Question about Freeplay Energy Summit AM/FM/SW Radio
Locked radio? I have a freeplay radio, and only have a manual i downloaded on the internet. The radio seems to be locked. The time flashes, and keeps (the wrong) time. And the light works. That's it. Is there a way I can re-set it? Is it an unfixable fault? Help! I'm moving to mozambique in 5 days and would like to take the radio with me!!
I h ad the same problem which I took of the two black plastic caps removed the five screws which splits the radio in two pieces. Just follow the leads from the battery and disconnect the plug on the board until you lose the display then put every thing back together and reproggram it again.
Mike
Posted on Nov 08, 2007
SOURCE:
Please wait keeps flashing on the screen and the clock loses time
OEM radio issues. Flashing Time. Radio Not Working... - Drive ...
www.driveaccord.net/.../51717-oem-radio-issues-flashing-time-radio-not...
Sep 20, 2010 - When I reconnected the battery, the radio does not work anymore. ... I reconnected it, turned the key and the clock is still flashing. ... Wait about three minutes or so, and reinstall the fuse. .... Please let us know what it was. .... Naviscreen comes up but I can't do anything with it because the buttons are dead.
Novelty Simpson Jukebox Alarm Clock Radio Homer ... - Fixya
www.fixya.com/search/p94498-novelty...clock/welcome_please_wait
Novelty Simpson Jukebox Alarm Clock Radio Homer Simpson Animated Jukebox Alarm ... ...welcome Please Wait" Every time I try to use any handset the screendisplays ... This keeps flashing for several minutes, and never seems to resolve.
Troubleshooting - Shop - SiriusXM Radio
Jan 16, 2016 | Audio Players & Recorders
It says 'lock' on the screen and does not operate at all. How do you unlock?
hi,
This can happen if the Hold or Lock switch is in ON position. Watch is there is any Hold or Lock switch at any side of of your radio. If found then just slide it to off position. If the Hold or Lock button is in ON position it will deactivate all the other switches.
ok
Jun 16, 2011 | Freeplay Energy AD022 FM Radio
When turning the crank, the spring slips, and the crank flies back to original position. Spring will not wind up.
One day while cranking the freeplay PLUS Radio on a job site with no power, something inside snapped, and made a horrid grinding noise. All of my co - workers laughed. From then on I only used the radio with the AC plug in adapter.
After 8 years of keeping the freeplay plugged in to listen to it I finally decided to open it up and take a look.
Low, and behold I found some broken pieces that looked like a belt. HMMM?
After a little more investigating I found the 2 drive wheels that power the generator... with no belt on them. I looked in my junk drawer, and found a small blue rubber band amongst the others that I save from packaging items. It looked suitable to do the task. After stretching it around the generator drive wheels, I cranked it up, and IT WORKED!
I'm still waiting to see how long this fix works, but in a pinch... keep some rubber bands and a phillips head screwdriver around. This may be the same problem your having. I'm now getting the long lost last laugh.
Hope this helps! KMT
KMT
Feb 19, 2011 | Freeplay Energy BayGen AM/FM/SW Radio
I have an original freeplay clockwork radio which has died. Help!
Hi , you have probably expired the battery life out of the radio [ they have a recharge battery life ] but all you have to do is replace those recharge batteries with new recharge batteries and your as good as new
Jun 12, 2009 | Freeplay Energy BayGen AM/FM/SW Radio
Freeplay S360 Need Replacement Battery Pack
I will give my info here and say that I -was- able to replace the battery in my Freeplay S360. I purchased two of the 2/3 AA rechargable NiCD batteries and soldered them together. Then I rewired it into the radio and voila! It works! Total cost: about US $4 Total time: about 20 minutes Now all I need to do is remember to use the thing every month or so, just to keep the battery in good condition.
Jan 05, 2009 | Freeplay Energy S360 AM/FM/SW/DAB Radio
Marconi 2951 radio test set vintage
possibly a power supply problem - check current drawn from the power line compared with your other 2951. any disturbance in power supply voltages can kill the afc/pll in older service monitors. if you have the manual check the ps voltages
Sep 21, 2008 | Radio Communications
12:33 keeps flashing
Hi - You can download the manual from the link underlined in blue below:
moz-screenshot.jpgRCA RP5420
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 31, 2008 | RCA RP5420 Clock Radio
Spring broken?
Solution #2 is correct. My Baygen Freeplay radio was running fast and mine had a broken belt. I could not find a belt on eBay. After hours of searching the internet, I fond a replacement belt at http://www.kenselectronics.com/lists/belts.htm I have the older large Baygen Freeplay radio without solar power and this is the belt that fit my radio... AV-SBS9.5 Replaces SBX9.5 & 1407-36 & SCX9.5 square 9.5 x .047" belt, Baygen Freeplay. Just search the website above... they also have a second size Baygen belt that might fit the newer Baygen Freeplay radios???
Feb 27, 2008 | Freeplay Energy BayGen AM/FM/SW Radio
Summit freeplay "locked"
If you push time set and alarm set buttons simultaneously you can lock/unlock the radio
Oct 12, 2007 | Freeplay Energy Summit AM/FM/SW Radio
Freeplay Energy Summit AM/FM/SW Radio Logo
144 people viewed this question
Top Freeplay Energy Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Freeplay Energy Audio Player and Recorder Expert? Answer questions, earn points and help others
