Question about Zebex Z-3080 Handheld
Computer does not see the scanner
I have a zebex hand scanner that was given to me. USB port. When I plug it into my laptop , the laptop does not see the scanner. How do I fiex this problem
dave
  • Anonymous Feb 04, 2009
    same problem, laptop doesn't recognize. but its red light is on and if i try to scan, it beeps, but no data is input into the computer
    Genius:
  • 1,913 Answers
Check that scaner in other system if u found then reintsall your scanner driver in your laptop or usb.driver
Posted on Nov 01, 2008
Driver Needed
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you
might see a yellow? ! question exclamation mark or red X this will mean you need to install a new driver for this device
right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options you can troubleshoot
hope this helps
Jul 15, 2012 | Zebex Alpha 70 (93086)
How to use zebex barcode scanner?
Click below for a link to the support site. Click on the User's manual for you model scanner.
Zebex Manuals
Hope this helps.
Zeppelinx12
Mar 11, 2011 | Zebex Computers & Internet
My notebook computer only has USB plug and it does not has serial port plug (RS232). I bought a USB converter cable for the RS232 plug. The notebook computer reconciles the USB converter cable and not...
Tthe Capshare only works with XP or Windows 7 Ultimate which has a virtual XP inside it ( a retrofit for outdated software).. I will not work with VIsta.
Feb 13, 2011 | HP CapShare 920 Handheld Scanner
Installing the Zebex z-3010
Normally, these scanners need no software, as they simply send a series of digits to the active text box. Try opening notepad or word and scanning any barcode. It should type the number itself.
Apr 14, 2010 | Zebex Z-3080 Handheld
WHERE CAN I DOWNLOAD ZEBEX Z-3080 SCANNER SOFTWARE?
This device needs no software. You first need to set it up with the configuration card (http://www.zebex.com/old_website/documents/quick_program_card/z-3000.3001.3010/Programming%20Card_U_090202.pdf). Then it should scan the barcode number in to the selected text area.
Mar 24, 2010 | Zebex Z-3080 Handheld
Alpha 70 Series is not working after disconnecting PC and recnctg
Hello Suzanne. The problem you are going to find here is that Zebex doesn't make this model anymore and haven't for some time. If the unit has power and emits a beam, I have the Zebex generic Programming Card and Programming Guide available on my company's website. Have a look at the sections that include the "reset default" barcodes. Print out that page and try scanning them with your scanner. Resetting the scanner to it's default programming may get everything ironed out. If the scanner doesn't have power or emit a beam, then unfortunately you will be looking at getting a replacement scanner. I can recommend several different scanners what would work fantastically and be quite cheap. If you still need help, please feel free send a message or email me. I hope this helps. Good luck!
Dec 28, 2009 | Zebex ZB 2200AM
Z-3052 usb driver
http://www.zebex.com/supports_services/technical_download.sbu.htm#
Oct 13, 2009 | Zebex Computers & Internet
Cannot detect scanner
There is going to be issues with connecting it in this fashion. The usb adapters are not addressed the same as a real parallel port. This means that the drivers probably do not have a chance at working. The other issue is usb ports on laptops rarely have the power to drive devices larger than a mouse or keyboard. This means that the usb adaptor may not have enough power to function. Try plugging it into a powered usb hub then to the laptop. This may give it enough power to do what you want if the drivers are compatible of course.
Good Luck.
If all else fails goto goodwill and get a usb scanner. I always see stacks of them. Most are the usb type.
Feb 20, 2009 | Canon CanoScan N340P Flatbed Scanner
Zebex Z-3080 Handheld Logo
491 people viewed this question
Top Zebex Computers & Internet Experts
David Payne
David Payne
Are you a Zebex Computer and Internet Expert? Answer questions, earn points and help others
