Question about Acer Aspire 5100 Notebook
Connecting Acer laptop to secondary monitor
I have a VGA output on my Acer laptop that I have been able to connect to projectors in the past with no problems but now no signal is going to either a secondary LCD monitor or projectors when connected to my VGA output. What are the possible problems and solutions??
Thanks,
Jason
  • 1 more comment
  • jasonpreston Nov 02, 2008
    So far I have tried differnt monitor setup changes using the Windows XP control panel under display settings. I have pluged a LCD monitor into my VGA output on my laptop and the LCD monitor says "no signal". In the display settings options I have checked "extend to external monitor" and clicked apply but nothing happens. Hope this is enough detail.
    Thanks,
    Jason
  • jasonpreston Nov 03, 2008
    Yes I have done this several times with no success.
    Jason
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Would you be willing to list what diagnostics you've run so far so we don't repeat something you've tried already?
    Thanks,
    Worldvet
    Guru:
  • 859 Answers
Have you use the Fn Key plus the Monitor Icon written on another F Key in the same color as the Fn Key?
WV
Posted on Nov 02, 2008
VGA-HDMI connection fail on Acer projector using adapter
You don't say whether or not the "adapter" is simply a gender-changer, or if it actually converts the digital signal from the HDMI port to an analog one for the VGA port. Some monitors have both analog and digital input capability and can automatically adapt to the the digital signal, even if applied to the VGA (analog) port. Other devices are not so smart and need an actual digital-to-analog converter style adapter.
Jul 06, 2016 | Acer XD1170D Projector
I can not connect laptop with projector
Instructions
Things You'll Need:
Laptop computer equipped with a VGA, S-Video or HDMI output.
Overhead projector with the applicable input.
VGA, S-Video or HDMI cable.
Software to ready your content for presentation at the correct screen resolution.
DVI-VGA adapter, if you are using a Mac.
Step 1
Learn the different types of video outputs your laptop may or may not support. The three most common types of video outputs used with overhead projectors are Video Graphics Array (VGA), Separated Video (S-Video) and High Definition Multimedia Interface (HDMI). You need to make sure your laptop has the correct output corresponding to an input on the projector you will use.
Step 2
Weigh the strengths and weaknesses of each types of video input and output. VGA projectors are the most common type, indeed it is likely that any projector in current use will have a VGA input. However, VGA video offers the lowest resolution of the these three types. S-Video offers a higher resolution than VGA, but is prone to screen flicker, especially when you are connecting your laptop to a power supply while presenting, rather than running off the battery. HDMI offers the highest picture quality of the three, and supports audio data transfer as well. However, know that HDMI-equipped laptops and projectors are more expensive than those that utilize the other video transfer formats.
Step 3
Choose a video data transfer standard best suited to your price range and needs. VGA is always the safest bet, but if you are purchasing a new laptop computer, try to find one within your budget with an HDMI output as well, as it will provide the best quality and allow you to transmit audio without the use of extraneous equipment. S-Video inputs are found on nearly every LCD and Plasma television, meaning that if you are giving your presentation connected to a television rather than a projector, this is a viable option as well.
Step 4
Make sure you know how to tell your computer to recognize that you wish to use a projector as a secondary video output device. On Windows-based laptop computers, this usually involves pressing the "Function" (or "Fn") key, followed by one of the numbered "F" buttons along the top of your keyboard. In most cases there will be a graphic of what looks like a television screen on the correct "F" key (e.g. "F4"), but if you aren't sure consult the manual that came with your specific model.
Step 5
Connect your video cable of choice to your projector and your Windows laptop, turn the projector on, and press the correct function key. If you have a solid video card, pressing the same key combination a second time will allow you to view your laptop's screen both on the computer itself and as a projected image simultaneously.
Step 6
Connecting a laptop computer to an overhead projector can be a little trickier. You will need a special adapter to connect to a projector using VGA, as well as the standard VGA cable. This is called a DVI-VGA adapter, and is available both from Apple and other electronics vendors. Plug the adapter to the DVI port on your Macintosh laptop, then plug the VGA cable into the projector and the adapter. Turn on the projector, then press and hold the "F7" key on your Mac. You will be up and running in no time.
Step 7
Try a dry run of your presentation using your own laptop and the same projector you will be using, if possible. It pays to be prepared, and your audience will be able to tell if you are fumbling around for the right function keys on the day you present. Your confidence will help you start your presentation off with a bang, and it will show.
Hope this helps
Aug 01, 2010 | Acer PD100 Multimedia Projector
Connected VGA cable to my pc and projector.Searching only
First off be sure that you plug into the input connector. As you look at the back of the projector it the VGA connector on the left. Also make sure you activate the VGA output of you computer (This mainly applies to laptops and secondary Video jacks on PCs).
Jan 15, 2010 | HP VP6111 Multimedia Projector
Clearco HD 9000 connected but 'no signal' from PC. Thanks
This projector has a maximum input resolution of 800 x 600, so if your computer is set to a higher one (which it probably is) and the projector is connected to your primary output, you'll see nothing. Here's what to do:
If you have 2 outputs as most video cards do nowadays connect the projector to one and the PC to the other. (you may need a DVI-VGA adaptor, usually one comes with your video card if you do).
Right click on an empty bit of desktop. A pop-up menu will appear and one of the items will be the control panel for your video card (usually nVidia or ATI). Start that up, and there will be an option to connect multiple monitors, as well whether you want cloned output or an extended desktop. You can set your resolution here. Make the projector your secondary monitor. It does not matter if it cloned or and extended desktop - if it is extended you can drag media player into it and maximize it to watch films etc, but cloned is best for games. make sure the reolution of the secondary monitor is no more than 1024x768.
If you have only one video ouput from your PC, go into video settings as before and just make sure that the resolution is set to 1024 x 768 or lower before you connect the projector.
When connected, keep pressing the input button until it toggles to VGA mode. Should work now.
Jan 08, 2010 | Office Equipment & Supplies
Are acer monitors unable to pick up HD video inputs?
There are two types cable to connect to LCD Monitor. VGA and the other is DVI,ight need DVI cable it has flat pins and is larger than the VGA small round pin models.
Dec 21, 2009 | Acer X193W LCD Monitor
How do I connect a projector to my G60
Hello
  1. Start by making sure the laptop and projector are both turned off before you start trying to make any connections.
  2. Locate the video cable -Usually your computer should have a svideo ort out. The projector should have either a hdmi or a RCA immput ports, thus you need a svieo to rca cable. Otherwise your laptop should have a VGA port oout where the projectorr should have a VGA port in.
  3. Make sure both ends are securely connected and tighten if necessary. Use a screwdriver or small pliers to tighten the connectors. A loose connection at either end will prevent you from displaying your presentation.
  4. Locate the audio cable and connect the audio cable included with the projector to the Audio Out on the laptop and Audio In on the projector. Make sure these connections are tight.
  5. Start your laptop and the projector. Make sure to check all connections to ensure they have been properly connected.
Really hope this can help you.
Kind regards
Andrea
Nov 13, 2009 | HP G60-120US Laptop
Problem connecting my acer aspire 5600 to a projector
First let it install this can take a minute or 2 (this goes automaticly) when this doesn't work go to your ATI control panel somewhere is a button where you can control a other monitor/projector
Oct 15, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
ACER Aspire One AOA150-1635 and Sharp XR32-X projector
you need to connect it with VGA. then enable the 2nd monitor
now you should have a wallpaper on the projector, you can drag objects to it by draging them out from the screen.
if you don't have the 2nd screen option. Then hold down the blue FN button and then tap F5 see if the picture comes, the FN + F5 will swap around with the outputs.
Feb 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer laptop stopped displaying to projector
Here is the deal. Right-click on desktop. Choose settings. Right-click on screen #2. Click on apply for new settings. The one additional problem you may encounter is the fact that the projector will display an area to the right of your laptop screen. In other words, move your mouse past the right edge on laptop screen. Look at projector image. See your mouse?
Aug 04, 2008 | Computers & Internet
Acer Aspire 5100 Notebook Logo
1,200 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
