Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Need Power Board
Where can I order a power board from for the wd-62327
  • 146 Answers
This can be hard. Mitsubishi is the only place that boards can be ordered. Only a repair shop or someone with an account with them can order parts. And sometimes they need an authorization number to order boards. Call your local service center.
Posted on Nov 15, 2008
Mitshubishi WD-62327 TV will not turn on and no sound. TV made a interference sound and shut off. Tried to turn it in the morning still nothing. Replaced lamp/bulb still nothing. Red light is on (not...
If you have a voltage meter there are some things you can check.
Unplug the unit and remove the back cover of the set. Then Plug the unit back in.
You will need to tape down the lamp safety switch in order to do these tests.
Here are all the failures that would give you a lamp error and what to check.
Cause 1. Unit powers on and works properly for a while then shuts off with a red lamp led(lamp error). Suspect bad lamp and replace.
Cause 2. Unit does not power up correctly and you have red lamp led(lamp error). Check the lamp enable line at connector J14 on the back of the light engine. If pin 6 does not switch to 5 volts after turn on, but your 12 and 5 volt supplies are good, then suspect a defective light engine.
Cuse 3. At power on the lamp turns on and off 3 times and then the unit shuts down with a red lamp led(lamp error). You have a defective light engine.
Cause 4. Unit does not turn on correctly and you have a red lamp led(lamp error). Check for 12 volts at connector J9 pin 4 on the light engine. If voltage is missing check for an open fuse F9A09 on the power supply board. If it is open, then you need to replace the fuse and you still have a defective light engine.
Cause 5. Lamp enable line at connector J14 pin 6 on the light engine does go to 5 volts at turn on, but does not drop back to 0 volts after 5 seconds, but your 12 and 5 volts supplies are good then you have a defective light engine.
Cuase 6. Check for 5 volts at connector J9 pins 1 and 2 on the light engine. If low or missing check Capacitors C9A37 and C9A38. Values are 3300MF/10V. Replace capacitors if defective.
This is all I have and I wish you luck.
Mar 20, 2013 | Mitsubishi WD-62327 62" Rear Projection...
WD- 60738 Just replaced bulb Sept 9, 2011 Unit turns on green flashing timer light, No statis Light, no lamp light. I can hear audio but bulb does not come on. After a few minutes unit shutsdown. The buld...
Hi W Bloom,
First of all, thank you for contacting regarding your TV problem.
My first advice is to do system reset by pressing the "Power" button key at the front panel and hold it for 10 secs.
Please check also if you can access the "Error Code Log" by pressing the "Menu" "3" "5" "6" "4" in sequence before the unit gone to shutdown.
You've mentioned that the bulb has been replaced just last Sept and now it won't come on. The lamp can't be test using the multimeter but you can make a visual inspection to determine its condition. Most of the faulty lamp has an obvious burnt mark. There's a possibility that the symptoms is caused by busted lamp but in your case, if it is a genuine lamp replacement, then high chance that the fault is not the bulb.
You need to check the ballast board but not the high voltage output of it feeding the lamp. No voltage coming out from the power supply board to the ballast board can produced the same symptoms. You have to check the this voltage at connector CJ1, you must get 325V to 340V. Check also the lamp enable at connector CJ3(pin 4) you must get a low voltage upon turning on the set to confirmed that the mainboard giving a signal.
If there's no voltage at CJ1, then the fault is on the power supply board.
If the readings are normal, and still the ballast won't ignite (you can hear a slight snap sound when the ballast board trying to ignite), then you have to replaced it.
Click the link below to order online.
Please let me know if you need further assistance.
Good luck and take care!
Kind Regards,
Dec 07, 2011 | Mitsubishi WD-62327 62" Rear Projection...
Wd 62327 DLP red 3 blinks 1 steady red light
Call for waranty repair if less than 3 months old.
Jan 08, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Have a mitsubishi model wd-62327.lost power now it turns on but no audio or video through any connentions
paid $40 to have a tech look at mine and said its the fmt pcb: 930B931001 & signal pcb : 930B30001
Oct 26, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Replacement Caps for Power board WD-52525
You can check out just look for correct values VOLTAGE, VALUE, TEMP 100C or call 800-638-3328
Dec 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV problem - Mitsubishi wd-62327 62
If the lamp is bad, you will hear a buzz noise as it tries to fire up the lamp. If you let it try enough it will spit out the error message. You can pop the speaker grille off and gain access to the lamp door. Use a philips screwdriver to get in. The lamp will be shattered or damaged looking if bad. If you have a good lamp, you may have 2 bad capacitors on the power board (3300uf). They will be bulged on the top and not flat. It is difficult to disassemble this tv.
Dec 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD 62327 DLP TV
Can I ask where you got the capacitor kit from?
Aug 17, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mits wd 62327 "NOT WORKING"
I recently repaired a Mitsubishi DLP for a similar symptom. Found C9a37 and C9a38 in the power supply to be defective. They feed the light engine driver. The power supply module is located all the way up front on the left side of the chassis looking from the rear. The module is also shielded so you will have to remove the shields to locate the capacitors. The value of the caps are 3300mf/25v. Good luck
Dec 14, 2007 | Mitsubishi WD-62327 62" Rear Projection...
TV Won't power on
Replace the capacitors in the DM board or the lamp is defective.
Sep 18, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
59 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
