Question about Maytag Atlantis MDE7400AY Electric Dryer
Dryer belt snapped bought new one and will not reach the pulley by a 1/2 inch this is a maytag dryer thought these belts were all the same length are they not ....
  • 4 Answers
Make sure the belt is in the groove on back of drum for belt then run belt from left side of drum over and around pulley on motor shaft going clockwise then continue around pulley and run belt toward belt tension pulley the one with the spring on it go counterclockwise around it at this point you will have to pull up on tension pulley to get belt on then realease that should take care of it ed
Posted on Nov 01, 2008
Replace seal around tumbler
unplug the dryer, pull out from the wall 6 inches, remove the screws at the lint filter, use putty knife to pop the clips at the seam between the top and front(one on left front and one on right front and an inch or two in) , remove the 1/4 inch hex head screw one on left , one on right, tip front forward, unplug the door switch, remember where the wires went, lift the front panel off. Remove belt by reaching under drum and grasp the idler pulley and pull it to the right and slip the belt off the motor pulley, use belt to lift the drum and pull out from cabinet. Remove old felt. do not get adhesive on you it is hell to get off. Use disposable gloves if possible. put glue around the tub, install the new felt, the fold face toward the back so that you can see the stitching. Allow 15 minutes for the adhesive to set up. Reinstall the drum, make sure the ridge of the drum is seated to the rollers in the back, put belt on the line where it has been riding and run hands around the belt making sure it is not twisted and the ribs are facing the drum. install the idler pulley in to the slot in front of the motor, pull belt through the idler pulley, pulley idler pulley to the right and re install the belt to the motor pulley. Re install the front of the dryer by inserting the clips on the inside of front in to the square holes on the cabinet front edge, re install wires for the door switch, the ones you remember where they went, put the screws back in to hold front panel, snap the top back down, put the screws back in at the lint filter area, Done! Wait about an hour before you run it to allow the adhesive to fully cure. These instructions are for most Whirlpool, kenmores made by whirlpool, roper, and kirkwood dryers. If this is not what you have contact me. Good luck.
Feb 04, 2014 | Kenmore Dryers
I bought it in 2003 neptune dryer and the 3 bar inside the dryer broke and the dryer is not working right . we have to dry them 3 time before they are all dry
Things You'll Need:
* Phillips-head screwdriver
* Replacement belt
1. Disconnect the power cord of the Maytag Neptune dryer from the dryer electrical outlet.
2. Open the dryer door, and locate the four screws on the inside lip of the door opening. Use a Phillips-head screwdriver to remove the four screws. This will disconnect the front panel from the shroud assembly.
3. Grab the front panel on each side with your hands. Lift up on the front panel to unhook it from the retaining tabs on the side panels. Remove the front panel, and set it out of your way.
4. Use a Phillips-head screwdriver to remove the four outside perimeter screws that secure the shroud and tumbler front to the dryer cabinet. Pull the shroud and tumbler front away from the tumbler while lifting the top panel partially up.
5. Reach both of your hands underneath each side of the tumbler. Use your left hand to grasp the idler pulley, and pull it to the left while using your right hand to slip the belt off the motor pulley. Pulling the idler pulley to the left releases tension on the belt. You can now slip the belt off the back of the tumbler.
6. Take the old belt with you along with the model number of your dryer to purchase a new belt. Most appliance repair shops will have replacement belts in stock. Make sure that the new belt matches the old one by comparing the two.
7. Slide the new belt over the rear of the tumbler with the ribbed side pointed to the inside. Using both hands under the tumbler, route the belt around the motor pulley and idler pulley. Pull the idler pulley to the left while routing the belt, and carefully allow the idler pulley back to the right to apply tension.
8. Reattach the tumbler front and shroud to the front of the cabinet using the retaining screws. Place the front panel over the side retaining tabs, and push it down to lock it in place.
9. Open the dryer door, and secure the front panel to the shroud using the retaining screws. Close the dryer door, and plug the power cord back into the dryer electrical outlet.
Feb 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
New Maytag dryer belt too loose
is the idler pulley have enough tension on it,the tensioner on these can get bad and not put enough tension on the belt,push on it,it should take some force to move it,if you can get your fingers under the belt around the drum without much effort then replace the idler pulley and tensioner
Jan 31, 2010 | Dryers
Installing a belt on a maytag dryer the belt seem to be too big what's the solution
you probably don't have it strung right thru the idler pulley by the motor, thats if you have the right length belt to start with,measure it with the old one to be sure
Oct 26, 2009 | Maytag SDE5401AYW Electric Dryer
How do you open the dryer to fix the belt
First before you you raise the top, open the cover on the back by the motor and let the belt loose from the motor pulley unless the belt has broken. If it has go to the lid. Slide a thin flat blade under the front of the lid and feel for the two clips several inches in from the corners. Push straight in on a clip while pulling up on the lid at the front edge and it will release the lid at that point. Do the other clip. Lift the lid. Three are usually two screws, one on each side holding the front tight. With the screws removed, pry out by each of the push clips on the side. The front should be come loose. Swing it away slightly paying attention to the wires to the door switch. Slide the new belt over the drum and work it to where it ran in the past. Put the front back on and snap the lid down. When putting the front on guide the front panel and the drum together at the felt seal. Open the panel on the back near the motor. Reach in and spring the belt tightener over and put the belt around the motor pulley. Let the spring tightener tighten the belt. Put the cover back on.
Jun 06, 2009 | Maytag MDG6000 Dryer
How to repair instructions
The rollers behind the drum need heat resistant grease. You'll need snap ring pliers to remove them. Clean and inspect everything inside, vacuum all lint. Have a spare belt, they're cheap. Check the tensioner pulley for lube, but don't get any where the belt touches.
Mar 29, 2009 | Maytag PYE2300AY Electric Dryer
Loose dryer belt
there should be a belt tensioning pulley or the motor should move in order to tighten the belt.
Dec 27, 2008 | Whirlpool LER4634J Electric Dryer
Broken belt that turns the drum
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!0798e0b.jpg
Aug 17, 2008 | Maytag PYG2300A Gas Dryer
Fitting tumble dryer drive belt
Looking from rear of dryer,one spring on motor is for tension,therefore put belt around drum(groove to the drum surface).Then rotate the motor firmly clockwise tensioning the spring,take belt from right of drum over tension wheel then put grooves of belt on shaft of motor.Release motor to tension spring,job done !!!!!
Mar 28, 2008 | Dryers
Maytag Electric Dryer - replace belt
The belt needs to be above the metal. Otherwise the repair looks good. Easy fix. Thanks for the pic.
Jan 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
139 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
