Question about Refrigerators
GBE18RBRAWW GE BRITA BOTTOM MOUNT FRIDGE. FREEZER WORKS - FRIDGE ALL IS WARM!
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
SOURCE: removing freezer drawer
my son fixed it - thx. problem solved
Posted on Nov 24, 2008
  • 686 Answers
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Posted on Feb 17, 2009
jumptrout51
  • 3361 Answers
SOURCE: Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Posted on Feb 22, 2009
lenwest
  • 150 Answers
SOURCE: refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 27, 2009
I have a GE Profile Brita Fridge. My fridge is working fine but my freezer doesn't work. What can I do about fixing it?
Does it have frost in the back off the freezer? Do you heard the fan running in the freezer?
Mar 25, 2016 | GE Refrigerators
Brita profile
yes replace the seal, this type of spotting that forms as rust color occurs on "ferritic" stainless steel. Simply put there exists iron in the alloy and the surface needs to be pacified. Use DeBruce Polish to correct the problem. Non-toxic and odor-less containing NO ACID, this TRUE MULTI-SURFACE CLEANER is the best product for stainless steel AND glass/ceramic cook tops. Go to debrucepolish.com, you will be glad you did!
Aug 26, 2013 | GE GDS18LBR Bottom Freezer Refrigerator
Hello I have a GE Profile with Brita refrigerator bottom freezer and it suddenly stopped cooling in the refrigerator portion. The freezer works but very weakly. Ive unplugged it, let it go for one hour,...
The drain is frozen up. The fan what provides the cooling air for the fridge is stuck in the ice. Remove the vegie crisper and pop the bottom under the crisper s out. Also remove the Styrofoam plate. You will see the problem right in front of you. Use a hairdryer to get rid of the ice build up. Good luck
Dec 07, 2010 | GE GDS18LBR Bottom Freezer Refrigerator
Freezer is cold, fridge is warm; replaced main board already
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 25, 2010 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
GE Profile - fridge not cooling
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
Ge profile brita 18 bm black purchased in jan/06
Having the same problem. apparently this is just a horrible fridge... unfortunately no solution for ya
Jan 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
GE Model PDS22MBRABB bottom mount
These fridges were made by LG they are very problematic, the defrost cysle does not work properly due to board defects and the fridge freezes up, I have replaced my board twice and the fridge has worked properly for 6 months max them the board shorts again, I talked with the LG rep he said scrap the fridge they are ****.
Nov 06, 2007 | GE Energy Star PDS22SIS Stainless Steel...
Refrigerators Logo
160 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
