Question about Philips Televison & Video
Philips 42pf7320a37 Plasma TV. Menu appears without being requested remotely or manually. Must select Menu Remotely (or manually) to regain screen. Screen stays on for a few seconds or up to 20 minutes. If it is a chip resposible for this can I tie a pin hi (or lo) to resolve this. (I never used the menu since installation)
  • ronasta Nov 03, 2008
    Problem was small (control ?) board that remote sensor connected to. Removed ribbon cable from board and problem resolved. Resoldered suspected cold solder joints on some resistors adjacent to IC, reconnected ribbon cable and all is well. Board is mounted on frame surrounds plasma screen, this frame had numerous broken plastic supports and was loose, perhaps moving tv at some point twisted frame put stress on board.
    Problem was cold solder joints on small board that remote sensor connects to.
    Genius:
  • 1,913 Answers
    Scholar:
  • 155 Answers
First shut off the tv then remove all the power wires connected to the tv externally.also remove the power wire connected to the electric outlet.
wait for a minute then try again without operating remote.and check it.
Posted on Nov 01, 2008
  • Philips Master
  • 19,396 Answers
Check that this is not caused from a stuck button, or a defective remote recalling the menu.
If it is not the remote, then you will probably need to replace the control board or the button assembly.
  • Ginko
    Ginko Nov 03, 2008
    That board connected to remote is the TV remote control decoder, on many TVs this is integrated with the control board, that is the one with the button switches.
    Glad to know that you fixed it.
Sound goes up all the way and no controll
Remote Control volume UP could be sticking inside the remote itself. Remove batteries and manually turn TV on and see if sound works ok.
Jul 09, 2014 | AOC L32W961 32 in. TV
How do I find the password for my AOC TV?
You might need to do a hardware reset if somebody programmed a password into your TV. This will erase all settings and set it back to the factory defaults.
Try this:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
May 19, 2014 | AOC Televison & Video
Factory reset menu lcd
Try this:
Jan 14, 2014 | AOC l32w781a
Reset button
Try this:
Jan 14, 2014 | AOC L24H898 24 in. LCD TV
Reset button
Try this:
Aug 31, 2013 | AOC L32W861 32 in. LCD TV
HI MY PHILIPS 25INCH TUBE T.V ONLY GOES FROM CHANNELS 2 TO 42
Either press menu on the Philips remote and go to autoprogram, or (if you have lost the remote), press volume - and channel - at the same time. When menu appears, use channel - to select autoprogram and volume - to select it.
-Tha Mp3 Doctor
Dec 31, 2008 | Philips TS2546C 25" TV
No menu access without remote
the channel selection buttons are supposed to pressed at the same time. the menu page will appear on your screen, use your volume for moving the pointer. entering using one of the volume button. thanks
Dec 28, 2008 | Philips 27PT543S 27" TV
42" phillips plasma
Hi There, Let's try to isolate the problem. Remove the battery from the remote control. With the battery removed from the remote control, let me know if the menu still appears. Thanks, Mike
Nov 04, 2008 | Philips 42PFL5603D 42 in. LCD HDTV
Tuning a Channel
why did it get the highest raiting?? it doesent even say a solution
Sep 23, 2007 | Philips 30PW633R 32" TV
Televison & Video Logo
156 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
