Question about Whirlpool GD5SHAX Side by Side Refrigerator
Do not defrost
Def Detrm T-Start & heating element are ok Is the PC Board The Defrt Timer ?
  • 59 Answers
Yes. This refrigerator has whats called an Adaptive Defrost Control or ADC board. It is located to the right of the thermostat controls and has between 4 and 6 wires going to it. Hope that helps.
Posted on Nov 02, 2008
Freezer frosts up and food gets soft
Repair the defrost system, defrost timer,defrost thermostat and defrost heater.
Aug 18, 2009 | Refrigerators
The refrigerator side has stopped cooling.
, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Freezer freezes, freg doent get cold
Aug 17, 2009 | Refrigerators
Freezer cold but not freezing
I you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Freezer works fine but refridgerator doesn't
Aug 16, 2009 | Refrigerators
Refrigerator and freezer not working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 15, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Frigerator working not freezer
Aug 15, 2009 | Refrigerators
Freezer is not cold
Aug 13, 2009 | Refrigerators
Samsung fridge rs52530bwp the fridge side will not work
I have a similar situation before in your case if your heating element is working then you are lucky I had a samsung fridge and the defrost heating element was bad and i was forced to install a different one because i would have to change the hole evaporator in order to replace the heating element so what dit was to use a mechanical 10 hour defrost timer and install a generic heating element and a defrost thermostat on serial so it want work on less the evaporator has froze over i drill a hole to the back of the fridge and i wren the cables to the back of the fridge cover then whit foil tape an take power directly from the power cord i install the timer next to the control board so every 10 hours will give power to the heating element but will not come on unless the evaporator has froze up. on my case i had to do it like that because the heating element i use was to strong for the control board and would just burn it up. but will work even better using the original heating element. NOTE: find the diagram of a old fridge that will help you to figure out how to install the timer and the defrost thermostat no need for the timer to cut off the compressor keep in mind than the defrost thermostat only close the circuit when is chill below freezing so i recommend to use a new one I hope this help you
Jun 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
Defrost not working
probably a bad def sensor. attached to the top of the coooling coil is a round sensor that senses heat form the def heater and terminates defrost when the coil cleared of ice. the part is model specific and is fairly inexpensive.
Jan 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool GD5SHAX Side by Side Refrigerator Logo
70 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
