Question about Dell Inspiron E1505 Notebook
Inspiron E1505 - Bad ethernet connection
I have a Dell Inspiron E1505 laptop. I was on the interent with my ethernet cord pluggin in to my Cox modem. Then I slightly dropped my laptop on the carpet (knee to the ground distance). So I restarted the laptop and the modem. Cox even sent me a technician to see if something was wrong with the modem. I was informed that something might be wrong with my laptop.
It seems as though my laptop doesn't even recognize if the ethernet cord is plugged in or not. I have no internet connection even though my bro has internet connection with the same ethernet cord plugged onto this.
Please help!!!
P.S. I was researching and read "Ethernet port??" on FixYa - that it might be a driver glitch. I was somewhat following the instructions and I do not see "ethernet or network controller in the device manager...
  • esy7
    esy7 Nov 01, 2008
    I don't see any lights blinking. So if do you think it might be the NIC card is loose?? Or???
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    when u plug the ethenet cord do u see two tiny lights blinking just below where the cord enters the comp?if not then there must be a problem ,maybe a loose contact..
  • 1,913 Answers
Right clik onmy network places chekc your lan card is enable?
if not enable it.
Posted on Nov 01, 2008
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
Im having ethernet problems with my inspiron E1505 dell laptop. after a reboot the computer no longer recognizes ethernet plugged into it. the cable has been tested and works fine. the drivers (Conexant...
Your ethernet card is not working and it seems to be damaged so if your laptop in under warranty so replace it free from the service center. Otherwise they will take charges for this replacement.
Ashish Kumar
Feb 02, 2010 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 charging port is bad
happened to me.... tech guy from dell came over, and temp. fixed it ... laptop is then no use with battery, i still always have to use the plug
Oct 21, 2009 | Dell Inspiron E1505 Notebook
Can not connect to wirless Dell 1525
Does it have awirless card or just an ethernet cable card?
Jul 28, 2009 | Dell Inspiron 1525 Notebook
Here are my recommendations for this issue:
1. Reseat the battery.
2. Remove All External Components
3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris.
4. Remove All External Components
5. Try a known-good battery in the system, if available.
Jun 09, 2009 | Dell Inspiron 6400 Notebook
I Cannot turn my laptop
Make sure that power cord is not connected. Reseat battery, plug in power cord, power on
Apr 24, 2009 | Dell Inspiron E1505 Notebook
Dell inspiron E1505 cannot connect to internet
A hardware error usualy indicated a bad network cable or a bad network card. Have you tried using a different Cable?
Mar 04, 2009 | Dell Inspiron 1501 Notebook
Network problems connecting to internet
Hi. If Dell is correct, then yes, it would be expensive. Your other alternative is to buy a PCMCIA Ethernet Card. They range from about $20 to $40. Or, you could go with what you suggested and do wireless via a wireless router.
May 21, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 Notebook Logo
356 people viewed this question
Alun Cox
