Scanning from Sharp to Mac OS X
How to i scan from my old Sharp AL 1540 CS to my new Mac OS X
  • 114 Answers
SOURCE: upgraded to MAC OS X; is there a compatible driver?
This scanner was released back in the late 90's, before Os X was released. Heidelberg discontinued support of all but their high end Nexscan scanners. So unfortunately, newer drivers were never made for this product.
Posted on Sep 29, 2006
  • 589 Answers
SOURCE: epson scan application won't open
Do you mean the old powerbook has the same OS as the new one, or the same epson software version?
In any case, this is all I found on it:
Posted on Jan 11, 2008
  • 74 Answers
SOURCE: failed to open a driver
Here ya go.
The drivers for your scanner.
Posted on Dec 24, 2008
  • 35 Answers
SOURCE: Epson Scan Reporting "Unable to write file" when scanning a photo on a Mac.
Do you have sufficient disc space? That is the only reason you should see an error like this.
Posted on Jun 14, 2009
  • 35 Answers
SOURCE: Mac OS X Leopard & Dimage Scan Elite II
Forget about the Minolta software. It's buggy at best with OS X. Use VueScan instead. A free trial is available so you can test it before you commit to buying it.
Posted on Aug 16, 2009
How to i fix the h2 code for sharp al 1540 cs
H2 is a termistor have to reset it if it works ok if not you have to change the termistor..
enter service mode c - auto -c auto than enter 14 and start .....if the code goes it is ok if not change termistor.
Oct 31, 2014 | Office Equipment & Supplies
Need driver for Sharp al 1642 cs with windows 64-bit
Please communicate with me through my email then i will send driver to you. thanks
Nov 05, 2012 | Sharp Al-1642cs Print/scan/copy
Sharp AL 1540 cs Code CH What is the code and how can I fix it. A new toner cartridge was installed last night.
Check the new unit is correctly seated and open and close all covers on the printer until it clears.
The CH Code is for an open cover but maybe to do with the cartridge not being seated correctly.
May 04, 2011 | Sharp AL-1540CS All-In-One Laser Printer
Cannot scan using Sharp AL-1655CS
Make sure that you install the driver for your operating system. Check the stop of the scanner under copying table to the left.Do installing the equipment from panel of management. Check in "system" of the "panels of management" consumption resource of your printer and scanner. The Driver of the scanner is fixed from printer apart. Arouse update the drivers in accordance with your operating system.Windows or Vista or Linuks on put
Oct 07, 2009 | Sharp AL-1655CS Copier
Sharp AL 1551 CS RSPF not feeding
This can be a fault of the controller of the direct current. Apply to service This fault can be not eliminated by you.
Mar 23, 2009 | Sharp AL-1551CS Copier
Al-1540 only scans, wont print says-data could not be sent to pri
it seems that the computer was trying to send the data to the printer through the wrong port. i went to the control panel in windows xp, and selected printers and scanners. and added a new printer (manually) as al-1540 cs on usb port 2. it alerted me that the software was not signed, i proceeded anyways. it asked if i wanted to keep the original printer , i said yes. and the test page printed away. so i would suggest people with similar problem to keep adding multiple copies of the printer again and again on usb ports 1,2,3... etc till it prints the test page. use the copy no. indicated in the printed test page to do all your print jobs in the future.
Dec 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
This is usually caused by a bad Fuser unit.
Does it happen all the time?
Did you take the Toner/Cartridge out and check if there is some paper debris in side?
Oct 02, 2008 | Sharp AL-1655CS Laser Printer
Sharp AL-1540 CS Error
there is a lock on the left hand side ... make sure it is in the unlock position.
Mar 10, 2008 | Computers & Internet
103 people viewed this question
