Question about Sharp Office Equipment & Supplies
Can not clear misoperation mode. tried pushing clear and escape twice. tried unplugging to lose memory.
    Genius:
  • 2,120 Answers
Make sure the phone line is good.
Posted on Nov 01, 2008
EE error code on reliOn blood pressure monitor?
Corrupt memory causes this.
Just guessing on your make and model type!
1 - Unplug the washer from power for 10 minutes to attempt to CLEAR THE CORRUPTED MEMORY on the main control board.
NOTE: You can try unplugging the washer multiple times to attempt to clear the corrupt memory. Unplugging the LG washer with the EE error code may clear the error code and no other action is required. The washer memory will be cleared or reset and the EE error code is considered fixed or repaired.
2 - If the code does not clear on the washer after unplugging it multiple times, this means the main electronic control board is faulty and needs to be removed and replaced.
3 - To be sure the main control board is the problem, run a TEST MODE if you want to continue the troubleshooting process or just replace the main control board and that will fix the EE error issue.
NOTE: How to run a TEST MODE on an LG front load washer is explained below...
4 - If you have unplugged the washer for 10 minutes and have done this multiple times and the EE code DID NOT CLEAR, you can run the TEST MODE and the EE error may come up with the FIRST PRESS OF START/PAUSE BUTTON DISPLAYS EE ERROR CODE. If this is the case,then you have a bad or faulty Main Electronic Control Board and you need to replace it.
Dec 16, 2017 | Washing Machines
When turning on our sharp XE-A42S cash register in REG mode it lets us enter in a price, but when we go to push the department key, it beeps and displays misoperation...
Firstly, press subtotal (ST) button. If a price appears, you are in a sale and it is waiting for you to finish (try another method like credit). If it gives an error or beep when you press ST button and the drawer does not open when pressing CA/AT/NS, you probably haven't signed on. Try signing on using a PIN number (see clerk sign on in your manual)
Jan 11, 2017 | Sharp XE-A42S Cash Register
Insignia tv(model unknown) stuck exiting Netflix how can I fix it??
Try to unplug the tv from the wall/ outlet, and be sure to leave it unplugged for about 5 min. This will clear the memory of the tv (dont worry though, this just clears up unnecessary files taking up memory, you wont lose anything) then plug it back in, and it should be fine after it reboots!
Apr 03, 2016 | Insignia Televison & Video
Canon iRC5185i with the erro code E000007-0201 . i need the solution to clear this erro
Manual:
E007-0201 Belt push-off temporary escape mode error.
Occurs when the belt deviation is not eliminated within 1 minute in the belt push-off temporary escape mode.
I can't understand what it means.
Oct 25, 2013 | Canon irc5185i
How do I turn off protocol monitor on sharp fax model fo-235
Had exact same problem on UX 177. You need to clear the memory. On the UX 177 unplug machine, press and hold down the COPY button then press and hold down the STOP button. Keeping these two buttons pressed plug machine in. It should display message "clear memory ?" let go of the COPY and STOP buttons and press the START button. Will then display message "memory cleared". This will also wipe out all other programming but it is the only way to stop protocol report. Then reprogram all your settings.
That stopped protocol report printing after each fax. On some machines it may be the stop and start button the need to be held down on startup. It also seems to make a difference which button you push first even though machine is unplugged.
This problem returns after a power failure so if you have a lot of numbers programmed in you might want to get an inexpensive uninterruptible power supply or plug fax into UPS for computer if you have one.
Mar 03, 2011 | Sharp Office Equipment & Supplies
How do I remove a padlock that is showing on my olaf ludwig tv?
Try contacting the manufacturer or looking in the owners manual. Many people write down the code in the manual so they won't lose it.
Child guard systems on TVs are locked by a pass code. To clear it you might try unplugging the TV and short the contacts on the plug. There is a low voltage memory keeping the lock in place and it may clear it. As a last resort depending on the TV there may be a small battery inside (like on a computer motherboard) that powers the code memory. If so remove the battery for a minute or two and put it back. Warning - TVs retain a 20K volt charge in the picture tube, even when it is unplugged so don't touch anything else. Otherwise leave the TV unplugged for a couple of days and it may lose the memory.
Mar 02, 2011 | Rawland Cycles Olaf
Cannot clear misoperation error
If there is still a $ amount in the display enter that amount or more and press the CA/AT/NS key
Mar 30, 2010 | Sharp XE-A404 PC Desktop
I have a 2003 ford escape. Check engine light came and my code showed P1405 code. Replaced EGR valve and sensor. Code does not show up on pocket scanner, but the escape stills loses power and will barely...
On alot of cars you must erase the code after repairs,the code is pending in the memory and can still run bad till cleared.try clearing the code
Jan 12, 2010 | 2003 Ford Escape
26 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
