Question about Whirlpool GH8155XM Microwave Oven
Microwave dead even though power works
Gexl1800 over the stove just quit working. i checked two fuses and i got a short on both. can you help
  • Whirlpool Master
  • 9,098 Answers
Is it dead, meaning no display, no light when you open the door and no beeps when you press a pad on the keypad? Is the outlet working?
A microwave can be dead for many reasons.
Itmay be the fuse, which is usually located behind the grille or on thefloor of the oven behind the control panel or between the door switches.
Ifthe fuse is good, it may be an open thermostat or thermal cutout (TCO)/ thermal fuse on or near the magnetron or on top of the cavity / bodyof the oven.
If it goes dead for a while during or after cookingthen comes back on, the magnetron is probably overheating and causingthe magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
Whenchecking TCOs or thermostats, if it has a hood fan thermostat, that should readopen, as opposed to the others, which should read closed.
TheTCOs you need to be concerned usually with have all black or whitewires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Ifit goes dead or blows the breaker (or GFI) when you plug it in or open or closethe door, then there's a problem with a door switch or door switchmount.
If it's intermittent or random, it may be a badconnection, usually on the control board or a loose fuse holder, oreven an intermittent fuse.
You should do a continuity test onthe fuse while it's in the holder (with the microwave unplugged, ofcourse) then turn the fuse by hand or take it out and put it back in,then test it again.
If you remove the fuse, then press the meterleads against the ends, it can allow internal contact to be made andmake a bad fuse appear to be good.
If you or someone you knowdecide to look into it, we have critical safety information anddisassembly information at our site, and our link is at our listing here on FixYa.
Thereshould also be a "mini-manual" hidden inside the unit behind thecontrol panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting & testing.
If you'd want to scan and e-mail or copy and fax the mini-manual (or atleast the "schematic diagram page) to me, I'd be happy to make moreprecise suggestions.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Nov 09, 2008
I have a Panasonic inverter microwave. Was working perfectly an hour ago. Now totally dead. There is no light or anything. Have checked plug and fuses. No smell or anything. Can you please help.
Could be a shorted inverter blew fuse and unit dead. Or bad fuse holder got fuse hot and melted fuse so now unit dead. Must check fuse first and if bad replace and try, if it blows as soon as it tries to heat probably bad inverter. If it works for a long while then quits maybe bad fuse holder not grabbing fuse tightly making it over heat. So then bad by temperature not amperage.
Jun 20, 2017 | Panasonic Microwave Ovens
GE oven is completely unresponsive but I have power to the plug that goes to the board. I see no obvious signs of damage, no burnt anything, not even a smell of burnt stuff.
Hi, Did you check the fuses on the stove. If it was built before and after model year 2000 there still should be fuses. If your stove is still under warrenty you may be able to get it fixxed for free. Good luck.
Feb 21, 2015 | GE Microwave Ovens
Our Maytag 2001 microwave white over the stove just quit. Is it dead?
there is a fuse in the cabinet for the electronics but you will need an electrician to get to it. have it check ed out or junk it.
Nov 18, 2014 | Microwave Ovens
Suddenly microwave stopped working
(would really like more info- digital number dead as well?)
(assuming completely dead) Could be a couple of things:
- blown fuses (inside, relatively easy to replace, std size avail at Raioshack) <-- most likely
- cut/loose power cord connection inside.
- (unlikely but worse case scenario) Door was closed crooked- one tong hit one door switch before the other- causing a short circuit internally that "self destructs" the microwave to prevent it ever operating with an open (or even crookedly ajar) door, irradiating any users. Typically it just blows the fuses, but if fuses blow immediately upon replacing and turning power on, then possibly one of the switches fused or melted internally, and needs to be replaced.
Jan 28, 2014 | Whirlpool MT4155SP Microwave Oven
I have a Magic Chef microwave MCO160UB. I was cooking on the stove (microwave wasn't on) and the fan came on as it has done before. After a few minutes, it shut off and is now completely dead. I...
If the microwave is above the stove, the heat sensors in the microwave
may turn on fans to cool it even though the microwave itself is not
running. It tries to save its life. It should turn off when the stove is not
heating it.
Aug 29, 2011 | Magic Chef MCO160UB Microwave Oven
My microwave quit working.
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches or on a small filter board in the back where the power cord comes in.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron, or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed or virtually zero ohms.
Also, the hood thermostat usually has thinner wires that are not black or white, like the other thermostats' wires.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you.
For more help from Emerson
visit here or get help using your appliance at 1-800-898-9020.
Get help locating an authorized servicer or parts at 1-800-695-0098.
Jan 10, 2010 | Emerson Microwave Ovens
It sounds like the magnetron overheated and opened the thermal fuse on the magnetron.
This can be caused when the internal cooling fan is not running or by a magnetron that is failing.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
The magnetron will have a 5 to 9 year warranty. Your manual will tell you that.
You can download GE owner's manuals and installation instructions here.
If needed, GE may send you a replacement magnetron. GE Customer Service is here.
Dec 04, 2008 | Microwave Ovens
Powerless microwave
The HV capacitor or the HV diode may be in short, check these parts, discharge the capacitor before touching anything.
Maybe something is shorted to ground.
Feb 16, 2008 | Sharp R-1490 Microwave Oven
Kenmore elite microwave
Does the digital display light up at all? Is it completely dead? Are you sure it has power? Have you tried another outlet? If the outlet is good and the unit is completely dead, the internal fuse may have blown. You can try to take the cover off (with the unit unplugged) and look for a blown fuse. Try replacing the fuse with an EXACT fuse of the same rating. Try plugging the unit back in again and see if the unit comes back on. If not, you may have a power supply issue or defective Magnetron.
Please let me know what you find and we'll go from there.
Good Luck,
- Jim
Jan 28, 2008 | Kenmore 62702 Microwave Oven
Repair an Amana microwave
My amana micro just went dead. No lights nothing ,almost like a fuse blew.Its an over the stove model . The outlet works fine.#mvh210w
Dec 21, 2007 | Amana AMC6158B 1000 Watts Convection /...
Whirlpool GH8155XM Microwave Oven Logo
132 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
