Question about Panasonic KX-TG5632 Phone
KX-TG6051B panasonic cordless phone - lcd screen doesn't work
LCD Screen does not show anything at all. I've tryed to use it on another base, tried a battery that works in another phone, tried charging it.....so far nothing works.
  • 2 more comments
  • kdu001 Dec 14, 2008
    I have the exactly same problem, I changed a new battery, it is still same.
  • chantalprudh Jan 23, 2009
    I have this problem too. Most be a defect in the phone.
  • Anonymous Feb 26, 2009
    Nothing shows on the screen. What is worng with it.
  • Anonymous Mar 18, 2009
    Forget it. Unfortunately, and surprisingly, Panasonic cordless phones, in my experience have been pretty crappy. I've had several different models through the years and either it's the LCD or the microphone or the speaker or the whatever. It's a shame. Panasonic is a good company but I guess cordless phones aren't their thing.
    I've taken the phone apart, which is pretty simple , and tries readjusting the LCD but it doesn't do anything.
I am just now having the same problem tried everything short of taking it apart. got six years out of it.
Posted on Oct 23, 2010
Changing from pulse to tone panasonic phone
Touch the following keys: Menu 0 5 1 and then select 1 (tone, the factory default) or 2. Then Save (a softkey with the label in the LCD screen) and Off (opposite Talk on the keypad).
The manual for the Panasonic KX-TG5664 is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/KXTG5664.PDF . See page 17 for setting the Dialing mode.
I hope this helps.
Apr 06, 2013 | Panasonic Lands Phones
Can the lcd screen be replaced on a panasonic KX-TG5240 cordless phone? are these lcd screens available?
Return it under warranty. They will send you a new one.
http://www.panasonic.com/uk/support/warranty-information.html
Aug 03, 2011 | Panasonic GigaRange KX-TG5240M Cordless...
Panasonic KX-TG5631 that works but no display
This problem can have many solutions as it can have many origins. But one of them, and it seems the problem is synchronized, happening to several handsets within a short period of time, as if they ran out of their useful life all together, is caused by the breakage of the flat cable connecting the display to the main board. The thin film conducting material deposited on the plastic base wears off or breaks just close to the display driver making it impossible for the video signals to reach the LCD.
A solution I found was to file part of the white plastic display support base to give the flat cable some slack, and them to insert a rubber wedge between the support and the main board to keep some pressure on the cable, lifting it up a bit, bending the cable as to make the film cracks close and remake electrical contact.
It is not a permanent fix (replacing the display would be) but the phones can go back to normal operation for some time. How long? I don't know yet.
Dec 18, 2009 | Panasonic KX-TG5631 Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Hello -need help with phone
It's not charging the battery, clean the contacts on the base, put it on another base to see if it says CHARGING.
Verify that you have power to the base.
Battery might be bad. Try it in another handset.
Nov 06, 2008 | Panasonic KX-TG2357 Cordless Phone
Kx-tg5634m
i cant get my phone to work. it says no link to base move closer to base,try again.
Sep 18, 2008 | Panasonic KX-TG5632 Phone
Model#kx-tg6071b when talk button is pushed, screen shows" no link to base move closer, try again". That is what appears on both handsets.
Press MENU, scroll down to INITIAL SETTINGS (press select), scroll down to REGISTRATION (press select), then select HS REGISTRATION, and follow the instructions on the handset screen. This is for the KX-TG6071B, but is similar for most Panasonic Cordless phones. That will link the handset to the base, and YOU MUST DO IT WITH EACH HANDSET.
Jun 22, 2008 | Panasonic KX-TG2313 Cordless Phone
Message retrive
Sometimes with these units the buttons on the base go bad but the whole system still works. Try picking up the handset and accessing your messages remotely by pressing Menu, and then pressing Select which will appear as an LCD button option on your LCD Screen
Feb 12, 2008 | Panasonic KX-TG6500 Cordless Phone
No dispaly on screen.
Three possibilities. 1) The LCD screen is cracked from a fall or hit etc.. It can be visible or a small crack hidden on and edge or corner, only visible after taking out the display. 2) The phone was exposed to moisture or high humidity long enough for corrosion to start. This could have happened many months ago. The corrosion has finally effected the LCD. If you're up to disassembling the phone you can clean the LCD connector with rubbing alcohol and a tooth brush as well as clean the LCD cable itself with a pencil eraser. Typically the LCD is held in with a little 2-color connector that you open with a tiny screwdriver or other tool by carefully prying off each side of the connector a little bit. (1-2mm) when you are done just slide the lcd connector in all the way and push the connector back in. 3) It's unlikely but the LCD can just stop working. It's not worth paying $30 to $50 for a new one. Just replace the phone.
Jul 12, 2007 | Panasonic KX-TG5622M Twin Cordless Phone
Panasonic KX-TG5632 Phone Logo
1,768 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
