Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
F-7 error code on jennaire oven
Fans kept running long after oven was on. Now timer beeps sporatically and f7 error code comes on. Jennaire w27400.
    Master:
  • 505 Answers
The F 7 code does stand for a stuck key on the touch pad. You just need to get the touchpad replaced by a technician. Thanks
Posted on Nov 01, 2008
    Genius:
  • 1,913 Answers
Check your power supply try with other power bord in your or other hose.
may be earthing or waltage problem.
  • Jenn-Air Master
  • 19,396 Answers
I think that is a problem with the control assembly.
Try first unplugging power cord for ten minutes , and see if this clears the error message.
  • Ginko
    Ginko Nov 01, 2008
    F7 is faulty touchpad and control assembly .
    Check first if any of the key is stuck , in this case unlock it, try also playing with the keypad, if you can fix it in this way you save $150
    Check that the internal connections to the keypad are fine and do not have oxide.
    part number is 71002033
    Part costs $157, see here
    PartStore.com
    See a testimonial here
    Get parts here
My control panel died completely and I purchsed a new on. when I plugged it up I am getting an F& error code. How do I clear that?
Posted on Jan 27, 2014
Jennaire double wall oven Model W256W-C, top oven locks, can't unlock. When locked there're clicking/popping sounds/fan runs at times. Need reset to the factory default? Can see the lock latch move.
Hello. It sounds like the gear in the lock motor is stripped. I don't know how old the unit is but over time, the plastic(or nylon) gear material becomes brittle and when the lock is engaged, the teeth break off causing the issue you described.
Sep 14, 2015 | Ovens
Why won't it operate?
Hi Pam, Is this not covered in the user manual? Additionally search online by "error code f7 f1" and see what hits you get.
Jul 10, 2015 | Jenn-Air JJW9630C Expressions Collection...
What do I do about oven beeping?
Could be control module, but not sure. I had issues with a code a long time ago, and the broiler kept coming on and wouldn't shut off, so finally had to shut it off at the breaker. Turns out the control module is fried. But just a thought.
Apr 28, 2015 | Kenmore Double 27" Electric Built-in Wall...
The oven door sounds awful, in the morning if you weren't awake, you will be...guests and eveyone as soon as the door is opened. How can we get it to stop squeaking. It is a Jennaire, about 4 years...
Try spraying cooking oil (such as PAM) on all the moving parts of the door -- the noise is probably coming from the hinges and/or spring.
Charlie
Jan 08, 2011 | Ovens
JKP15 Electric Single Oven: Oven keeps beeping with F7 error...
F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC).
May 07, 2010 | GE JKP15 Electric Single Oven
''F7'' Error Code
HI. This is the result of a failed function key. This is an integrated part of the main control board. Unfortunately, this is not repairable, and the main control board will need to be replaced, asap.
Dec 20, 2009 | Kenmore Ovens
F7 displays on control panel????? JRS04BOW3BB. Used very little. Timer kept beeping on its own so I disconnected at breaker.
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Thanks
Jul 28, 2009 | GE JRS04 Electric Single Oven
F7 Error on the above range
There is a fix for the F7 error. Search for Powerman + GE + F7
Apr 27, 2008 | GE Profile JT910SASS Electric Single Oven
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
1,053 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
