Question about Toshiba TP50H95 50" Rear Projection Television
Replacing ic's of TP50H95
I ordered the ic's stk392-110 as you suggested but there's no schematic in my manual to guide me through replacing. Any suggestions?
  • 3 Answers
I can try and guide you from my very limited experience if you'd like.
When at the back of the set looking into the tv, the board that is furtherest to your left and has a riser ontop of it is the board that contains the two stk392's. Look for the side by side aluminium heat dissipaters that the stk392's are attached to (you can't see the stk392's from the back of the set, the dissipaters are in the way) You need to get that board out to complete repair, once you remove the board, the solder points for both the dissipaters and the stk392's are obvious.
I took a photo of all the connections prior to removing board and then labeled all of them. Once I replaced the stk's, I was surprised how easy it was to get it all back together, I didn't need the photo and my repair was successful. There were about 25 different connections and 8 or so screws holding the board in place including one or two in the middle. I hope this helps. Good luck.
Posted on Feb 11, 2009
Rca big screen P61937
Hello crystallb200,
Your Convergence Amplifier ICs have malfunctioned, and have to be replaced.
Here is a brief description on how you can change these out yourself, however if you do not have a background in electronics I suggest that you have a qualified TV technician work on solving this for you.
Remove the back of the TV locate the Convergence ICs (using the schematic or service manual) and the order the parts you will need which are the two convergence ICs and the biasing resistors (you will see these on the schematic). To remove them unsolder the pins, unscrew the screws holding them on the heat sink and remove them carefully, if they stick use a solvent to break down the adhesion of the heat sink paste. Once loose, take them out and then unsolder the biasing resistors and replace them with the ones you ordered along with the ICs.
To install the new ICs put heat sink paste on the back of the ICs and insert the pins into the proper holes in the circuit board. Screw the screws back in securely, and solder the connections back.
After doing this you will need to perform a convergence adjustment, using the cross hair adjustment screen (access this from your TV menu). and the you will need to do an advance adjustment using the crosshatch pattern (also accessed from your TV menu).
Once these are done use you service manual to follow the procedures on locking the adjustments into the TVs memory.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 17, 2009 | RCA Televison & Video
Everything has a blue and yellow ring around it
Hello lomain,
I posted this for another person, but it fits your situation so here are my suggestions:
This is not a bad tube it is a convergence problem. Your convergence amplifiers are malfunctioning, and need to be replaced. If you have a background in electronics, you can remove the back of the TV locate the Convergence ICs (using the schematic or service manual) and the order the parts you will need which are the two convergence ICs and the biasing resistors (you will see these on the schematic). To remove them unsolder the pins, unscrew the screws holding them on the heat sink and remove them carefully, if they stick use a solvent to break down the adhesion of the heat sink paste. Once loose, take them out and then unsolder the biasing resistors and replace them with the ones you ordered along with the ICs.
I hope this helps,
Thank you,
Shuttle83
Mar 23, 2009 | JVC AV-56WP74 56" Rear Projection...
Red convergence outline
I posted this before, however it fits your situation so here are my suggestions:
I hope this helps,
Thank you,
Shuttle83
Mar 10, 2009 | JVC AV-56WP74 56" Rear Projection...
TP50H60
STK IC's are mounted on large heat sinks.....Look on the "hidden side" for #s....caution on older sets = they can be difficult even for senior techs....T.
Aug 20, 2008 | Toshiba TP50H95 50" Rear Projection...
Repair kit
I am having the same problem. What are the part #'s of the stck ic's that you used to replace the old ones?
Jun 11, 2008 | Toshiba TP50H95 50" Rear Projection...
Hitachi 43UUWX10B
The resistors often burn out on that set when the convergence ic's go. The 3.3ohm 1/2watt metal film resistors those are usually the ones that burn out when the ic's go. you have to unsolder one side and lift the leg up out of circuit to check with a ohms meter. You can not check them in circuit make sure you lift a leg up to check or you will not get a correct reading
May 28, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Replacing Convergence ICs
As long as you can solder you should be okay, however i would suggest getting your ICs at the following link because they provide free instalation instructions with pictures on how to remove and replace the Convergence ICs. heres the link.
http://servicemanuals.vstore.ca/
Apr 26, 2008 | Samsung HCL4715W 47" Rear Projection...
Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Mar 01, 2008 | Toshiba TP50H95 50" Rear Projection...
Discharge flyback transformer
you take a long screw driver and a jumper wire to ground and touch any metal on the Red HV wire.
besure to check the resisters other wise it will blow the IC again.
i would also use stk392-180's
Dec 06, 2007 | Toshiba TP50H95 50" Rear Projection...
Televison & Video Logo
97 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
