Question about Dayton Gas Furnace Heater
Dayton blower fan repeatedly kicks on and off
Hi folks.
I've got a Dayton gas furnace.
Model # FG8D12520MU12A.
The fan kicks on... runs for a bit and then kicks off.
This pattern repeats.
When I run with the heat on, I get a fan-limit switch error code on the
control board.
When I run it in fan-only mode, the fan kicks on for about a minute or lses, then keeps cycling... kicks off ..... kicks on for a few seconds.... kicks off...
Any suggestions regarding this problem?
thanks in advance
  • 1 more comment
  • Anonymous Jan 07, 2009
    My Dayton furnace fan will constantly kick on and off on and off. on for 10 off for 5 on for 10 off for 5.
  • sasyko Jan 18, 2009
    where is the fan limit switch? mine is doing the same thing..
  • Anonymous Jan 19, 2009
    I have the exact same problem on a Dayton model 3E837 but can't find a replacement part for the limit switch
  • Dayton Master
  • 3,238 Answers
Chech the air filter is clean and the fan limit switch look to change fan limit
Posted on Dec 11, 2008
Trouble shoot Dayton gas furnace model GG9S100C16MP11A fan is left on constant but in cold weather 10 or colder fan will go off and furnace will go thru a restart mode and run fine for awhile then will do...
Do not run contentiously during heat mode. the fan runs at a slower speed with heat and heat fires first then the fan cycles on during heat cycle then when heat satisfies the thermostat the heat will cycle off and fan will run for a couple more minutes and then cycle off. So set stat on fan cycle to auto.
Feb 03, 2015 | Dayton Gas Furnace Heater
Furnace fan runs costantly
Check to see if fan setting is summer or winter.
Feb 05, 2012 | Dayton Gas Furnace Heater
Furnace will kick on, begin heat up, go to the point where the fan should start and the whole thing shut down. If I move the thermostat down below the temp it show, it will start again and do the same...
Sounds like the blower motor is bad and then the unit is kicking off on high limit....
Probably nothing you can do with out getting a new motor to replace the bad one...
heatman101
Feb 02, 2011 | Dayton Gas Furnace Heater
The pole buiding 24 in hanging Dayton sometimes the blower comes on like after 5 minutes after everything else kicks in and sometimes like when its supposed to and sometimes not at all?? All the electric...
I'm not sure whether this is a gas unit or not. With many gas heaters, the blower comes on when the heat exchanger gets hot enough and goes off once the heat exchanger cools. Other things are happening before the blower goes on. The blower is normally controlled by a "fan control thermostat". This stat actuates the blower when the furnace is hot enough so that cold air is not being blown around and allows the blower to run until the furnace cools enough to get out the remaining heat after the flame shuts off but not so long to again allow cool air to blow around. If this fan control is malfunctioning, you will get erratic runs from the blower or the blower may not run at all or run long or continuously. The fan control is the first thing to check.
Gary
Jan 31, 2011 | Dayton Gas Furnace Heater
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
My furnace kicks on, runs a little while, kicks off, then kicks on again until desired temperature is reached
it could be the thermostat on the wall not working or the fan control is not working as it should also check to see if air filter is blocked
Oct 24, 2010 | Dayton Gas Furnace Heater
Dayton Gas Furnace - Blower will not shut off
Try national energy they are on line and carry most spares
Apr 06, 2017 | Dayton Gas Furnace Heater
How to make the fan run only.
Inside the furnace there should be a switch that says on/auto to run the blower constantly flip it to on.
Jun 07, 2008 | Dayton Gas Furnace Heater
Dayton Gas Furnace Heater Logo
924 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
