Question about Casa Vieja Probe White Ceiling Fan
Why does our two year old fan with light sometimes turns on by itself.
The ceiling fan will sometimes turn on by itself.
  • Anonymous Mar 17, 2014
    ceiling fan turns on by itself
  • 3 Answers
If it is not a timed operation then, the contacts are getting loose or misaligned.
Posted on Nov 10, 2008
Hardwired ceiling fan turned off by itself and stopped responding to remote control, but the light turns on/off.
I've had problems with Minka Aire also. You might need a new receiver. Call Minka @ 1-800-307-3267 and talk to someone in tech dept.. Should be a one year warranty on the receiver.
Aug 17, 2015 | Minka Lavery Minka Aire F888-BNW...
Why Ceiling Fan Fixture does not work
You get what you pay for! Shouldn't buy a store brand.
Jul 14, 2014 | Hunter 52" Ceiling Fan With Light And...
Sub-Zero 650 - Keeps turning itself off. The
HI,
Are you having any fault codes along with this issue? Does the fans and light stop working also? This is unusual, is this the G or O model? I need more information to assist you.
Please let me know.
Sep 08, 2013 | Sub-Zero 650 / O Bottom Freezer...
The fan sometimes turns itself off and then won't start for a while...it is controlled by a wall switch
there must be loose wiring in switch or in the fan you will need to check the wiring at these two points they may spark and start a fire, if they are all tight your switch may be going bad this atleast is an easy fix, good luck
Aug 27, 2011 | Hunter (25417) Ceiling Fan
Fan just quit working one day. Nothing happens when I turn the light switches on and off.
Is it powered thru a light switch? Sometimes those do just quit. You can remove the old switch & replace it. Go to Lowe's/Home Depot, the switch itself is fairly inexpensive (probably less than $5). Remember to turn off the breaker to that room/switch before you do anything. The installation itself is simple - just wire + to + and ground it. Did you notice any kind of noise/smell before it stopped working? If the motor is burnt out - just replace the whole fan (unless you feel like tinkering with breaking it down & finding a replacement motor). Sometimes the lite switch on the fan itself will go out - parts for that can be found at about any larger hardware store, but sometimes that's not an easy repair (depends on what type of lite kit is on the fan). However, if that were the problem -it would not cause the blades not to turn, it would only keep the lights from coming on. Try replacing the light switch that turns the fan on/off first (the one on the wall, not on the fan itself) - hopefully that'll solve it for you. Good Luck.
Jul 13, 2011 | Hunter Fan 21623 Concert Breeze Ceiling...
Fan pull chain broke off within the fan housing itself, cannot turn fan off. what is solution?
Typically, you have to disassemble and replace the switch, however, sometimes you can reconnect the chain inside of the housing, but before the switch.... Surgery is the only way to tell.
Jan 28, 2011 | Hunter Ceiling Fan Control Switch
I have a Hampton remote ceiling fan with lights.The Redington 11
the carbon of remote which help to connect the points of remote is not working so purchase the liquid carbon and put on the inner points on remorte buttons
then i feel it strt working.
Apr 29, 2010 | Universal Remote Control Hampton Bay...
Removing the ceiling mount from the ceiling of a hampton ceiling
Sometimes there is a small trim piece where the canopy meets the ceiling that "snaps" into place and rather than turning to unlock it needs to be gently pryed off. If you have a small trim piece that makes more than about 1/8 of a turn without unlocking. that is definately what you have.
Sep 06, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Casa Vieja Probe White Ceiling Fan Logo
589 people viewed this question
Top Casa Vieja Dryers Experts
tsalagi152
Stan Ford
Tom Chichester
Are you a Casa Vieja Dryer Expert? Answer questions, earn points and help others
