Givin a set of Jensen comp speakers. Need the wires to conn. to comp.
Need the correct wires to connect to computer. Friend found speakers after moving but doesn't know where the wires are . Jensen jps 45
5 Suggested Answers
Open SKy
  • 620 Answers
SOURCE: Need a wiring diagram for connecting KOSS HD 50 COmputer speakers
Hello there! lellya
1) you have to tell , what kind of sound card you got? on board audio? A7, or Creative Audigy? 5.1 or regular.
2) then, you have to connect one speaker to the other, one two way connector cable, for the 2 KOSS speakers.
3) another cable that goes in back of your koss and from the out of your KOSS Speakers to the input of your sound card, at back of your PC, this input is your sound card jack.
4) its supose to work like so.
good luck
Posted on Oct 17, 2008
SOURCE: cant hear sounds from the head phone.....
Posted on Apr 07, 2009
  • 581 Answers
SOURCE: need to lengthen my speaker wire
buying RCA wire extensions
Posted on Jan 03, 2010
  • 70 Answers
SOURCE: Got these speakers from a friend who was moving. I
First of all please keep it in mind that the Speakers do not require any kind of drivers.
If you are getting the sound volume icon on the taskbar and if you are able to raise and lower the voice using the slider, make sure the mute box is not checked. Similarly check the if the applications Itune or WMP is not muted.
Make sure the drivers for your sound card are installed properly.
Press Windows key and the letter R
Type devmgmt.msc
It will open the device manager
In device manager look for Sound and game controller and make sure the sound card driver is installed properly
For any further query feel free to revert with your comments
Posted on Jul 15, 2010
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up. Thanks.
The reason you may find it difficult to connect the Sony Receiver to the Jensen JS650 is that the JS650 does not have a line level input (RCA) to match the RCA subwoofer output of the STR-DE597 receiver. In this case, all you need to do is connect an extra set of speaker wires from the "Speaker B" Left and Right speaker connections on the back of the Sony to the speaker input connectors on the Jensen. On the front panel of the Sony, select speakers A+B settings so that the subwoofer is on in parallel with the front speakers.
I hope this answer is helpful to your home system set up.
Feb 15, 2015 | Sony STR-DE597 Receiver
How do I splice the power connections into the 12 volt system in my camper? I found there was a ground wire and a 12v switched and unswitched wires. Which would I use?
Both, if you read install you need an unswitched feed for memory of radio and switched for main feed (switched feed will need to be on for radio to work). At the least put inline fuse in the main feed (suggest 10A)
Jul 30, 2014 | Jensen DV2011 AM/FM/CD/DVD
My Boston Digital BA735 speakers are not working. power is on. cords are correctly placed, volume on comp is not muted
Try to isolate the problem. Connect the speakers to another computer or mp3 player or stereo. Test the speakers for sound making sure all volume switches are on. If they work look to sound settings on your computer.
Oct 04, 2010 | Boston Acoustics BA735 Computer Speakers
Subs dont work
To test speakers.A. Unplug speaker wires.
B. connect a 9volt battery to each speaker,touching one wire to the negative and the other to the positive breifly. The speaker should extend outward or inward, simulating the pumping of the cone. Depending on the polarity of the DC voltage hooked to the battery.
That's why it is important to wire the speakers correctly. Pos to Pos Neg to Neg.
You should know if the speakers or wired in series or parallele.
Google speaker wiring. Very informative.
Aug 12, 2009 | Harman Kardon HK695 Computer Speakers
Are these speakers adaptable with my Compaq Presario PC?
Hello my friend, with regards to your problem first we must check if your currentl audio device is compatible with your speakers. I mean you have a 5.1 speaker then let us check if your audio plugs is also a 5.1 channel in order to accomodate your speaker. else you can istall your speaker in to your currentl audio device but not all speakers were work cause it needs to have the same specs from your speaker to your audion device installed in your can only use the green, and blue then if you have mic the you could used the pink plugs but for your black plugs in your speaker it cannot be used.
Jun 16, 2009 | Dell 5650 Computer Speakers
Jensen JMP 50 sounds like I am in a tunnel or well.
Have you powered up the speakers have you checked the sound drivers?? but remember the sound of the Jensen JMP-50s is a bit hollow and lacking in bass, and the speakers do lack bass and treble controls, which can often be found in other speakers in the same price range.
Aug 18, 2008 | Jensen JMP-50 Computer Speakers
Amp stereo hook ups
You need to run RCA cables from the RCA output jacks on the back of the Sony to the input RCA jacks of the Jensen amp. Then you need to run a wire that connects to the blue wire of the wiring harness on the sony to the "remote" or "turn on" terminal of the jensen. That is the wire that turns the amp on when the radio is turned on. It should be on the power wire terminal of the jensen along with the +B (positive) and the GND (ground) terminals. Those are the only ones that go from the Sony to the Jensen. You also need to have the speakers connected to the speaker jacks of the amplifier, and the power wires connected to the power terminal of the amp. The positive power wire needs to go to the positive battery terminal and the ground should be connected to the chassis of the car close to the amplifier. make sure the ground is connected to a clean bare metal part to make sure it is good.
Thats all, but you also need the proper guage wire and make sure no bare wire is exposed to any metal areas or the chassis of the car. You can get all of those things at anyplace that installs car audio. They can tell you the proper guage wire and they have the RCA cables to.
If you are not experienced at this type of installation you really would be better off lettng a professioanl do it for you. It is easy to wire something wrong and damage the amp and/or the receiver.
The wires also need to be run in a place that they will not be damaged and are out of the way.
Ihope this helps you, and please be careful. Help is here if you need it.
If you found this information to be helpful a rating of "FixYa" would be appreciated. It is the only reward we get for the free help we offer.
Jun 28, 2008 | Tomtom GO 700 GPS NAVIGATION BRAND ONLY...
Jensen Bass Boost CR220x
white/black is speaker positive
white solid is speaker ground front and back ground
gray/black is speaker ground front and back
the solid black wire is battery ground
Apr 13, 2008 | Jensen SCR-60 Stereo Cassette Player with...
Hi, Jensen is under different ownership from when your amp was made, so it's unlikely that you'll find a replacement plug for the high-level input. A high-low converter is also called a line-out converter. It's a device that connects to the speaker wires and changes the signal to a low-level RCA connection. This allows you to use the amp's RCA plugs with your speaker wiring (through RCA signal cables). A line-out converter should be available any place that sells car audio accessories.
Aug 11, 2007 | Jensen XA92 Car Audio Amplifier
Jensen LXA400
I have this same amplifier. I have noticed several ways it will "not work" during my ownership of it. I have it connected to a seperate battery to save my alternator, battery, etc as it is a power hungry beast for how low the output wattage is. Test the input voltage to see if you have enough, one way to see this is to check the "jensen" emblem that lights up. If you dont have enough power it will appear dim and only the right side lights up. Also the amplifier will not work if your speakers are "blown" even a little bit. Ive taken speakers that wont work on my lxa400 and connected them to a higher power amp and they will work (although they will sound horrible) If youre smart you will keep the gain under 3/4 on this amp, I see some people have found out the hard way that full gain fries the amplifier circuitry. Not an expert on electronics but it smells somewhat like melting glue or plastic. Ive noticed a lot of people have problems with the RCA jacks as well. There are 8 jacks, in two clusters. The first one is A+B and the second is C+D. Note: You do not NEED Y connectors on this amp! Connect your output rcas from the deck to top left and bottom left jacks of the left cluster. This will give you left and right (a+b) output from the first set of speaker outs. Then connect an rca patch cord from the top right and bottom right jacks of the first cluster and connect the other end to the top left and bottom left of the second cluster. This will give you output from the second set of speaker outs. Remember that this is in 4 channel mode. I dont remember the set ups for 3 channel but two channel I believe is the left deck rca goes to top left of the first cluster and the right deck rca goes to the top left of the second cluster. Then you just wire the speaker outs according to the picture on the amplifier. something like this: _________________________ |(+) - (-) +| ~~~~~~~~~~~~~~~~~~~~~~~~~ Speaker + goes to (+) and speaker - goes to (-) Also addressing another issue if you want to increase the wattage to your speakers you just use a lower resistance speaker (2ohm instead of 4) I would not recommend using anything over 4 ohms. As for the high level inputs, I dont recommend using them unless you have the plugs that go with them, its a lot easier to wire your deck rears to a line converter (changes straight speaker wire to RCA jacks) or to just buy a new deck with RCA outs. Last item, common knowledge: 400 watts does NOT mean 400 watts!!! This amplifier puts out very little actual wattage (50 or 83 per channel depending on the load) Hope all this helps someone out there.. Anyone who knows the 3 channel setups I would appreciate it.
Apr 12, 2007 | Jensen LXA400 Car Audio Amplifier
146 people viewed this question
