Question about Car Audio & Video
1991 volvo 740 turbo wagon stalls, rough idle, hesitation, engine light on
Hi, I recently bought a 1991 740 turbo wagon which ran great when i got it. I started sensing a little hesitation, but not constant. Now it stalls at stop lights, idle is rough, and I'm experiencing extreme hesitation, especially over 40 mph. It hesitates and if you put your foot to the floor, it kind of "kicks in" and accelerates. The car has 161k on it and is used to commute daily. Check engine light just came on yesterday. Any help you could give me would be greatly appreciated.
Thanks,
John
  • 116 Answers
SOURCE: 98 E-250 Rough Idle; codes p0156,p1131,p1151,p0301,p0171,p0174+
po301 thru po306 all misfire codes cylinder 1-6 remove plugs and replace them..... set the plug gap first
i suggest u replace the wires also if they never been replaced all these misfire codes can set the others and one is for the oxygen sensor ( 02s or HO2S) CIRCUT MALFUNCTION do u know how to check wireing systems
do the tune up plugs (set gap) .052-.056 change the fuel filter also. clear the codes hows it run
this info is for 98 E-250 4.2Litre
what engine do u have 4.2L or 4.6L i know it is a v-6 by the codes
Posted on Dec 15, 2008
SOURCE: Car stumbles,hesitates,loses power on Hwy, randomly
Did you check earth connection of electric system?
Posted on May 10, 2009
  • 2039 Answers
SOURCE: My 1991 Toyota has acceleration hesitation
check rom the air fiter box there a air hose that goes to engine check if that air duck hose is not crack or broken repair with electric tape if broken or crack if everything goes fine after the repair change that hose or leave it like that with a few layer of tape its a cheap repaIR THANKS PIERRE
Posted on Jul 30, 2009
  • 52 Answers
SOURCE: 2001 focus. Replaced plugs, wires and coil pack.
Have you replaced the timing belt? if not i would highly recommend doing so. these cars need to have the timing belt replaced before it breaks otherwise it can and will cause major engine damage.
Posted on Aug 11, 2009
buckway2222
  • 6 Answers
SOURCE: Acceleration Issue
your fuel injectors are clogged
Posted on Aug 23, 2009
I got some serious problems with my 1988 volvo 760 turbo. It has about 159,000 miles. It has the B230FT engine. It was running great when I bought it about 3 months ago. It started with stalling once and a...
The bearings in the turbo may be shot. Check the shaft in the turbo if you can wiggle it around its bad and will need to be replaced or rebuilt.
Jan 03, 2011 | 1988 Volvo 760
Engine loses power and stalls
try adjusting the throttle position switch very hard to adjust right car will hesitate , not idle properly and hesitate when accellerating if not adjusted properly.
Jan 23, 2010 | 1991 Volvo 740
1992 Volvo 740 Wagon w/o Turbo: Timing Belt Needs Replaced
It is a right hand thread and you usually need an impact gun. Take the fan out of the way, to give you more room, I have found that helps.
Mar 30, 2009 | 1992 Volvo 740
1991 volvo turbo idles fine runs ok but the exhaust manifold gets glowing hot after highway speeds. help
please stop driving you will ruin your motor.the problem you are having is a vacum leak. and that is causing your engine to run very lean.
Mar 11, 2009 | 1991 Volvo 740
1991 740 Wagon electrical problems
Was the car primarily in a Southern state--no winters? If yes, it could be the wiring harness that leads to the rear wiper/stop light inside the rear tail gate. They usually break at the flex point, and short to the frame.
Feb 12, 2009 | 1991 Volvo 740
Smokin Car
I had a 87 740 turbo wagon, It ran a 10.9 1/4 mile man was it fun. I hate to say that your turbo is nearing the end of its life. The only thing you can do is replace it. there are speciality shops that specilize in turbos. if you can't find one close check out a Diesel truck shop, they deal in turbos too. maybe you can have it rebuilt a little cheaper, or I can tell you how make it pass a Corvette. Good luck.
Jan 09, 2009 | 1987 Volvo 740
Car Audio & Video Logo
389 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
