Mitsubishi VS-50605 50" Rear Projection Television Logo
Chris Forsee Posted on Sep 21, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi VS-50VA1 I have a Mitsubishi big screen Model VS-50VA1. My 4 yr old was punching buttons on the TV control panel itself and now the only thing that can be watched on the screen is DVD. You are no longer able to change the input selection. On the top of the screen, the words "TUNER OUT" appear. I don't have the original remote or the owner's manual (nor can I seem to find one anywhere) and nothing that I do seems to do a thing. I was hoping that someone would have some input as to a solution. Thanks
Anonymous
Level 3:
President:
  • Master 3,130 Answers
  • Posted on Sep 21, 2006
Anonymous
Master
Level 3:
President:
Answers
3130
Questions
5
Helped
1649961
Points
8439
Go to http://www.remotes.com enter in the TV model number, and order it, as there is nothing that can be done in a case like this. You could try to borrow a remote from a local store to switch the set back to the tuner section or borrow an original remote from someone.
1helpful
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
Resetting the parental controls
I can help you unlock your Mitsubishi HDTV VChip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
5helpful
2answers
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CK-35402, CS-40FX1
manufacturer.
personal code.
2answers
Need internal parts for mitsubishi projection tv for 1993 model #VS-50VA1
post your model number and what parts you are looking for I may be able to help you get them
50" MITSUBISHI BIG SCREEN (MODEL#VS-5076,
INITIALIZE THE SYSTEM CONTROL. WITH THE REMOTE CONTROL PRESS "MENU 2, 3, 5, 8, " USE THE ADJUST BUTTON TO SELECT "INITIAL" AND PRESS "ENTER"
Fluttering and picture discoloration
model # VS-60607 Mfg Yr February 2000 Big Screen TV:
1.  tearing/fluttering/ripping across entire screen caused by damages associated with diode 522, and;
2.  the problem is really an OEM Mitsubishi causation as the
leads of said diode get too hot <too much current flowing through
it> and this component lifts itself off of the main circuit board, &;
3.  supplemental hidden damages arise from this, and;
4.  you should not attempt to fix this set but rather contact the
national & state Consumer Protection staff & file a complaint, &;
5.  pleadings should say:
    a.  this set almost burned down our/my home & us to death;
    b.  we paid too much money for this to happen, and;
    c.  we demand full replacement of the set & money for our
         inconvenience for all of the above, and;
    d.  said replacement need not be a Mitsubishi but like unit;
6.  check with Martindale-Hubble to find a good law firm/lawyer.
7.  have fun, eh!
Mitsubishi VS-50VA1 schematics or resistor ID
Perform PIP bypass (must give up PIP function) 1)remove PIP module,leave out. 2)Install 22mf/50v NP caps on bottom of PCB. Mount cap to VP pins 5 to 11. " " " " " 7 to 9. Re-check video=should be clean.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
