Question about Microsoft Xbox 360 Console
X-box 360 has blinking orange light on ac adapter and will not turn on.
  • 2 more comments
  • Anonymous Nov 29, 2008
    no. everything was working until i turned off the power source. i turned on the power source, and now it won't work
  • jstew3781 Jan 03, 2009
    the power ac addapter is pluged in, and the orange light is blinking and making a beaping noise. The other cord is pluged into the Xbox 360 but the power button won't work
  • blueblooblue Jan 16, 2009
    help me plz
  • Anonymous Feb 02, 2009
    is the orange light on the ac adapterfor the 360 suppose to turn green?
    my nneed for speed game keeps feezing up but every other game doesnt.
    its a new game i just got and it has noo scratches i think the two might be related can sum1 help?
    Problem Solver:
  • 17 Answers
Well then if the orange light does not turn on then you have not connected something the right way or thers something not plug in the right way ok
Posted on Nov 03, 2008
4 Suggested Answers
  • 5 Answers
SOURCE: AC Adapter has a blinking orange light...
Just cool down man, it is not so hard to fix it if you know exactly what happens and how to fix it. I had just fixed my XBOX AC adapter which turn the orange light on with the tips and tricks from http://www.unique-stuff.co.cc/fix_xbox_ac_adapter_problem.html
The complete listings of different light colors will easily indicate what problem your xbox console and ac adapter encounter. Hope it helps..
Posted on Jan 23, 2011
SOURCE: my xbox 360 won't turn on
I know what to do.... it happened to me, but I fixed it. Ok you will need a peperclip for this to work. Take off the faceplate of the 360. And then what should have been the powerbutton, use the paperclip to hit it. It should turn on, then you can put the faceplate back on.
Posted on Jun 28, 2008
  • 1525 Answers
SOURCE: blinking orange light
green light mean on
orange light means standby
red light means power failure
no light means the fuse my have blown
good luck
shaun
Posted on Jul 31, 2009
Battery light
Remove battery and try to power on the laptop.. If it powers on and boots up then the battery needs to be replaced.
Aug 18, 2013 | Dell Inspiron 5160...
No power battery flashes 4 orange
If it is orange or is blinking orange, the battery charge is low or expended. Remove the battery and re-install it. Plug in the AC adapter and connect it to an outlet. Turn on the computer.
When the battery status light blinks green and orange, the battery temperature is too hot for charging. Shut down the laptop, detach the AC adapter, and allow the laptop and battery to return to room temperature before attempting to charge the battery.
If the battery status light blinks orange rapidly, the battery itself may be defective.
Apr 08, 2012 | Dell Inspiron 5150 Notebook
I played like 30 min then i went out and when i came back home at the night i couldnt turn my xbox360 ellite on and the ac adapter was blinking orange!
It sounds like your power brink may have over heated or faulted. Please see this page for information.
http://xbox-360-problems-fix.blogspot.com/2007/11/xbox-indicator-lights.html
Aug 18, 2011 | Microsoft Xbox 360 Console
The light is flashing orange on adapter and no power to system when turned on
It is possible that there is some foreign particles inside one of the connectors. Since the power supply does come apart and also disconnects from the unit, you can try to clean it to see if it will sort out your problem. Here's what to try:
1. Disconnect the AC adapter from the wall and the console. Let it rest for a few hours so that you do not electrocute yourself.
2. Disconnect the wall power cord from the AC adapter brick. Check the connections on both ends to see if it needs to be cleaned.
3. Clean any ends of the adapter with alcohol solution (isopropyl, or "rubbing" alcohol). Make sure the connection to the console is clean as well. Allow to dry.
4. Reconnect all necessary parts and try your console again.
If that does not work, there could be another problem with power flow to the AC adapter or a problem with the adapter itself.
Feb 28, 2011 | Microsoft Xbox 360 Console
When my Xbox 360 is off, the light on the AC Adapter is orange, but when I hit the power button to turn the Xbox 360 on, the light on the AC Adapter turned red.
HI you did not mention is you are able to use the unit even tho the led turns red. If not then the unit is drawing to much current and the power supply is shutting down. Or the power supply is faulty, If you can and know someone with a 360 system try to borrow theirs and see which part of the system is faulty if you know his is good and the same thing happens, or take yours to his house and try, but if same results then the 360 is at fault.
Apr 21, 2010 | Microsoft Wireless Network Adapter Xbox...
The system does not turn on. i have checked the power cord and hard drive on another system and they are okay. any ideas?
Sounds to me like the main board is bad. Last step to try just to be sure. Try another AC Adapter on your 360 and if it still doesn't work then you know the main board is bad. Also try just plugging in your ac adapter and see if the green light goes away or if it turns orange. Those are sure signs that the main board is shorting out the ac adapter. Also hook up the 360 to another power outlet.
Nov 30, 2009 | Microsoft Xbox 360 Elite Console
X-Box 360 won't turn on
have to change the AC adapter and check your AMPERAGE that is also a problem with what doctors are very spoiled
Aug 22, 2009 | Microsoft Xbox 360 Console
Blinking orange light
green light mean on
good luck
shaun
Jul 31, 2009 | Microsoft Xbox 360 Console
Try moving everything to a different room on a different electrical circuit (as in electric panel outside your house). You might have too much load on that circuit for the plugs in that room. You could try unplugging everything except tv and xbox too.
Oct 29, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
779 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
