Receiver cooling fan stays on
When my receiver is turned on,the cooling fan stays on all the time.after a couple of minutes the receiver will shut off automatically.
    Genius:
  • 1,550 Answers
Maybe the audio amplifiers IC´s are in bad conditions you need to replace them
Posted on Nov 01, 2008
Gas does not ignite on furnace. Fan stays on even when shut off at thermostat. When trying to start, I hear a click and get a gas odor that stops quickly. Furnace had major overhaul 10 years ago.
You have a ignitor problem .Replace the ignitor .Is it a direct spark or a glow type .My guess it's a glow type .About the fan issue sometimes fan would stay running for maybe a minute even after you turn the fan mode ofg
May 27, 2017 | Heating & Cooling
When I turn the engine off the engine cooling fan stays on and does not shut off
depending on the engine temperature the fan is supposed to remain on after you turn the engine off, until the engine reaches a preset cooler temperature. when it reaches cooler temperature usually within 5 minutes or so it should cut off... if you cut it off and it is running 30 minutes later.. then there is a problem with the fan relay or temperature sending unit.
Sep 28, 2015 | 2009 Dodge Grand Caravan
Samsung model dv5451 cooling light stays on
I am assuming when you turn it on, after couple of minutes goes off.
If you are on sensor drying and have no load or too little, then clothing might not touch the sensor enough (to show it is wet), and therefore microprocessor shuts unit down "thinking" everything is dry already. Try time dry.
Alternative: defective main board, sensor, wire harness.Call for service.
Dec 22, 2014 | Samsung Dryers
1997 Honda cooling fan takes a long time to shut off after car is turned off
There is no fix. Small cars such as honda, Saturn, ect have computers that when it sinces the England is hot the fans will not shut off untill cool... even when the car is off :) enjoy it because without it our small aluminum engines will melt
Jul 04, 2014 | 1999 Jeep Grand Cherokee
I have a 1997 Ford Thunderbird. Upon turning the ignition key the cooling fan turns on and the car will not start. There is nothing you can do to make the car start until the cooling fan turns off which...
I would hate to tell to replace any parts without doing some testing , The cooling fan is controlled the PCM - engine computer through the CCRM - constant control relay module . The only thing i can would suggest is you have it hooked up to factory scan tool to check for DTC'S - diagnostic trouble codes an have scan data looked at . Different sensor inputs to the PCM , ECT - engine coolant temp sensor, IAT - intake air temp etc.... If there are no codes ,check power an ground circuits of the PCM . If the cooling fan stayed on all the time i would say the CCRM was bad , still could be , but with out testing this is just a guess . Do you know how to do automotive electrical testing using a test light , volt meter ? How to read an use a wiring diagram ? You can find free wiring diagrams here
http://www.bbbind.com/free_tsb.html Enter vehicle info . year , make , model an engine ! Then under system click on engine , then under subsystem click on cooling fans . Good luck !
Apr 10, 2017 | 1997 Ford Thunderbird LX
Projector will only stay on for a couple of minutes then shuts off automatically. the LED turns from green to red
Make sure the venting for the cooling fan is clear and that it is activating. The only time I have seen this in a projector is when it overheats. If it reaches a certain temperature and doesn't sense the cooling fan being on it shuts down to protect the bulb and protect against fire hazard.
Oct 28, 2010 | Toshiba TDP-T90 Multimedia Projector
We just got back from a five hour trip, shut the car off and cooling fan stayed on for about five minutes. I restarted the car, and it went from 200-1500 rpms slowly, shut it off and fan stayed on again....
I have a 2001 S60 and the thermo fans come on after nearly every trip for at least 5 minutes, I would check your coolant levels and certainly change the thermostat if the problem persists.
Nov 28, 2009 | 1997 Volvo 850
AFTER A FEW MINUTES OF OPERATION ON MY SONY KF-42WE610TH LCD PROJECTION TV THE SCREEN GOES BLACK.THE SOUND COTINUES AS NORMAL.AFTER A COUPLE MINUTES IT COMES BACK ON THEN REPEATS UNTIL THE SET HAS RUN FOR...
First blush - the protective device called a "thermister" is heating up and "fusing". When the system cools down, the thermister releases the protection and allows the highvoltage transformer to provide power again.
Often times a device is drawing too much current - and the thermister shuts off the device to protect it - much like a fuse.
I have been able to maintain service on my TV by adding more cooling air to the existing fan. If your cooling fan is not turning fast enough - it can also cause the problem.
Nov 14, 2009 | Sony XL-2100U Projector Lamp for...
Yamaha HTR-6130 Receiver will not stay on! Shuts
One last try with everything disconnected!
Other than that I suspect internal surge damage.
Aug 04, 2009 | Yamaha HTR-6130 Receiver
Sudden shutdown
What you have not indicated is whether it shuts down or restarts. If the laptop restarts then it is possible that the processor is a celeron and there is a problem of a overheating. If you are sure about all software issues be alright, I suppose you get a new fan. At times after a fan has gone weak, regardless of the contacts it has with the processor, it will still not cool; but it also be good to check the processor temperature if its goes over 60 degrees. good luck.
Aug 27, 2007 | Computers & Internet
149 people viewed this question
 Grubhead
Grubhead
