Question about HP DeskJet 5650 InkJet Printer
I had a paper jam and when cleared,
The ink cartridge is now fixed to the left side of the printer, the on/off switch is blinking and, the yellow down arrow on the left is blinking. I can't get the printer to work now and there appears to be no paper left
  • Cathy9985 Nov 26, 2008
    my printer had a paper jam and when i cleared it, a yellow light kept blinking and it wouldn't power down so i unplugged it. Now it will turn on but won't print.
  • 33 Answers
Disconnect the power cable from the back of the printer..press & hold the power button down for 40-45 seconds...then try to slide the carriage manually from left to right..then connect the power cable and turn the printer on..
Posted on Nov 26, 2008
    Scholar:
  • 87 Answers
What happens when you power off/on the machine?
Inkworks
866-381-0541
Posted on Nov 21, 2008
It says paper jam but we do not see any paper anywhere
did you switch the machine on and off
one of the paper sensors may be stuck pr damaged
Feb 14, 2011 | HP Officejet Pro 850 InkJet Printer
I have paper jammed in my HP DESKJET PRINTER D2260. Tried to pull it out but paper ripped off and can still see other end still in there. Been advised to open back door and clear it but cant see how back...
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 18, 2010 | Office Equipment & Supplies
How do I clear a paper jam from the hp laserjet 1020
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Nov 16, 2010 | Office Equipment & Supplies
False paper jam reading.keeps say to clear paperjam. called HP and they said its a common problem,too expensive to fix,buya new one from us for 300 bucks
Check the following Steps for fix HP printer carriage Jam :
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Sep 14, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How do I clear a paper jam in the Kodak ESP-3 can't get to the paper
If you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below. Works for esp 7.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
Jan 17, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Blinking green light
Clear the paper jam, or replace the ink cartridge. Possible causes are the paper jam or ink cartridge. The other solution is to disconnect the power from your printer and reconnect it. Hope this helps!
Oct 22, 2008 | HP Deskjet 3845 InkJet Printer
Hp Officejet 6310 All-in-one paper jam
Here's a video that shows how to clear a jam on this printer.
Apr 08, 2008 | HP Officejet 6310 All-In-One InkJet...
Ink cartridge carrier jam
Once it jams on the left turn off the machine. usually my lights are all red at that point, one is blinking the other two are solid red. open the cover. shine a flashlight in there, you will see a clear or light grey plastic ribbon that runs from the left to the right. it is the top most thing. Very carefully, clean it with a paper towel and a little water. or a kleenex. it should be almost clear.
after done, move the cartridge head to the right without turning on the printer. once again, clean the clear plastic ribbon where the cartridge head was located. finally turn on the printer, when it stops initializing, click the paper feed button, if you were successful, you won't see it jam into the left side.
if not, try repeating again. I think the optical head could also have some junk on it, and will deposit it back on the clear grey plastic strip.
the clear strip passes through the cartridge head. I'm told it is called an encoder strip and the optical head reads the strip to know it's position.
when that strip is dirty or covered with some ink spots, the print/cartridge head, can't read it and slams into the side the the printer.
this happened to my c80 at least 3 times now in seven years.
Feb 09, 2008 | Apple Epson Stylus C80 InkJet Printer
HP 5650 deskjet printer
Did you or one of your users have a paper jam recently and force the jam out of the printer? Because we've had a few 5650's do this after a jam. About 66% of the time this fixed it...
  • Removing the ink, unplugging the printer, moving the print head to the half way point, and starting the printer. If it resets at that point and lets you put the ink in, your usually gold. If it just stops and blinks again your not.
That said, I'm actually taking one apart that wasn't fixable this way right now. I think the problem may be something related to not recognizing if the cover is up/down, but still can't see why it happens or how that it is effected by the jam.
Oct 22, 2007 | HP DeskJet 5650 InkJet Printer
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer
Four flashes: Empty ink tank
One of the ink tanks is empty. Replace it.
Six flashes: No print head installed
Install a print head.
Seven flashes: Defective print head
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight
flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL
button to cancel the error so you can continue printing. Before the waste ink tank
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Oct 19, 2007 | Canon S520 InkJet Photo Printer
HP DeskJet 5650 InkJet Printer Logo
119 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
