Question about Singer White Speedylock 1634
Just replaced my uppper looper on my white 1634....
I am not sure where it is supposed to rest, the thread coming throught the upper looper is not being picked up when i try to serge. The only thing happening is the needles sew straight lines. HELP! is the upper looper supposed to come up in front of the needles or behind them? perhaps something else is going wrong. I have re-threaded my machine to assure it is correct.
Hi.
The upper looper goes just in front of the needles. I had issues with my machine when I got some fabric jammed and the looper moved so it wasn't catching the left needle and it was sewing a straight stitch on the left. The looper needs to be placed in front of the needles and very close to the needles without hitting them.
Hope this helps!
Cherie
Posted on Dec 19, 2008
How do you adjust the timing on a serger? I have a White Speedylock 1634.
There are a lot of web sites & videos dealing with timing. Just search for "serger timing" or "overlocker timing."
Jul 28, 2016 | Sewing Machines
My serger is not looping at all. I changed the needles and nothing is working.
Start with the threading sequence. Upper looper, lower looper, left needle, right needle. Your upper & lower loopers must be threaded before your needles or it won't make the stitch. If it still doesn't work, it's out of time and will need to be taken in to a shop.
Mar 05, 2015 | Singer White Speedylock 1634
Upper looper has come loose and swivels. What is correct position for it to be tightened?
be careful you should take it to a shop because I tightened mine in the wrong position and it broke and I can't find another upper looper anywhere
Nov 23, 2010 | Singer White Speedylock 1634
I have a bernina overlocker and whenever I use it the lower looper (marked in red) thread breaks. How can I fix this? It was serviced yesterday and when other people used it before me it worked fine!
Then it's one of two things. First try setting your lower looper tension on 3 and see if that works. If not set it back on 4 and cut ALL your threads and re-thread the machine STARTING with the UPPER looper, then the lower looper, then the right needle, last the left needle if you're sewing a 4 thread overlock stitch. Make sure the threads aren't twisted in the thread guide. Make sure the lower looper thread is OVER the elbow on the upper looper and over the upper looper thread. Let me know if this works. We'll work until we get it fixed!
Sep 14, 2010 | Sewing Machines
Can I disengage the upper looper on the White Speedylock 1634? If so, How? My manual says nothing about it. I want to do a hem on a sleeve that has two parallel top stitches and the lock-stitch underneath...
No. You would want to disengage your upper KNIFE not upper looper to do this but you need a serger with the COVER STITCH feature to do this. You can get the same effect using a twin needle on your sewing machine. Hope this helps!
Aug 22, 2010 | Singer White Speedylock 1634
White 's serger
Even though the video is busted, have you tried taking it to a store like Radio Shack and having them try to put the information on DVD for you?
My VHS tape was fine but I put it on DVD and the instructions are quite good and very helpful.
Sep 14, 2009 | Sewing Machines
How to i thread my 008d bernina serger?
I believe it is color coded right?
start with the Upper looper follow from the upper looper throught the loops below the machine up through the tension disk and to the place where the thread cone sits. now retrace your steps from the thread to the looper place thread under foot.
by starting from the finishing point to the starting point you know where you are going with the thread when you thread the machine so upper looper lower looper right needle left needle. you must get it exactly correct or it wont work
Jun 21, 2009 | Bernina 1008
My white speedylock serger 1634 thread keeps getting in knots
i have the book and it says thread from inside out, inside looper (upper) then lower, then thread the needles, first right then left.  I have found that it does not matter if you thread the needles or loopers first but that you should try to thread from inside to out.
Jun 16, 2008 | Singer White Speedylock 1634
White Speedylock 1634 upper looper foot broke, need new one.Please help.
Contact a sewing machine dealer in your area. He can probably order the parts for you.
sewman7
Jun 11, 2008 | Singer White Speedylock 1634
Eclipse DX
It is important to leave about 3 inches out of the end of the loopers when threading. leave them lie where they come out of the jets. Put fabric under the foot and sew, do not wory about putting the thread under the foot. If it still does not work try changing the needles.
Oct 27, 2007 | Baby Lock Eclipse Serger
Singer White Speedylock 1634 Logo
154 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
