Question about RCA HD52W59 HDTV Projection Television
HD52W59 (ITC222) Switches Screen Format
I have an HD52W59 (ITC222 chassis) and it stays in 4:3 format. I am using a antenna to receive digital signal.
However, the PBS channels are in Cinerama format, while all the main channels (ABC, NBC, FOX, CBS) are all in 4:3 format. I hit the "Format" button on the remote, and it shows the "4:3" format on the top left of the screen, but disappears right away. The only time I can see the "4:3" displayed in the top left corner is when I change channels and hit the "Format" button right away. Otherwise, it does nothing.
I did want to mention that I re-soldered the solder joints on the flyback transformer and replaced the FL231 fusible link because of convergence/pincushion issues. However, as I was trying to remove the deflection board, I could not figure out how to remove the two ribbons from the board (connects to SSB) and tugged on the ribbons by accident. None of the pins were removed from the connector, but I am wondering if it was enough to cause the pins to wiggle loose from the connector.
Any help is much appreciated!
SOURCE:
  • 3 Answers
SOURCE: fusible link keeps blowing out , shutting tv off
Arynsunn,
Thanks to you, I was able to find the solution to my problem.
Have you tried using the correct Fusible Link? I noticed in another post that you said you replaced it with a 500ma instead of the 400ma. I had the same original problem as you and found the exact fuseible links at www.mouser.com. Part# 576-3960400000 Littelfuse Fuses - A 125V UL TL LL .400A . They are only 55 cents plus shipping. I bought 5 for under $10 shipped. Only took 2 days to get them. My TV works like a charm now! I too thought I may need to replace the IC's but thankfully my TV is working fine. If you did need to replace them, where were they located? I couldn't find any stk IC's inside either and the IC's on the heat sinks are all small. Just trying to be proactive, in case I ever need to replace them.
Posted on Feb 01, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Posted on Sep 11, 2008
ladywinn
  • 5138 Answers
SOURCE: Red and Green flicker after replacing FL231
Go to the R/G CRT boards at end of neck of picture tubes resolder socket pinns and Video ICs on the board.
Posted on Feb 16, 2009
tvtek
  • 1284 Answers
SOURCE: how do I replace the FL231 fuse on the circuit
Yes, but before powering the set back on you must fix the original issue that caused it to open. The high voltage transformer location LL008 will need to be un-soldered and all pins and pads cleaned. Then re solder the pins to the pads with solder. The original solder was lead free but it tended to crack after it heated up thus causing the intermittent connection and then opening the 400ma fuse to the convergence panel. The fuse is no longer available, but I have included a link to be able to purchase it on ebay. Make sure you ONLY use the size fuse needed as anything higher could be a fire hazard. Please take a moment to rate my answer. Thanks...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=220478092023
Posted on Nov 24, 2009
  • 69 Answers
SOURCE: We just purchased an Samsung Plasma model #PN50B1D
unfortunately these newer tvs do not display the standard definition analog channels very well. the picture gets better when viewing digital channels but doesnt display at its best untill u place it on a high definition channel
Posted on Feb 07, 2010
We bought our TV in Australia but are now living in new Zealand our TV comes up with invalid format to have tried returning but we get sound no picture. Will this mean it won't go in new Zealand.
The TV may be too old even if it is a digital TV set. NZ terrestrial DTV broadcasts in MPEG-4 format, and a lot of Aussie digital TVs won't receive this. A Freeview digital set top box should solve this problem, and be cheap.
Dec 06, 2016 | Miscellaneous
Set up installing antenna, tried Ant A & Ant B no receptiom what do I do?
The first question you have to answer is whether your TV is capable of receiving digital broadcasts. TV stations no longer broadcast the "old analog" signals, but now transmit only in digital format. If your TV is not capable of receiving digital broadcasts, you will need to buy a special box which allows you to receive digital broadcasts. Then you would hook it up in the order: antenna -> digital box -> TV.
If your TV is capable of receiving digital broadcasts, I've found that it is very important that your antenna have a pretty much unobstructed view of the direction from which the signal is coming. For instance, if your local signals are broadcast from the southerly direction, you should try to mount your antenna to a window which is facing south.
One last point before I forget, you must make sure that you select the proper input on your tv. For instance, I have cable, and a dvd player hooked up to my tv. Before I use the dvd, I have to go into the TV menu and select my dvd. When I want to return back to cable, I have to go back into the TV menu and select the cable input.
Jun 07, 2015 | Televison & Video
Have rca hd52w59 that has mind of its own. Turns volume down but not up. Turns TV on but not off. Flashes menu screen on and off. Screen formats changes, etc etc. Is the TV shot or is there a relative easy...
Thats a very common problem with that model which is caused by the small signal board needing replacement. Several version of small signal boards were used in that chassis but the people at www.tvrepairworld.com have replacement signal boards and will help you determine which version you require for your specific version if your not sure.
Jan 04, 2012 | RCA HD52W59 HDTV Projection Television
This area has just changed to digital and could not get bbc 1 and 2. I GOT CHANNEL4 AND 5 BUT AFTER FIDDLING NOW GET NO SIGNAL AT ALL.
I am assuming that you are in the UK....
UK or across the pond here in the States, clear digital signals are sometimes harder to receive than the old format.
If you are using an indoor antenna, I would recommend an outdoor one.
If that is not possible you may want to take a look at an upgraded indoor antenna with a signal booster.
Jun 09, 2011 | Televison & Video
RCA HD52W59 HDTV Plug in digital antenna into air antenna input then run channel scan =0 channels What should I do next??? Mike
Make sure you are connecting the digital antenna to the digital antenna input on the back of the set, then rescan. Most over the air Tv signals migrated to digital transmission and therefore the analog input is mostly for older analog devices. If you still do not get any channels, then you need to make sure the antenna you are using is rated for reception in your area. You can check for proper antenna size and channels available here,http://www.antennaweb.org/aw/welcome.aspx
Feb 08, 2011 | RCA HD52W59 HDTV Projection Television
All ready used box once. Now going back to antenna. Not receiving display or menu on T.V. screen.
All TV over the air is transmitted as a digital signal now. In order to see it on an older TV (read Analog), you must have a signal that you can receive(antenna hook up) and a digital to analog converter box. That box allows you to see your digital signal on older TVs. The signal is sent from the antenna to the box via a RF connection, and decoded to channel 3 or 4 (your choice). for further information see Consumer Report at:
http://www.consumerreports.org/cro/electronics-computers/tvs-services/non-digital-tvs/digital-converter-boxes/digital-tv-converter-boxes-first-look-3-08/overview/digital-tv-converter-boxes-first-look.htm
Jan 09, 2011 | Insignia Digital-to-Analog Converter for...
The inputs on my RCA scenium dlp tv wont work.
It sounds like your talking about the ITC222 chassis series which is having a small signal board problem. Very common in the RCA ITC222 and ITC222A Chassis HDTV's
Jul 12, 2010 | RCA Televison & Video
Picture format
The HD reciever shouldn't be the problem.
If you recieve an image with a 4:3 aspect ratio, the image will be displayed at that ratio on your HDTV unless you specify otherwise. To do so go to your TV's Setup screen
setup
Choose picture formats
select smooth wide as your default
***Some digital (ATSC format) stations may transmit 4:3 images in a way that will not allow expansion. You will be unable to adjust the picture format.
Hope this helps!!!
J
Nov 17, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Receive one channel with Coverter Box
Make sure those 6 channels are also being broadcast in Digital format also, otherwise your converter box won't have a digital signal to convert for your TV. The switchover date is early next year I believe.
Oct 10, 2008 | Zenith C27A24T 27" TV
RCA HD52W59 HDTV Projection Television Logo
70 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
