Question about Palm Tungsten E Handheld
Tungsten E will not get past Tungsten screen to sync.
I have tried soft reboot, hard reboot, even letting the battery run down before recharging, but nothing seems to help. My unit goes to the Tungsten screen and stops. No button works and it will not shut off with the power switch.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
Hate to say this but, back it up and toss it.
Posted on Dec 29, 2008
Palm tungsten t5 won't boot past the Palm Powered
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your T5, so only do it if you have to. Hold the Power Button while you push the reset button. Continue with the instructions to finish erasing your device.
Feb 17, 2010 | Palm Tungsten T5 Handheld
My Palm Tungsten E2 does not turn on.
Have you tried doing a soft reset? To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the back panel of your handheld.
Jan 09, 2008 | Palm Tungsten E2 Handheld
Tungsten t5 : Won't power on, despite change of a rechargeable battery, soft reset, trial of hard reset. Any suggestion ? Shall I throw this device away ?
It might just be that the battery is shot and you need to replace just it, I would try that before you throw it away
May 25, 2009 | Palm Tungsten T5 Handheld
Fatal alert
This is a common problem with the Tungsten line, You can try doing a hard reset. This worked for my E2. If that doesn't work, the battery must be removed for a few hours. Although it still may not work after the battery removal.
** To preform a hard reset, hold down the power button, and push the reset button on the back of the unit. The top of your stylus unscrews to expose a "plastic pin" for this purpose. Keep holding down the reset button while the unit reboots. You should see a palm screen displayed while it restarts, let go of the power button and follow the instructions. Pressing up on the pad ring should erase all data.
Feb 20, 2009 | Palm Tungsten T5 - Multilingual Handheld
Tmobile wing frozen
Turn off your mobile and then pull out the storage card, Restart your device, it should work now !!!
Jan 10, 2009 | T-Mobile Wing™ Smartphone
Palm Tungsten E2
The top digitizer is defective and needs to be replaced.
You can find digitizer parts in ebay or other on-line companies, at reasonable prices.
Regarding the labor cost, depending of the repair shop you choose, it may be cheap or expensive.
Also, if you have minimum experience and skills in fixing electronics, you can try it. really is not so difficult, and minimum set of tools are needed for it
Best regards,
Sep 26, 2008 | Palm Tungsten E2 Handheld
My e2 frozen on the palm powered logo
Okay here it goes, your going to want to leave it on for however many hours it takes to completely drain the battery then you're going to want to recharge it back to normal charge, and try restarting it again. This will delete completely anything that is keeping it from restarting properly. If you did open up the machine without following "antistatic procedure" you may have fried a component on the board and then your in trouble
you'll need to salvage a board from another tungsten and put it back in your PDA and hope you put it back together right
May 28, 2008 | Palm Tungsten E2 Handheld
Tungston E
Battery. You need a new battery. Also could be the hard drive in the device
Feb 13, 2008 | Palm Tungsten E Handheld
HP rx3115 hard reset
Had the same problem with my hp rx3115 . Worked fine, then the next day dead. power button, lower buttons, or outter reset button didn't work to turn it on. Okay so, i thought it just needed to recharge. Used computer cable for active synchronizing that also recharges, still dead. Then cable just for recharging. Finally comes on. Charged it all the way up, synchronized it, unplugged it, few minutes......dead. The battery is no good.
Nov 16, 2007 | HP iPAQ RX3115 Pocket PC
Palm Tungsten E Handheld Logo
156 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
