Question about GE 19GT317 19" TV
White lines and gray tint
My tv was working fine until I moved it across the room and now these horizontal white lines show up on the tv and it has a bright white tint to it. I tried messing with the screen options but that didnt work. The sound does work and you can sort of see the screen behind the tint.
You should go to partiya.com. All the informatioin is found there.
Posted on Sep 21, 2006
    Novelist:
    Champion:
  • 275 Answers
Buddy, While shifting your you have accidently disturbed the Screen voltage. Bring down the Brightness and Contrast levels to 50% and then adjust 'Screen' adjustment at the rear of your TV till the screen is almost dark.
    Sergeant:
  • 337 Answers
Some tv's have the focus and screen controls exposed in the back,maybe when you moved the set you missadjusted the screen control if that is the case all you need to do is move the lower control to the left slowly and the lines should go away as well as the tint.This is done thru the back with the cover on it,not need to remove cover if the controls are exposed.If the controls are not exposed the set needs service.
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
Tip
If Your screen shows a: white vertical line on a black screen or, a white...
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, carefully using your finger find the too hot transistor or, chip; or, use component coolant; spray the too hot component with a component cooler repower the TV, until the screen comes back to normal. To fix: apply white sylicone coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Garden
Tip
TV shows either: black screen with: white vertical or, horizontal line
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
White horizontal lines covering picture on Toshiba 51HC85
The set uses a Hyper board inside that processes all signals, it is well known for this issue, board no longer available=reason is quite simple : about a dozen tiny surface mounted filter caps on that board with age dry out, at first it will work after warms up as poor caps regain some capacitance and seem to be ok.
Buy a new set, you can send that board out and have it repaired/rebuilt but the last one I saw which was under extended warranty cost about 200 just for the board rebuild.
In the last 4 years Here on Fixya I have encountered only 2 people who were able with instructions had the skill to remove the board and replace those caps, both were top notch computer repair techs.
Dec 09, 2012 | Televison & Video
Thin white horizontal lines!!! I've had my WEGA KE-42M1 for 5 years with no problems until about three months ago. After about an hour being on, there are thin white horizontal lines that move randomly...
Sounds like your TV is giving out, plain and simple.
If this doesn't sound right, then only one thing comes to mind. Have you moved the TV recently? Are you using a different coax cable, (if using cable that is). If so, just change the cable back to the previous one and you should be fine.
Aug 21, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
RCA-single horizontal white line
Your vertical deflection IC is bad.
Nov 04, 2008 | Televison & Video
Tv shows a white horizontal line and then shuts off
for sure the tube is bad be better off buying a new tv or find someone that has a tv repair shop
Oct 07, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Thin horizontal line across picture
I really dont understand the problem Could we see a picture of this please?
Jun 14, 2006 | Toshiba 35A44 35" TV
GE 19GT317 19" TV Logo
139 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
