Question about HP LaserJet 4100n Printer
Setting Up Printer For First Time Use
Hello
I have just purchased an immaculate 4100N. I have printed the test pages and they are perfect. It appears that the printer itself is working correctly.
I am using Vista Home Premium. I have purchased and installed a card with a parallel connection plug or socket at the back of the computer. I have connected the printer to the computer with a parellel cable. I have "installed" the printer in Windows and set it as the default printer. It shows up in Printers with a green tick.
I have tried printing a document from M/S Word. I checked that the 4100N was the selected printer. The document shows up as "Printing" in the printer dialogue. Unfortunately, nothing happens - the document doesn't print and the printer still shows as "Ready". Being a relative beginner, I don't have a clue as to what to do next. However, I searched Google and found this excellent site, which has already been added to my Bookmarks !!
The driver I installed came direct from the HP web site - HP Laserjet 4100 Series PCL6. I guess this is later than PCL5 ? How do I know for sure that I have even got the correct driver ? I did see references to a Universal driver - should I have gone for that. Am I supposed to set something in the Bios - I know how to open and view it but have never changed anything in it.
I'm hoping you can help me - it looks such a fantastic printer and I'm frustrated because I can't get it to work.
  • 4 more comments
  • Dave ROBERTS Nov 01, 2008
    Hello
    I'm amazed - I never expected such a quick response. I have been to the page you supplied. I clicked on the option to check current driver and was asked to install the latest "Driver Check" software, which I did. The check was completed and it identified my printer correctly, HP Laserjet 4100 Series PCL6. It asked that the printer was on and installed. Done. I then clicked on Check Now.
    The result was: Connected Printer - HP Laserjet 4100 Series PCL6 ----- Operating System: Vista ------ Connection: LPT1 ------- Results: Cannot determine the driver status for your printer.
    I ran the check again, but got the same result. I then downloaded the PCL6 driver again and installed it. As far as I can tell, the installation worked correctly. (The dialogue said "This wizard will install the HP Universal PCL 6 Driver")
    It then said "Use driver already installed" and then a dialogue "Installing printer" and finally confirmation that the driver installed OK.
    I selected a document to print - nothing, no response at all, only in the print queue, where it changed to "error".
    Hello again - and thanks for your continued help.
    I tried the 30 seconds tip - I got a message saying there was an error.
    I downloaded the driver again - when I tried to print a testpage (not from Word) immediately after installing the driver, I got the following error: The selected printer is not a supported HP device.
    As for the cable I'm afraid I don't know if it's good - I last used it about five years ago and it was working again. In case nothing else works, I'll make sure to buy a new one on Monday. Obviously the existing cable has got the correct plugs on each end - so I'll take it with me and ask for the same.
    I'm now going back to Control Panel, and I'm going to delete all the dud entries for the 4100 (I've tried that many times before finding this forum, that I've got several dud entries etc) and then I'll go back to your first answer and start again.
    Regards
  • Dave ROBERTS Nov 02, 2008
    Hello Again
    Having deleted all eroneous printer entries, I downloaded the drivewr yet again - ewverything seemed to work OK - checked in Printers and printer was showing as default, with driver just installed - yet when I tried to print test page, or a document fromn Word (Yes, I did check which printer was selected) I got the same error message, saying it was not a supported HP device. When I cancel the error box I get another error box saying "The handle is invalid"
    I don't know what to try next.
    Hello again,
    Thanks for the offer - Because the cable I'm using is so old - it was purchased with and used on my old Epson EPL5200 - I have ordered a new cable from HP, which should at least ensure that the cable is not to blame. The parallel card is of the same vintage, so I am going to replace that as well.
    By the way, I did think to go to PC World today - but I was not prepared to pay £19.99 just for the cable !! (I didn't even bother asking them for the price of the parallel card.)
    As soon as they are in place, yes, I would certainly appreciate your help. I have never used the "Assist" function so I'll have to read up on what I need to do.
    In the meantime, I have deleted all instances of the printer supposedly being installed, only for me to then repeatedly get that "This is not a valid HP ....." etc etc.
    I have also deleted all the instances of the drivers which I downloaded, having had to rename them slightly each time.
    While I'm waiting for the card and the cable, is there anything else that I could do, in preparation ?
    Again, thank you for your interest.
  • Dave ROBERTS Nov 03, 2008
    Hello again
    I live in Bournemouth. I have left a message for you on the site you have given.
    Kind regards.
  • Annie51317 Dec 19, 2008
    Hello
    I have an HP Laserjet 4100N. I am using Microsoft XP. I have purchased a parallelconnection plug or socket at the back of the computer with a USB connector for laptop. I have connectedthe printer to the computer with a parellel cable. I have "installed" the printer using MS XP auto detect driver because the little CD is for MS 98SE and ME. It shows up as the default printer.
    Ihave tried printing a document from M/S Word. I checked that the 4100Nwas the selected printer. Unfortunately, nothing happens - the document doesn'tprint and I get an error message "This document failed to print." The printer still shows as "Ready". I even tried following the directions in Windows troubleshoot for printers. I used the command prompt to no avail. I don't have a clue what to do next. However, Isearched Google and found your site.
    The driver I installed came direct from the Windows install - HP Laserjet 4100 Series. How do I know for sure that I have even got the correct driver ?
    I'm hoping you can help me.
    Master:
  • 409 Answers
  • 2 more comments
  • Cosma Papouis
    Cosma Papouis Nov 01, 2008
    Try turning the printer off for 30 seconds and back on.
    Are you sure it is a good cable you are using and that the parallel port is working?
    Try reinstalling the software and tell it that you do not want to use the existing driver.
  • Cosma Papouis
    Well let me know how you progress
  • Cosma Papouis
    Cosma Papouis Nov 02, 2008
    Could be that the Vista drivers are not installing correctly.  How would you feel about letting me remote control your pc?
  • Cosma Papouis
    Cosma Papouis Nov 03, 2008
    Contact me directly cosmap@papouis.net  http://www.cosmapapouis.com  where in the UK are you?
    I do not use the assist function, so there is nothing you need to do to be prepared. :)
2 Suggested Answers
Maanita
  • 1142 Answers
SOURCE: Does PCL6 support duplex printing?
This is gona be a helpful website for you
http://search.lexmark.com/printer/US/en/13D0000
Posted on Jun 27, 2008
My Sharp Ar-M155 is displaying d message replace the toner cartridge. I ve tested d cartridge with another machine and it is working perfectly
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Jul 07, 2011 | Sharp Office Equipment & Supplies
I want to print from my HP Laserjet 4100N tray 2 instead of tray 1. How can I do that?
Do a Configuration Page print out from the printers 'Information Menu'
Perform a paper path test from tray 2;
<Information Menu> , <Item> , <paper path test> , <Select> , use <Value> to select <Input Tray =2> , <Select> x 3 times.
Is the print out correct?
Check the paper size setting for Tray 2 matches the size you are trying to print onto.
Check / Adjust setting in the 'Paper Handling' menu.
Make sure Tray 1 has no paper in it when you send the print Job.
Check your Driver settings in Windows
Dec 22, 2009 | HP LaserJet 4100n Printer
Prints only on left side of page.
In printing web pages and email please try to check also the print setting before you print the page cause word document files and web pages are not the same in there printing setting. Web pages and emails has different setting so my recommendation is that when you print email and webpages next time then please check the printer settings then modify it the same settings as you wish or as your word document's output.
Thanks
Aug 18, 2009 | Epson STYLUS R230 InkJet Photo Printer
HP Laserjet 4100N saying toner is low when it isn't
yes Is there a sensor in the printer and in the toner cartridge that tells the printer when the toner is low. if u r using new cartridge it indicates perfectly.if u r using refilled cartridge the indication is not always perfect.so u do one thing use your cartridge till u think the printout is perfect do not worry about this messages this is common in many printers.if this solution helps u pls rate it as "fixya" thank u for using fixya.good luck.
Jun 11, 2008 | HP LaserJet 4100n Printer
Printing Envelopes
Must use Tray 1 bpass to feed labels, on word change media type to envelopes ie page size,paper type and on printer set tray1 paper type to envelopes
Dec 11, 2007 | HP LaserJet 4100n Printer
Printer Pauses every few pages, seems to print slower than it shouls
More likely to be Network print spooler issue, check settings on driver.
Nov 09, 2007 | HP LaserJet 4100n Printer
Laser Printer Cleaning
Does the dirty background get lighter as you print additional pages? Have you tried a new cartridge yet? Unless your toner cartridge is leaking toner (you?ll see toner on the inside of the printer or leaking out if you remove the cartridge and shake) a simple cleaning is probably not the answer. Let me know and we'll pick up later.
Feb 28, 2007 | HP LaserJet 4100n Printer
HP LaserJet 4100n Printer Logo
642 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
