Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Vertical lines If my TV is moved for any reason it will display wavy, vertical lines across the entire screen. Most of the time the picture looks this way, but sometimes it is very clear and crisp. I have checked all of the input connections and they appear to be solid.
  • 1 more comment
  • jwaynenewm Nov 20, 2007
    the tv was moved and now there is vertical lines that are red they go and come back i took the screen out and tthe red projection light has the lines going through it but the other two are clear
  • Anonymous Feb 21, 2008
    mine does this as well, most of the time the lines are present
  • Hatfield Feb 24, 2008
    I have the same issue. Most times the lines are there,but some times they go away after the TV has been on for a while. When they go away, the picture is great.
    Scholar:
  • 131 Answers
The red line in the crt is the sreen voltage is to high or bad tube.
A simple fix is if you take off the front panel there will be a black box be careful it is high voltage make sure you are a pro.
there will be six controls look for the one marked screen and is for red tube adjust very slightly counter clockwise.until red
line gos away. If that does not fix it its the red tube.
I hope this helps doctor video
Posted on May 01, 2008
Samsung TV display has gone out - has audio, but there are vertical, colored lines/bars across entire display.
Call a television engineer. Don't try and fix it yourself it always ends badly and more expensive. Could be a board, a component on a board, a bad connection, or blown capacitors. The course is 2 years full time education.
Apr 30, 2018 | Samsung Televison & Video
Green vertical lines across screen
It will be best to contact the authorized service center for Samsung in this case. They only can provide the component.
Nov 30, 2013 | Samsung LN-S4695D 46 in. LCD HDTV
Very thin black vertical line moving across tv screen left to right on tv
The screen voltage to the picture tube is more than normal. Adjust it by the help of screen pot-meter integrated with Line Output Transformer. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 05, 2012 | Panasonic CT-20SL14 20" TV
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Oct 31, 2009 | Dell Inspiron 1720 Notebook
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Picture Problems On 50 Inch Philips Plasma
You plasma still under manufacturers warranty. Most electronic devices have one year warranty.
The failure in your TV can only be corrected by repairing it.
I would suggest to call philips and ask them to find you an authorized repair center near you to get your TV fix under their warranty.
Jul 24, 2008 | Philips 50PFP5332D 50 in. Plasma...
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
137 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
