Question about Kenmore 63942 Dryer
2002 kenmore dryer
Dryer just stopped working, when I try to turn it back on nothing happens, no sound nothing. I am trying to get at the fuse but the back seems to be sealed shut. How do I dismantle it to get at the fuse
Thanks
ADAM
  • 686 Answers
Either the top pries up or at the bottom of the front panel you'll see 2 screws. If screws at bottom take out and lift off be sure to disconnect door switch wires before removing door completly. If it's pry top up use flat screw driver at about inch and a halh in from edges pop the top up and open then inside front panel toward top you'll find 2 more screws take them out and front panel should come off. Good Luck
Posted on Mar 01, 2009
Nothing happens when you push the start button. I have checked the breaker already
Sounds like your door switch has gone bad. If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Here is a video on the door switch. On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. Here is a video on the thermal fuse.
Happy Holidays!
Dec 09, 2010 | Kenmore 73952 Gas Dryer
Kenmore Dryer Model No. 110.64632300
If it is 6 years of age or older and have a lot of use in the past you will be better off replacing it. The cost to repair it will outweigh its age and cost to repair
May 20, 2010 | Magic Chef CYE4000AWW Electric Dryer
Making buzzing sound and not turning. then the buzzing sound stops and it smells like something is burning. then u will hear a clicking noise and sound will stop all together and nothing will happen unless...
The motor on your dryer has gone bad. The humming is the motor trying to start and the smell is the motor getting hot because it is not starting.
You need to replace the motor.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Mar 09, 2010 | Kenmore Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Battery went dead alpine cd stop working
Sometimes when you jump off a truck the CD player fuse will blow because it was trying to turn on each time you turned over the engine. Check all the fuses.
Mar 22, 2009 | Alpine CDA-7892 CD Player
Kenmore dryers
Check the breakers, then the wiring in the back. Make sure the wiring is connected good. Then the hi limit switch which is probably located under the top. (easy to remove).
Jan 18, 2009 | Kenmore 63942 Dryer
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
Dryer won't turn on
its a thermal fuse open up the back make sure you unplug it and turn off the gas its on your lower left side of your blower housing its skinny and white and about a inch in a half long and has 2 connectors going to it if any problems let me know
Mar 28, 2008 | Dryers
Kenmore 110.69912990
Need more info. Check voltage at outlet. Check thermal fuse,
check thermal cut-off assy. Then you have question -what caused the thermal to fail? There are several.
Mar 17, 2008 | Kenmore 73952 Gas Dryer
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
