Question about Sony DCR-VX2000 Mini DV Digital Camcorder
Perfect picture but audio glitches...
Hi, I read about a similar problem, but the solution wasn't clarified. During playback the audio "glitches," or "ticks." I bought head cleaners, and have run them more than a few times--the problem remains. I can't tell if the camera is recording with the glitches, or if they happen only in playback mode, because they seem to pop up at different times. I have been advised NOT to send the camera to Sony. I bought it used, and am happy with it for the most part. I'm hoping this is a minor issue? Do I need new heads? An adjustment? Thanks for your time.
  • Anonymous May 18, 2008
    My camera does the same thing. It not only drops sound but also has a pixelation effect also. I had the drum motor replaced and a cleaning and alignment done. After about two uses the problem came back. The repair company said the drum motor was bad again. What parts do you usually have to replace to fix this type problem? Thanks for any help. Bill
    Problem Solver:
  • 4 Answers
For audio gliches & dropout of video we suggest to change supply pully & TG Plate of deck machanism then realign with good tape.
regards
sanjy
Posted on Jul 15, 2008
    Champion:
  • 221 Answers
Audio "glitches" or dropout is a typical symptom of tape path misalignment. find a good local repair shop (are there any more of us still around?) and they should be able to perform this relatively simple alignment.
Posted on Jul 20, 2007
SOURCE:
Audio from cd playback distorted all other audio perfect
what program are you using, and are they traditional cd's or burnt?
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 22, 2012 | HP Presario Cq56-115Dx 2.3GAmd Notebook Pc
During playback picture freezes
it's having trouble reading the disk. clean it. use a disc cleaner from walmart or radio shack to clean off the optical lens, too..
Dec 14, 2009 | Televison & Video
Audio clipping during VHS (S-VHS) playback.
Have you tried the Panasonic site, they have PDF (free) of user manuals?
Sep 11, 2009 | Panasonic AG-DS555 S-VHS VCR
Sony CCD-TRV65 No Display on Playback-blue screen
i Had exactly th esame problem with mine and i sent it back to sony as i read it was a chip fault and they repaired it free of charge for me and sent it back very promt. Contact them via email and check out similar problems online they detail the exact cause of this and it helped my case enormously.. i hope this hlps you bu ti did read they had a time limit on this fault so good luck.
Feb 01, 2009 | Sony Handycam CCD-TRV65 Camcorder
I'm having a problem similar to those describe regarding the drop off of the picture during dvd playback. However I noitced that if I plug the player in directly, rather then just running it on the...
The problem of Polaroid DVD-players is too suggen cuttofs during playback. Usually there is no "low battery" warning 5 minutes before it just cuttofs. Usually it has 4 hours playback time.
Probably you need to replace the battery.
More information you can read here.
Good Luck
http://reviews.cnet.com/portable-dvd-players/polaroid-pdv-0700/4505-6498_7-30602915.html
Dec 07, 2008 | Polaroid PDV-0700 Portable DVD Player
Black screen during record
contacted Sony chat assistance. It is a warranty glitch. I have to send it to Sony, but they will repair free of charge.
Mar 16, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
Records media but playback has no audio.
Are you absolutely sure that it is receiving an audio signal?
What input are you using? Try recording using alternate inputs.
Audio part of a VCR is normally way more reliable than the video.
The exception is on high-end stereo types where they record the extra audio signals using the video head cylinder in which case it can easily be lost.
Jan 24, 2008 | GE VG4054 VCR
No audio on tv channels but perfect on DVD playback etc
this looks very much like a problem I once 've had (and later found the solution by accident). When you go into the menu of the remote control and press the "automatic channel search" function you can always specify from which "source" the signal is arriving either 1, from antenna, (ie. over air) or 2, from cable or 3, from satellite. Then the decoder searches and finds a bunch of station in its reach. Once (while hooked up to an antenna) ,I had accidentally made it do the station search under the "cable" header instead of "antenna" and it found the same stations as the one's I've had before,(over antenna) but some stations suddenly had no more audio. Because I was unaware that the set was programmed under the cable header I could solve this strange mystery only much later when I reprogrammed it one day and it searched the stations under the Air-Antenna header, then suddenly all the stations were coming in properly, with good image and full audio. ------If this doesn't solve your problem then search under the menu of your set if at another part of it you can specify some other similar options like Antenna-Cable choice. I'm quite sure its easy to correct. good luck Alex
Mar 26, 2017 | LG DBRH197H DVD Player/HDD Recorder
Problem with menu system maintaining display
I would highly suggest upgrading the firmware. Best thing to do first when having odd glitches like that.
Nov 27, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Auidio drops
while your monitoring the sound when recording it cuts out or while you playback the tape it dropps out? if it's noticed during playback it's one 3 things. the heads are dirty, the tape tension is low or the heads are bad. send it to video tech service in sacramento. that guy is super cool.
Jun 20, 2007 | Sony Handycam DCR-TRV900 Mini DV Digital...
Sony DCR-VX2000 Mini DV Digital Camcorder Logo
206 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
