Question about Nokia 6600
My phone can not read the memory card
The card is cromped
  • Nokia Master
  • 1,800 Answers
Try a fresh new memory card if its not workung the Phone memoryt vard reader chip and circuit replacemt is needed
plz do rate this post as good as u can
Posted on Nov 02, 2008
Reading memory card
Hi
Try using another memory card, this time of less capacity i.e if you were using say a 8GB SD card, try a 4GB or 2GB one. It could be your phones not compatible with the cards storage capacity.
Hope it helps.Thank you.
Jul 14, 2012 | Samsung Cell Phones
My cellphone dose not read memory card and i can't format it
maybe your memory card is damaged or corrupted... check it by inserting other memory card... if your phone CAN read other memory card it means that your memory card is damaged or corrupted... and if the other memory card you inserted and still the same problem persist that your phone thus not read memory card... maybe there is something wrong with your phone... it can't detect a memory card...
options:
- replace new memory card (if damaged)
- go to the cellphone technician and have that phone fix..
goodluck...
Feb 02, 2011 | Nokia 5130 Cellular Phone
Won't read new memory card
Hi,when a memory card does not read on a phone, it means that the memory card is bad or is not compatible with the phone.
If the old memory card being used before works, that means the new memory card is bad and will need to be replaced.with another.
Have a nice day.
Aug 06, 2010 | LG Xenon GR500 Cell Phone
Memory card is not working
The reason the memory card is not working could be either the memory card is not working or the phone is not reading the memory card.
To test if it is the memory card,
insert the same memory card into another phone to see if the phone reads it.
if it does not read it, then the fault is from the memory card.
all you have to do is to replace the memory card.
To test if it is the phones memory card slot,
install a tested okay memory card into the phone to see if it will read it.
if it does not read it. then it is the phone. it could be a software problem or a hardware problem.
firs flash the phone with the appropriate software to see if it will work, if it does not, then it is the memory card slot.
To change the memory card slot,
follow these steps,
  1. First remove the battery cover & battery. Remove the two screws you see.
  2. Run your fingernail around the join of the front cover and then remove the front cover.
  3. Now remove the four screws you can see.
  4. The top part of the phone (PCB and LCD screen) can now be removed from the middle chassis.
  5. then you will have access to the memory card slot,
  6. remove it and carefully install a new one,
  7. reverse the process to reassemble the phone back,
  8. test it with a memory card.
take care
Jun 19, 2010 | Nokia 6300 Cellular Phone
5800 MMC NOT WORKING
If you Nokia 5800's memory card is not working.
It simply means there is a problem or two,
1. the phone might not be reading the memory card,
2, the memory card might be faulty.
test to know if it is the phone,
  1. insert the same memory card into another phone to see if the phone will read it.
  2. insert another tested okay memory card into the phone to see if it will work.
  3. if it does not,then the fault is from the phone,
to fix this,
  1. get the appropriate screwdriver,
  2. open the phone,
  3. carefully open the memory card slot,
  4. clean it properly with naphthalene and dry it under the heat of a bulb,
  5. or you can replace the memory card slot completely,
  6. insert the memory card and turn it on to see if it will read it.
  7. before you couple it back together.
  1. insert the memory card into another phone to see if it will do the read it, if it does not, then the fault is from the memory card.
to fix this
all you have to do is to change the memory card.
take care
Jun 18, 2010 | Nokia 5800 XpressMusic Smartphone
Continues to tell me to insert it when it's there
The reason the phone is not reading the memory card is either the phones memory card slot is faulty or the memory card is not in good conditions.
To test if it is the phone, try a well tested memory card in the phone to see if it reads it, if it does not then it is the memory card slot.
to solve that, try to open the phone and clean with spirit and drey it with the heat from a bulb, or you can replace the slot.
To test if it is the memory card, try the memory card another phone that the memory card is working fine.
if it does not read the memory card, then the fault is from the memory card, and the solution is simply to replace the memory card.
Make sure the memory card is not above 16GB.
Take care
Jun 14, 2010 | Samsung SCH-U450 Cell Phone
Transferring music files to microSD card
It says on the manual this this phone accepts microSD™
memory cards up to 2 GB (depending on memory
card manufacturer and type). Check with your phone manufacturer if there are known issues with a particular memory card brand.
Also, try connecting the memory card to your computer via memory card reader and see if the card will be detected. That way, you can check whether the card is working or not. Save the music files from the PC to the memory card, then see if the music files will appear when you insert the card to your phone.
Jun 20, 2009 | SanDisk 2GB microSD Memory Card
Phone can't read memory card and music that card reader can
hello sir my mobile c-6 ke kingstan memory 4gb card me lock lag gaya card no:e30461120/eskom1103443
Jun 13, 2009 | Kingston 2GB Secure Digital Memory Card
Memory card not read by the cell phone
you put your memory card on other mobile.
if it works so you have to repair your hardware and if it doesn't so change ur memory card
Fazel
fazel_rehman05@hotmail.com
Jul 23, 2008 | Nokia 6300 Cellular Phone
Memory Card Reader
when you install the software and connect the phonevia USB cable the memory card should be read as DCIM
Jun 22, 2008 | Cell Phones
Nokia 6600 Logo
49 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
