.
Unplug the mass-cable (usually green-yellow one) that connected to the drum, mark with duct tape where it goes.
There will a cable-terminal box on the left bottom, lift it from the stand, this is just for safety. We don't want if unconditionally accident, like drum fall accidentally and may damage that stuff. Because that one would be the first impact. Hence, anything that you see possibly had a chance for such damage, I advice to remove it.
Unplug the cable that attached to the drum, mark with duct tape. There's one cable (red one) that needed to be cut apart, don't worry it's ground cable, you may attach and isolate it back later.
Step Five - Suspension and Drum Unit Removal
Before anything, make sure you put a safety-cushion on below of the drum, because we're going to do the vital part. Each suspension had 2 plastic bolts, up and below. We need only to remove the upper bolt. Jolt using the screwdriver for the snap, and knock gently it out. Do the same with the other suspension. After this, put the suspension far away from the drum.
Spring:
This is the tricky part, if you get used to deal with spring releasing. It won't any major problem for you. The trick is, use the rope and circle the upper jaw, make sure you tie the rope well. Use the chisel (or long shaft), do this like you are going to pull a nail out method. Be very careful, check if the cushion is in proper place for each spring releasing. We don't want to harm the below stuff with falling-drum occasion.
The drum is heavy. Make sure you have a good stamina to take it out, if not ask someone to help you.
Once the spring is out, we need to unlock the belt. This belt is holding the drum and front-seal. Once the belt is loosen, gently pull out the belt from the seal. Next, take the drum out -very careful- from the machine. Now deal with the seal cap. Use a rope to tie the seal-cap to make sure it does not stretching, we just want to make sure the rubber keep in the position. Next is put a proper cushion to hold the cap from not falling down.
Step Six - Bearing Removal
There were two drums. From rear shaft (where the pulley stood for), use the hammer and a chisel (dull) to knock the inner drum out. Knock it fairly on each side.
This stuff is not Japanese made, so I advice if you find a trouble in removing those bearing manually. Pay for someone who is good in dealing with this stuff.
My first machine was really damn hard, because of its corrosion. I forget the specification, but I knew that it was hold tight with three legs for 60 degrees on each side of the drum. I can't bet for a risk by damaging the bearing-case, not yet I fear it would be a leak-risk to the drum, if I hit it with more pressure. Those bearings still won't going out. Lately my friend used the eject machine to take it out, with proper lubricant and some heating.
Last Step - Installment
Put some rubber sealer to oil-seal when installment. Make sure you install those bearings fairly and properly to its case. If you are not sure what you're doing, you may ask the expert.
The most important is make sure no leak of water. Test with water around the seal to make sure the seal is doing its job. When it's done, install back the machine.
Posted on Nov 02, 2008
My washing machine is leaving dirty marks on my washing can you help?
Looks you have aleakage of grease form a damaged bearing in the drum.
If you have the technical preparation, you should remove the drum and check those bearing. See some interesting youtube videos about issue:
How to remove washing machine Drum tub 1 of 4
How to Replace Washing Machine Bearings
How to replace washing machine bearings on Candy Hoover Otsein Zerowatt
Dryer Repair Replacing the Lower Front Drum Felt Seal GE Part WE9M30
YOU EVEN MIGHT FIND MUCH MORE ON THEME DOING GOOGLE REARS ON
Youtube repair drum
Some other brands are similar to Hoover
Aug 22, 2015 | Hoover Washing Machines
Why won't it agitate or move drum?
Screeching noise is typical to drum's broken bearing issue.
See some infor about issue:
How to Diagnose Drum Problems in Washing Machine
How to change drum bearings on washing machine
How to Change the Bearings in LG Washing Machine
How to replace washing machine bearings on Bosch Neff Siemens and some...
Some more video there... explore
Now, if you don't find it so easy to replace those bearings or you are not sure if this is your problem, call a repair service
Aug 18, 2015 | Washing Machines
My washer makes grinding sound when washing, how do I fix this?
Guess it's a bearing in the drum, though just my appreciation. If you are not a tech in washing machines, you should call a reapir service to get it dismounted and replaced
Watch some videos about issue. Take note that you are not specifying your make an model and procedure might be somwhat different for your particular washing machine.
Aug 12, 2015 | Washing Machines
Awo3551
yeah that means you didn't put the bearings in straight causing the shaft to be off center when spinning at high speeds, i have done this before several times unless you used a proper hydraulic press to push them in perfectly square it will be off center when spinning, i assumed you used a hammer and a drift as i have done in the past if so there is a very slim chance of getting it right the only way we have found to get around it is by ordering the whole back half of the tub with the bearings pre set in the tub by the manufacturer as they use proper bearing presses, sorry for the bad news but your going to have to pull it apart again and try knock them in square or order the whole back half of the tub with bearings
Nov 17, 2011 | Whirlpool Washing Machines
Sounds like gravel when it is washing and there is no loose articles in the tub
Ball bearings are worned out. Repalce the bearings with the same type no. or equiv.
Inspect the bearing holding shaft also. If it ir worn circularly, replace the shaft also. You have to replace the wter seal also.
Apr 06, 2010 | Maytag Ensignia MAV4758AWW Top Load Washer
Bad bearing
if the bearings are rusted or seized u need to change main seal near bearings. was it noisy b4 you looked at bearings?could be broken spider that holds bowl.please reply if u need more help
Mar 31, 2010 | LG WM1814CW Front Load Washer
Spin cycle locks up
it is the clutch and be repalced fairly easily
Oct 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
WATER LEAK ON REAR OF DRUM AND EXCESS MOVEMENT hOOVER1400 HPB145
If there is water leaking then you need to repalce both bearings and the seal that sits around the drum shaft and protects the bearing. Check the brass collar on the drum support thats sits in the bearing is not worn or grooved.If it is the shaft and/or the drum need replacing too
Sep 22, 2009 | Washing Machines
Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Dec 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Electrolux EW1000i Front Load Washer Logo
524 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
