Question about Whirlpool GU1200XTLS Stainless Steel Dishwasher
Replace motor in dishwasher
I have a whirlpool dishwasher model DU8700XY-1. I'm ying to remove the motor. I have removed all the parts inside the washer. Lossened the 4bolt on the motor assy. rotated the 4 rubber ??? 90 degrees. I can get the motor to come out from inside the washer or from the bottm as well. I don't want to force it. How hard are these to get out? Thanks Russell
  • 117 Answers
Once the 4 rubber tabs are moved, it should come up through the basin with a good push. Careful though because it will be sharp around the empty hole now.
http://tclaundryrepair.com/
Posted on Feb 20, 2009
I have a Whirlpool Quiet Partner Two dishwasher. The rinse only light & quick wash light constantly blink and I can't run it, none of the buttons will work. Is there a way I can reset my dishwasher?
This generally means the control panel is no longer working and must be replaced. That's the entire plastic assembly at the top of the door, in which the buttons reside. Disconnect power first, remove screws inside the door which hold the panel in place. Unplug power connectors, remove circuit board control board. Find dishwasher model number and search parts for that model. The part is pricey, more than $100 last time I replaced mine. Install control board into new panel, make power connection. Reassemble door. Good to go.
Oct 03, 2015 | Whirlpool Dishwashers
Whirlpool dishwasher will not drain. If the motor is tied into all fill and drain functions then the motor is good. I removed the drain hose and primed it with a total clear line I am in the dark.
here is the schematic for your entire machine http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-GU2400XTPT7/1198/0130000?searchedModel=GU2400XTP&blt=06 have you check the drain pump which is seperate from the motor? the motor basicly runs the sump with water going on the inside of the machine the drain pump is drains out the water part number 17 in this next diagram if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks again Rick
heres the pump and motor section link http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0512156-00008.png
Feb 03, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
No power going to front panel on whirlpool dishwasher gu2455xtsso
If the model number you listed this question under is correct, there is a thermal fuse (also known as a bi-metal) located inside the control panel of the dishwasher. The part number for the thermal fuse replacement is W10258275.
If you type in your model number you can utilize the exploded view parts diagrams at pcappliancerepair.com, appliancepartspros.com or searspartdirect.com to assist you in locating the part. The fuse is listed as item 6 under the "Control Panel Parts" section.
To replace the fuse, follow these steps:
1. Make sure the dishwasher is unplugged or the breaker is turned off.
2. Open the door and remove only the top screws directly behind the control panel.
3. Remove the protective cover from back of the control panel to expose the main control board.
The thermal fuse should be mounted to the control board. If you remove it and take a resistance check, it should read close to 0 ohms, if good. If bad, replace as necessary.
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Apr 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool disher
Run diagnostic by pressing Normal, heated dry, normal, heated dry, normal heated dry. a total of 3 times in 15 seconds.
The dishwasher will reboot and run a test load.
Nov 15, 2009 | Dishwashers
Whirlpool DU960PWKQ1 Dishwasher will not drain completely
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jul 24, 2009 | Whirlpool DU960PW Dishwasher
Water isn't draining
Check all the possible causes below to address this issue you are having. replace any part or device if found to be faulty
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Mar 30, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwaher does not clean, upper rack
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Mar 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher not starting
First I would check the chopper it maybe jammed or something blocking it...
1) remove wash arm holding the center and rotate the arm.
2) remove upper wash tube rotate to the right
3) remove screen screws to remove screen
4) pull up accumulator
5) reomve screw on chopper cover...
6) check chopper
7) if chopper clear .. you will need to replace motor
to replace motor
1) remove toe cover
2)remove drain pump
3) remove 3 hold tabs by sliding them out.
4) lift out accumulator base.
5 remove and replace motor.
Oct 07, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher - how do i remove timer ??
When I looked up a Whirlpool 2000 dishwasher, it shows an electronic timer. For a mechanical timer, see last paragraph.
First, turn off the breaker for the dishwasher. Then you'll need to remove the Phillips screws around the inside of the door. The inner door panel lifts up, leaving the electronics in place. Disconnect the vent motor and the dispenser motor wires. Place something heavy on the outer panel to keep it down and prop up the inner panel. Remove the plastic cover over the timer - it should pop off. Remove the wires to the circuit board. The electronics are held on with one or two screws.
Mechanical timer: Turn the timer **** backwards. It should come off along with the pointer. This should reveal a 1/4 in ***** holding the timer in place.
Mar 11, 2008 | Dishwashers
Whirlpool dishwasher model gu1200 not working
I checked. There is no sheet of any kind inside or below the door of my Whirlpool dishwasher.
In any case, opening up the non-washing washer revealed that the filter behind the chopper assembly was clogged with food. I cleaned it off, put the thing back together again, and it was washing dishes again, until about three days later. I took it apart again and found food clogging the filter behind the chopper. I thought the chopper wasn't chopping, so I replaced it. It was around $16. About three days later it wasn't washing dishes again.
Further examination (dis-assembly of the sump motor and impeller) revealed that the end of the impeller (which is designed to engage the chopper) had broken off, thus the chopper no longer spins with the sump motor. The impeller costs about $20 and isn't too hard to replace, as long and you keep track of what you've dis-assembled and put it back together in reverse order.
On whirlpool dishwashers, the sump motor drives the impeller (it's connected via the threaded end of the motor shaft) and the impeller, in turn, drives the chopper. The chopper you can replace from inside the tub, without removing the dishwasher from its home or taking apart the sump assembly. But save your $16, as that probably isn't what is wrong... The impeller, being screwed onto the motor shaft, requires complete removal of the dishwasher so that you can completely remove the base assembly that holds the motor assembly.
If you have a GU-series whirlpool washer, the tech manual can be found here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
It has complete instructions for the replacement of every part.
Nov 22, 2007 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Whirlpool GU1200XTLS Stainless Steel Dishwasher Logo
182 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
