Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Red color is missing - everything is green
The color red is misssing - what needs to be done to fix the problem. How expensive is it? What should I do with the TV - it is only five years old?
  • ssanders012 Dec 03, 2008
    I have no gray, and green is in its place in the center
    Novelist:
  • 135 Answers
You will need the optical block replaced. Approximately $1000 or so plus around $400 labor and taxes. Visit Sony's website to see if they are still honoring the extended warranty for the optical block issue. They know it as a green tint complaint. The menus will also be affected if you have the problem.
If the issue is no longer covered, try negotiating a shared cost repair.
Posted on Nov 09, 2008
Sont Projection Tv colors
Your red tube is weak or defective. If weak, gain can be adjusted up on the red tube.(cheapest cost) If red tube circuit is defective that will have to be fixed by a technician.(cost between $100 to $200) If tube is worn out, it will have to be replaced(250 to 500). Any work should be done by a qualified tech. Prices will vary depending on your area.
If set is over 5 years old, I recommend replacement.
Mar 13, 2014 | Televison & Video
Blue colors are bright green
This model did have problems with : missing color (red,green or blue) and other issues like inverted picture-----it may need the main cpu reprogrammed which is done with a jig and two sd cards loaded into the set that way.
Oct 29, 2012 | JVC HD-61Z575 61" Rear Projection...
There's a green hue over everything
One of your other color tubes( blue or red ), is blown. The green saturation you are seeing is beacuse you are missing a color to complete the picture. Rear projection t.v.'s are pretty cheap to fix with this problem. Just contact a t.v. repairman.
Dec 17, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
No sound on play back using camcorder on technika tv
Looks like you are using Component cables. There are five cables. The first three cables are Green,Blue and Red. These are the ones that are molded next to each other and are the Video signal cables. The other two cables are Red and White and they are the audio cables.
First to correctly hook up these cables you need to Connect (Match) Color for Color. (Green to Green, Blue to Blue, and Red to Red. To tell if you have correctly connected the Video cables is to look at the screen. If the picture looks ok (Normal with no colors missing then you have connected the video cables correctly). If you see a missing color meaning red, then switch the Red cables. The picture should be ok now. The remaining two cables are the Red and White cables. The "Red cable" is for the "Right" audio input and the "White" cable is for the "Left" audio Input". If all is connected correctly then you should have a good picture and Left and Right audio.
Jul 05, 2009 | Televison & Video
Marantz PV-5580W Color Problem, Missing Red?
I have the same model however my screen is red w/ green lines. Did you find a fix to the problem?
Jun 30, 2008 | Marantz PV-5580W 55 in. Rear Projection...
Dark picture
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 13, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Help.. LCD colors
Reconnect your cables!  Somehow you don't have red and green in there, just shades of blue, right?  And it doesn't depend on whether you're running a browser or something else?
Make sure everything's tight and if you can (but only if tightening cables didn't work,) check that your computer's putting out a normal signal by testing another monitor with that computer.
Nov 11, 2007 | ViewSonic VA520 15" Flat Panel LCD Monitor
Missing colors on screen
if you have H/D one of your cables might be loose red/green/blue  i suspact red
Oct 21, 2007 | Toshiba 32WLT58 32 in. LCD Television
Hitachi 52 projection tv
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
121 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
