Question about Radio Shack Cinego D-1000 Multimedia Projector
Cinego connection cables
I want to connect my VCR to the cinego. Can you give detailed specifics about the mini plug which goes into the cinego unit - 2 poles, 3 poles or 4 poles ?
    Problem Solver:
  • 11 Answers
The question seems to indicate that you don't have the cables. The unit comes with three different cable for video input. One for Component (HD), one for S-Video (looks like the round plug for a mouse on a computer, but is wired differently), and one that has a single yellow plug that probably is compatible with your VCR. If you don't have the proper cables, get with your Radio Shack dealer to get the, since trying to use a cable which was not designed for the unit may cause damage.
Posted on Jul 20, 2009
Need to find an original Cinego component cable
I am almost positive I have an extra one of these cables. Please let me know in more detail.
May 09, 2012 | Radio Shack Cinego D-1000 Multimedia...
How do i connect more compponents to my projector
The projector came with three video cables, and one audio. The first of the video cables is for component (three colors, which are blue, green, red) and is used for HD (hi definition) components. The second is an S-Video cable, which is used for just that, S-Video, which is one step below HD. The last type is composite, which is used for regular input. It has one input, which is yellow.
In order to utilize more than one component, you have to have a switching device. Since it is impractical (for me, anyway) to constantly unplug one video cable on the Cinego and plug in another of a different type, you must ensure that all of your components are of the same type. You may convert somewhat between components using cable adapters, but can only do so when the conversion is one level. The levels, from highest to lowest, are thus: HD, Component, S Video, Composite. You can go from one level to another which is one above or below, but cannot jump two levels.
As one example, if you want to utilize the HD capabilities of the Cinego, and you have HD cable or satellite and also a BlueRay disc player, such as a Playstation 3, you connect your HD cable/satellite and the PS3 each to a switching device, and connect the switching device output to the component input on the Cinego. The switching device, if you buy an automatic one, will detect whether the cable box or PS3 is on, and will transmit that signal to your Cinego. You may have to use an HDMI to Component conversion cable, or your switching device may have the ability to input HDMI but output the Component. The Cinego can only input the Component, as it doesn't have the HDMI input connector. The auto switiching device is about $25 and is available at big box retailers such as WalMart. So are the cables available there.
Apr 20, 2009 | Radio Shack Cinego D-1000 Multimedia...
Connect Cinego to MacBookPro
The projector has a computer video cable input on the side of the unit. If yor MacBook has a female VGA output, simply purchase a VGA cable (double male) at a Radio Shack or WalMart, or other comparable retailer, and connect the two. The Cinego will find the input signal from the Mac, and you have to press the right keys on the Mac keyboard to tell it to put the screen signal through the VGA output on the side of the MacBook.
Apr 19, 2009 | Radio Shack Cinego D-1000 Multimedia...
Cinego D1000
If you have the video cable plugged in as composite, check the red connection plug, it should be just as tight as the others. If this is not because of the connection described, your unit probably need repair. A local Radio Shack can tell you where to send it.
Sep 06, 2008 | Radio Shack Cinego D-1000 Multimedia...
You can see the link below for your Cinego Projector. Since you did not specify the model I did a generic. If you need more specific info for a specific model you can reply via comment.
Aug 27, 2008 | Televison & Video
Cinego D-1000 no power
Make sure all the connections on the bulb are secure. Cinego wont turn on if they arent.
Aug 07, 2008 | Radio Shack Cinego D-1000 Multimedia...
Connecting tv/cable box
This is a fairly common problem with this model. In most instances, it is just "slow" in sensing the presence of a video source as it cycles in its selection, internal DVD, VGA, Composite Video IN. Since it does not have a manual source selection, your only option is to really wait.
Verify that "Auto Source Select" is enabled in the Management Menu (buttons-Proj/Setup then >/9) and "tap" the "SRC" button on the projector itself to manually initiate the input/source selection.
Verify that you have done the connections correctly. Yellow RCA connector is the video while the red & white are the audio. Of course the Video input should be connected to the Video output, same goes for the audio. Please refer to pages 22 & 23 of the user's manual for more detailed instructions as well as illustrations.
A couple of things to consider: it is not HDTV capable and pls don't loose the remote.
If the unit will not select a source after some time (minutes), perhaps your best bet would be to seek replacement.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 12, 2008 | Radio Shack Cinego D-1000 Multimedia...
Cinego Projector to a laptop
Describe the connections available to you on the projector.
Jul 17, 2007 | Radio Shack Cinego D-1000 Multimedia...
205 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
xxxxxx xxx
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
