Question about Nuvo Simplese D 4-Source 4-Zone Audio System System
Serial codes for nuvo simplese
Does anyone have the codes for volume up/dowm and power on for the nuvo simplese system. Iam trying to connect it to a control4 system.
  • 382 Answers
I asked Nuvo about this and they said that the RS232 port was never setup for control, it is only to be used for programming when they are initially setup by Nuvo.
I have codes for the Essentia and Grand Concerto that I have written but non for the simplease as Nuvo said it cannot be controlled.
Cheers,
Posted on Jan 07, 2010
  • Kevin Braid Jan 07, 2010
    Control 4 just posted a driver for the Simplease, it is available through composer.
    Ends up it can be controlled but you must connect the TX to the tip RX on ring and Ground on sleeve.
    Let me know if that helps!
    Cheers
Nuvo Essentia won't power up
First, try unplugging all of the sound system and plugging the amplifier into an outlet on a circuit that was not changed by the electrical work. Also, plug an outlet tester into the outlet you were using for the amplifier to make sure it is correctly wired. If one outlet in a system has hot and neutral reversed and others don't, this could cause problems with some designs.
If you are lucky, dirty power from sparking inside the circuit breaker crashed the control circuitry in the amp, and it just needs a hard reset (power disconnect/reconnect) to be made functional again. In the worst case, something got fried and you'll have to use instruments to track it down.
Apr 23, 2014 | Nuvo Essentia Amplifier
No power light at controller no lights at key pads
What is the solution?
I'm having the same issue.
Nuvo has been installed about 3 months.
Nov 11, 2012 | Nuvo Simplese D 4-Source 4-Zone Audio...
Nuvo Essentia low volume on left side speakers
check the wires make sure thay are not loose or partial connection
May 29, 2012 | Nuvo Essentia Amplifier
Nuvo Essentia system on/off button flashes when keypad is plugged in. I can get 1 port in the back of the EZ Port to work on all zones but when keypads are plugged into other ports on/off button just...
You may have a pair of the cat-5 wires in the incorrect order which is causing a combus fault. Check all your cat-5 connections, ensure they are T568a (GS/G/OS/B/BS/O/BrS/Br).
Let me know if that checks out and we will continue trouble shooting.
Thanks,
Oct 29, 2009 | Nuvo Essentia Amplifier
I have nuvo 4 zone switch that I cannot get to
That indicated there is a short or incorrect wiring on the combus of the keypads.
Remove the keypads from the walls and unplug them one at a time.
Then unplug one at a time from the all-port until it works.
The last one you unplug will be the offender, inspect the cat-5 crimp for a pair or wires that are in the incorrect order.
Cheers!
Jul 19, 2009 | Nuvo Simplese D 4-Source 4-Zone Audio...
Trying to reprogram my Nuvo Essentia Amp, and I need to get the software in order to do so, and I am finding that it isn't available on their support site...
Unfortunately it is only available to those who are certified installers/dealers. Nuvo tries to protect those that sell it and does not offer anyway to program it on your own (Unlike Russound that can be done through a keypad by anyone).
I wish I had a better answer but you will have to find a dealer/installer to get you a copy of the software.
Cheers,
Jun 22, 2009 | Nuvo Essentia Amplifier
Nuvo NV-4A Keypad Flashing/Won't Work
I have the same problem. All keypads blinking in All Off. I changed the fuses on the Nuvo. No luck. Does anyone have a solution to this?
Jul 12, 2008 | Nuvo Simplese D 4-Source 4-Zone Audio...
Nuvo Simplese D 4-Source 4-Zone Audio System System Logo
472 people viewed this question
Top Nuvo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Nuvo Audio Player and Recorder Expert? Answer questions, earn points and help others
