Question about Dell Dimension 8400 PC Desktop
Dell 8400 X300 128MB BIOS P/N 113-A33406-100 error
3 Suggested Answers
SOURCE:
  • 52 Answers
SOURCE: Dell 8400 No Boot, not even POST
It sounds like your bios were improperly flashed or went bad. The X300 SE message is your video card. So your video card works, the system mostly works, but the BIOS isn't starting up. You should contact Dell and tell them the situation.
Posted on Apr 19, 2010
shahrasool
  • 51 Answers
SOURCE: When trying to boot PC
no problem friend please open your cpu shutter and you can see here a cell like watch's cell plug it out and replace it with the new one and start your computer now your this problem is 100% solve. thanks
Posted on Jul 17, 2011
Dell 8400 Boots to Black Error Screen in XP States to reinstall System 32
This might be caused by hard-drive failure. You should run hard drive test from BIOS to make sure hard drive is ok. You can access BIOS by pressing F2 during start up, from there start hard disk self test and wait for it to complete.
If hard drive is ok after test, insert in your original Windows installation media and reinstall OS.
Oct 02, 2012 | Dell Dimension 8400 PC Desktop
Dell dimension 8400 frozen on BIOS revision A01
you might need to update your bios contact the dell website for a possible update
hope this helps
Jul 06, 2012 | Dell Dimension 8400 PC Desktop
When trying to boot PC all i get is black screen and message:- X300 SE 128MB BIOS P/N 113-A33406-100. Have replaced bios battery on motherboard an checked connections etc but still displays same message....
Jul 14, 2011 | Dell Dimension 8400 PC Desktop
Error when starting Dell Dimension 9150 desktop PC: X300XT BIOS P/N 113-A33437-102
go to www.dell.com and check for a bios update if one is not present contact support and tell them your problem
May 31, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Apr 19, 2010 | Dell Dimension 8400 PC Desktop
Replaced the dell 8400 power suppley, -now system says floppy disk failure (I don't have a floppy) CD R/W have power, but don't work? Is there a schematic available?
Hello my friend probably is a bios setting,somehow you hit default settings or flash your bios and you turned it on.Go into bios(hitting del on boot) and on the general page there will be a setting for a floppy drive, likely something like floppy 3.5" 1.4mb choose it and hit enter and you should be able to disable the floppy drive.If there is no setting, look for a HALT ON ALL ERRORS setting and change it to keyboard onl.
Feb 06, 2010 | Dell Dimension 8400 power supply ** FREE...
[Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Apr 27, 2009 | Dell Dimension 8400 PC Desktop
My dell dimension 8400 bios a03 fails to bootup and displays this alert on the screen: Many attempts to boot the system have failed at checkpoint [Ithr]. how can i recover from this?
You need to reset your bios settings. Open your case and remove the cmos battery for 10 minutes. Caution: unplug all ac plugs before you open your case. put the battery back in and turn it on you should see an error message saying: you need to set system time and date. If you see this then you have successfully reset your bios settings and the defaults should load up. follow the instructions to change your time and date settings and save. reboot and hopefully you can boot up. I hope this works.
Mar 09, 2009 | Dell Dimension 8400 PC Desktop
Error reinstalling Windows XP on Dell Dimension 8400
Sounds to me like the hard drive is bad.Download some testsoftware that does not require windows and test it.
http://www.seagate.com/www/en-us/support/downloads/
Jan 15, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension 8400 PC Desktop Logo
137 people viewed this question
Ekse
Clive
Clive
