I have a DVD player for tv and i have st it up as the manual stated to do. now it says no disc. The player is a CiTECH Compact DVD player with Progressive scan Model # is T201 DVD
3 Suggested Answers
premtech
  • 934 Answers
SOURCE: Red lines when watching DVD
Regardless of what inputs you use when the lines appear, that symptom suggests that the Proscan Module Samsung p/n#BP95-00140T is probably defective. That board is a plug and play replacement but there are no short-cuts to testing it to be certain that's the problem or the entire problem. That said, the top of the metal shield lifts off and the board can be pulled with no greater skill than a first year technician. The board is $184.25 plus shipping from Vance Baldwin - so if you're feeling lucky you could try this one yourself... Just be careful. If you have ANY questions drop me a note at premtech@willapabay.org and include the model number. Hope this helps Bill Good luck
Posted on Jun 05, 2007
  • 7 Answers
SOURCE: Hi, where can I download
I have CiTECH T201DVD user manual.
It looks exactly like this thing here.
http://citizen-electronics.com/citizen/en/product/view/20285
I think it is the same thing essentially, just under different brand names.
They do have the same 1-800 number anyway.
If you won't find something particular in there, I might scan a page or two from mine if you want.
Posted on Jul 22, 2011
My nx501 says invalid disc when I put a cd in I
Clarion NX501 Owner Manual Installation Manualit looks like this is mainly a dvd player,it does play disks with mp3's and wma files but,not compact disc files,read the manual,try a recorded cd with mp3s,
DVD Player System
Digital Versatile Disc System with CDDA capable
Usable discs:
DVD video disc, Compact disc
Frequency Response: 20 Hz to 20 kHz
Sound/Noise Ratio: 95 dbA (1W Ref)
Dynamic Range: 95 dB (1 kHz)
Distortion: 0.05%
Video system: NTSC/PAL
May 22, 2015 | Televison & Video
I need a manuel for my RSQ-MV-333, where can I get one?
Retrevo has the manual for the RSQ MV-333 here: http://www.retrevo.com/support/RSQ-MV333-DVD-Players-manual/id/8203ag317/t/2/ . You will need to enter a code to download the file; then use Adobe Reader or a similar program to read the manual.
The unit can play compact discs with digital video, compact discs with digital video and playback control, CD-G (compact disc - Graphic) and audio CDs (finalized CD-A discs, not MP3s or open CDs made on your computer).
I hope this helps.
Dec 20, 2012 | Cars & Trucks
I can get the home page up on the tv where it says cyberhome. i put disc in and it says loading and then it says bad disc. what does a bad disc mean?
Assuming the player is fine, the 'Bad Disc' display message usually means either a disc which is an incompatible format (for example DVD-ROM) with this player; a disc which is a region that does not match that of the unit; or a defective/damaged disc. Check the discs prior to using them in this player and if they are burned discs, make sure they are a compatible standard format for playback.
This model is not region-free by default unless stated otherwise in the manual.
Apr 16, 2011 | Cyberhome CH-DVD 300 DVD Player
Hi, where can I download user manual for " Citech T201 dvd player "?? (canada) Thank You
Dec 11, 2010 | Televison & Video
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
*or*
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
http://www.retrevo.com/support/RCA-CDRW121-CD-Players-manual/id/19240bh946/t/2/
Feb 23, 2009 | RCA CDRW120 2-Disc CD Recorder
DMR ES15 computer burnt dvd will not read
Place the disc back in the computer, open the program that burned the disk and finalize the disc, once finalized it should work in any dvr
Feb 16, 2009 | Panasonic DMRES15 DVD Recorder
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
NO DISC
I bought a Dora DVD player for my daughter in March 2007. On November 2007 I inserted a disc into the player. It spun and stated there was no disc on the tv in the upper left hand corner. I tried 2 other DVDs and the same thing happened. I unplugged everything temporarily and plugged it back in and no improvements???
Apr 10, 2008 | Emerson Dora The Explorer DVD Player
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
