Question about Whirlpool Washing Machines
Blowing fuses put new timer in and now it blows the fuse
  • 93 Answers
Find your wire diagram it sould show you how connections go on the timer
Posted on Nov 01, 2008
My Whirlpool microwave MT6120XEB-0 keeps blowing the fuse. Inststalled new fuse and display and timer works. Cooking blows new fuse. It turns on, makes grinding sound and blows a new fuse within a second...
You almost certainly have a shorted high voltage capacitor.
See the safety warnings and help information here.
Chances are you will have to remove the oven from the wall to replace it.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 26, 2013 | Microwave Ovens
1993 grand prix.blows brake light fuse when u apply brakes
hot wire touching metal fuse blows so you don't burn up the wiring get it tested and fixed soon could be dangerous to keep putting in a new fuse
Jun 24, 2013 | 1993 Pontiac Grand Prix
1999 ford escort wagon my brake light fuse blows everytime i put one in
remove your tail light bulbs than put in a new fuse if it does not blow it is a bulb socket put one bulb back in check the fuse if it blows remove bulb. than put bulb in other socket if it doesnt blow with new fuse you will know what socket to replace. if this was helpful please leave feedback
Apr 12, 2013 | 1994 Ford Escort
Mazda 626 ac fuse keeps blowing
Try unplugging the compressor then put in a new fuse. If the fuse does not blow, the problem may be the clutch on the compressor.
Jul 29, 2012 | 1997 Mazda 626
01 kia rio keeps blowing the injector fuse every time i put it in first and take off how do i fix it
You may have a shortted injector. Pull all the injector connections off, put a new fuse in. If it still blows the fuse, you must have a short in the injector drive circuit from the ignition switch to the injectors. I don't know what all is in the circuit, but you may have a resistor pack before the current reaches the injectors
If the fuse did not blow, then one at a time, reconnect the injectors. You are looking for a shorted injector that blows the fuse. If the first connection blew the fuse, disconnect that one, put in a new fuse, and start with a different injector connector. You may find one that blows the fuse, meaning it is shorted, and needs replacing.
Good luck.
Apr 08, 2012 | 2001 Kia Rio
Blowing fuze on f350 diesel for glow plugs
Most likely you have a shorted glow plug. First unplug all 8 leads and energize the start cycle which activates the timer box. If you blow a fuse now its the timer box thats shorted.
Then connect 1 or 2 leads at a time until you blow the fuse. You can unplug 1 of the last 2 to isolate the bad glowplug. Using the wire leads will keep you from having to remove every glowplug from the heads.
Check your ground wires to the timer box because the timer only cycles for the initial start. Also as the weather gets colder the timer can work longer but not indefinitely. That can be another reason for the fuse to blow.
Dec 20, 2009 | 1992 Ford F350
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
Fuse blowing
Your exhaust vent is blocked.
Timed dry is High heat.
Permanent press is a medium heat and intermittent.
The dryer does not get as hot as often in Permanent press mode. Therefore the fuse does not reach critacal and blow.
Remove the vent at the rear of the dryer and run a timed load.
If it dries correctly, repair your vent blockage.
If not, repost and I will lead you to the next step.
Feb 19, 2009 | Kenmore Dryers
Blowing 30 amp engine control fuse.
You say it eventually allows you to put new fuse in, do you mean when it sits for a while, a new fuse won't blow, but if it blows and you immediately replace it, it blows again instantly?
Sep 05, 2008 | 1997 Dodge Ram 1500 Club Cab
Epson 7300
Hi there
The Epson Powerlite 7300's lamp has got a chip on the side of the lamp's bracket that resets the lamp timer automatically when a new lamp is inserted. And it only does it once - first time the unit is switched on after replacing with a new lamp.
The fuse on this chip blows and causes the lamp timer to be reset. Unfortunatelly this is the only way to reset the lamp timer on this model. There is no manual way.
So to cutt to the chase , you will have to buy the original lamp and replace it before it will reset.
Part Number is : ELPLP05
Apr 17, 2008 | Office Equipment & Supplies
Washing Machines Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal De
