Question about Hitachi PJTX100 Multimedia Projector
There is no picture
I been trying to fix ed-x3270a hitachi projector. there is no picture on rgb input (laptop or pc) connecting. But it senses something connects. But when I connect something to video input (video camera) it works properly. This projector has 2 monitor input and there is an IC (EL 4332CS) to swich them. I connect to osiloscop IC's input and outputs there is input signal but no ouput. I decided that IC is defective. But Im not sure. any advice to fix it?? thanks
Just a shot in the dark. this reminds me 'bout a problem with a Optoma (or maybe it was a Ask) i fixed. In that setup menu (on the proj), i was able to adjust the sync signal on the input. (I don't mean the the screen refresh rate..)  Just tried gradually step by step. Worked then!
Posted on Oct 27, 2007
When i connect the projector to my computer, all it says is no input selected. i need help with this IMMEDIATELY!!!
make sure the computer has the output screen signal enabled on the external rgb connector. you can confirm this by connecting an external lcd monitor to the pc. swap the pc vga output to the projector.
then make sure the vga/rgb input source is selected on the projector.
also select the lowest resolution on the pc to start with. when a picture appears on the projector, then increase the pc screen resolution until it says it's not able to show it, and back off to the last setting that worked
Apr 13, 2011 | ASK Proxima Office Equipment & Supplies
Projector comes on, everything seems to work, wont recognize any inputs when they are plugged in, says that there is " no inputed detected"
There are several input that you will have to select. RGB for input from computers. There are also video imput selection if you plug it into a DVD player.
Aug 10, 2010 | Hitachi ED-S3170A LCD Projector 1700 ANSI...
Hitachi projector cp-s318 and the pictures give off a red tint.
Make sure the Computer Input is set to VGA, Computer, or RGB (depending on which projector model you have). Go through the menu settings of your projector.
Hope this helps
Apr 01, 2010 | Hitachi CP-S318 Multimedia Projector
I've connected my laptop to the projector. It displays the image for a second and then displays 'Analog RGB searching'
Try setting the projector to VGA instead of RGB input if you can, you should be able to toggle though input modes.
Make sure that the resolution of the laptop is equal or lower to that of the projector.
Jan 28, 2010 | HP Digital Projector Vp6120 Multimedia...
I've connected the projector to my laptop using the VGA cable as stated in the manual. The projector reflects as it should, i can access the menu and input options which i then select RGB scart (though...
Not with any RGB input options, computers are not compatible with these. The projector needs to be set up to receive VGA. There must be a toggle button or menu entry somewhere on your projector that lets you do this or why would it have a VGA input?
Dec 07, 2009 | Sanyo PLC-XW55 LCD Projector
Color shift blue tint
This could also be a setting. If you are using component video as a connection, make sure that the unit is set for RGB if coming from a laptop or other computer system. If the projector is set to YPrPb, the picture will look purple or bluish as you describe. Change the setting to RGB and all should be well.
Dan
Oct 26, 2009 | Hitachi CP-X1250 Multimedia Projector
I am trying to project a presentation from my toshiba laptop to a Hitachi data projector (new). The desktop and all have a red/pink tinge. i even tried just going into my pictures and doing a slide show -...
This sounds like a bad cable... do you tight the scew? inspect the cable connector at each ends to dbl check that there is no damaged pin, and also on the projector side...
Oct 15, 2009 | Computers & Internet
I can't project my image from my laptop to the projector..
A usb cable will not work that way--on your projector, it's used for data...you need to obtain a monitor cable which will plug into the vga connector on the laptop and into the connector on the projector (rgb in 1) or (rgb in 2) If you use the #2 rgb input, make sure the button IS NOT pushed in! If it is, the projector will be switched to OUTPUT mode on the #2 connector. Also, on the laptop, normal operation is "laptop only"...when you push the <alt F4> buttons, it should then switch to "laptop + external display(projector)", another <alt F4> push will give "external display only" mode. Then, another push will return you back to "laptop only". NOTE: Sometimes, you have to turn on the projector first, then immediately turn on the laptop--not to get technical but different equipment can get finicky about syncing up...just something to be aware of...
Aug 31, 2009 | Hitachi CP-X250 Multimedia Projector
Hitachi PJTX100 Multimedia Projector Logo
238 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
