Hi, my hp ipaq hw6950 won't connect to my wireless router. It endlessly says connecting... connecting... connecting... Thanks
  • 113 Answers
try resetting the router and try connecting check whts the wireless standards in the router and the ipaq and config according to that for instance if ur router can support b then try entering the setting manually it will work try entering the correct wireless key
Posted on Nov 01, 2008
My HP G60 laptop with Vista won't connect to Netgear router
Usually there are 2 types of wireless connections, 2.4 GHz and 5 GHz. Your laptop may not be able to connect to one of these connections, so it may be incompatible with your router. You can try buying a USB networking card (no more than $20). It will plug into one of your USB ports and should allow you to connect to your router. Hope this helps!
Jun 22, 2017 | NetGear N600 Wireless Dual Band Router
I cant get wireless on my handheld hp ipaq 2200
change the security settings if any in the wireless router.... use 64bitWEP password for the router and if it is a BELKIN wireless router then WiFi protected setup should be disabled in the roter....
contact router's technical support to do settings in it....
Apr 28, 2010 | HP Computers & Internet
Set up
Hi Rbosley,
I found the real manual here,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&cc=us&dlc=en&product=218413&os=228&lang=en&
Second one down.
Are you using Cable, or DSL. DSL requires you to setup a PPPOE connection, putting in your Username and password for you DSL connection.
Are there any other routerrs on the network? Just making sure you are not trying to use the router then there is one already one on the work.
I would suggest your use the reset button on the back, resetting it to defaults. That way, you should be able to plug in your modem to the WAN port, plug your computer into the LAN port.
Then restart the modem, wait 2 min, power up the router, wait 2 min, and startup the PC. Make sure your IPs are set to automatically get IPs and DNS. The router's DHCP should supply them to your PC.
DSL requries you setup a PPPOE connections, which really just consists of selecting the pppoe option, putting in the infomation, and the doing all the rebooting.
It you still are having issues, get back with us!
Jan 09, 2008 | Compaq iPAQ Connection Point CP-2W...
IPAQ h5550
I had to install several updates on my H5550 to get the wireless to work. You need firmware 1.10.10 to start with (the latest version), then there are several wireless firmware updates, and a wireless driver you need to install. I can´t remember what these were off the top of my head, but it might help point you in the right direction.
Oct 30, 2007 | HP iPAQ H5550 Pocket PC
Hp ipaq 4240
Turn your Linksys router off and back on again, then try connecting on your iPaq again. If that fails, do a soft reset on your iPaq and try again. If that fails, do a hard reset. Also, do you have any wireless security set up for the router?
Sep 07, 2007 | Computers & Internet
Wireless connections
Is your router setup for security? For example on your laptop, did you have to enter a SSID & WEP key in order to get connected to your wifi router. Also, see if your router is setup for MAC filtering, may be possible that its blocking your handheld device from connecting. If thats the case, then you would have to do the same steps on your handheld device has you would on a laptop.
Sep 03, 2007 | Computers & Internet
IPAQ wireless connectivity
always start with the simplest answer first so make sure you have WiFi turned on. Think back, have you changed the wireless security on your router? If so you may need to re-enter the network details or add your iPAQ's MAC address to the access control list on the router. In the bottom right-hand corner of the home screen you should have a small HP Wireless symbol, if you tap it you should get your HP Wireless control panel on screen and can 1: turn WiFi on and off, 2: manually enter the WiFi network details and 3: search for WiFi networks in range.
Aug 16, 2007 | HP iPAQ H5555 Pocket PC
Connecting a Ipaq RX3715 to a wireless router
First, you have to be sure your ipaq has wi-fi feature is on and you can check on network connectivity option for any wrong setup there. According to your information, your ipaq is not recognized by your router and I agreed that your router is working normally. Try to reboot your ipaq and be sure to get wi-fi to turn on and try to connect it again. I have my Dell Axim also used Windows Mobile like Ipaq and it connected easily with no issue. The message in your to show me that you need first to identify your ipaq before you you can get it to connect to your network. I hope this help.
Mar 05, 2007 | HP iPAQ RX3715 Pocket PC
Hx2410 general wi-fi questions
Have you been able to connect through your router at home? I'd get that set up and running first. Then doing it on the road will merely be variations on a familiar theme. If you've tried at home but it hasn't worked, let us know something about your home network (what kind of router? using security/encryption?), and about what you've already tried so we can try to help.
Sep 08, 2005 | HP iPAQ hx2410 Pocket PC
Connecting RX3115 to Laptop w/ WiFi
you have to configure an ad-hoc connection between ipaq and pc if no router. otherwise, simply connect to the router and run activesynch
Sep 07, 2005 | HP iPAQ RX3115 Pocket PC
Computers & Internet Logo
183 people viewed this question
David Payne
David Payne
