Ball still not working
When I first rebooted the ball WAS working vertically, now it's not again...
  • 1,498 Answers
Hi Imatcha,
No worries, it's an easy fix.
Theres some crud on the rollers inside the ball socket. It builds up after a while whether its a trackball or standard mouse.
The ball is usually held in by a ring with two indentations on it. Use a pen or something hard and pointy to turn it counter clock wise about 1/4 turn.
Take off the ring, take out the ball.
Inside you'll find two rollers offset 90 degrees from one another. The center of one or both has a buildup that keeps the ball from turning the roller.
Use a Q-tip with alcohol to clean it. Sometimes you can just scrape it with a fingernail.
When your done, put the ball back in, the ring back on, quarter twist clockwise and you're ready to go.
Thanks for using FixYa
Mike
Posted on Nov 09, 2008
  • Justin Case
    Justin Case Nov 24, 2008
    Hi Imatcha,
    If you are still having problems, let me know.
    Whoever is doing the drive-by down rating, please give it a break.
    Mike
    Master:
  • 505 Answers
I checked the feature of the mouse. The mouse can be reprogrammed only for left and right handed person. I guess you need to get the mouse replaced as we already tried replacing the battery.
Thanks
Posted on Nov 01, 2008
Vertical lines
I would contact customer support and find a manager.
Make him aware that they are dropping the ball.
They are giving you back usede problem equipment.
May 23, 2014 | Samsung UN46C7000WFXZA - 46in Led Hdtv...
Vertical blue and yellow lines on dispaly
Sounds like booting problem from hard disc. The disc might have damaged due to fall. Replace it; reload the O/S and check.
Gopakumar Gopalan Google
Apr 19, 2014 | Toshiba Tecra A9-S9021V Notebook
What are some exercises that two people can do together using a medicine ball?
There are quite a few exercises where you can use partnering work. I will describe 2 variations for you now.
  1. . A standing torso twist - stand back to back (approximately one meter apart) with your hips facing forwards. Pass the ball to one another by only twisting your torso.
  2. Vertical Extensions - stand back to back with your partner. Begin by passing the ball overhead and then return it between your legs. Here is a diagram illustrating the vertical extension partner work.
Aug 05, 2012 | Exercise & Fitness
Mouse Cursor just goes Vertical, Up and Down can't do anything else, or Horizontal.
Try with another mouse. If the mouse is with a ball, open the mouse and clean the wheels inside.
Feb 28, 2011 | E-Machines eMachines Desktop PC
What is the proper torque frt wheel bearings
Position vertical link/hub assembly on lower ball joint taper pin, install securing nut and tighten to 44-59 ft. lbs. (60-80Nm).
Install nut securing upper ball joint to vertical link and tighten to 44-59 ft. lbs. (60-80Nm).
Position tie rod ball joint taper pin on steering arm and install and tighten securing nut to 53-63 ft. lbs. (71-85Nm).
Install the hub/bearing assembly. Tighten to 90 Nm.
Good luck.
Jan 31, 2011 | 2004 Jaguar X-Type
MY BLACKBERRY'S SCROLL WON'T WORK IF I TRY TO CLICK ON AN ICON....
Steps to be followed
1.Click Menu key
2.Goto Options icon
3.underthat select SMS/KEYBOARD option
4. Increase the Track ball sensitivity to 100 horizontally and vertically Both.
After this track ball works....
if its not working walk in to Service center
Nov 09, 2009 | RIM BlackBerry Curve 8310 Smartphone
How do u repair the ball n the curve
1) Go to option's.
2) select Screen and keyboard.
3) make horizontal and vertical sensitivity to 100..
If your track ball is Still not working you need to walk into the service center.
Nov 05, 2009 | RIM BlackBerry Pearl 8100
When I roll the ball to the left, the cursor doesn't go to the left?
change the trackball sensitivity
Steps :
1. Click Menu Key
2. Go to options, under that select Screen/Keyboard
3. scroll down you will get track ball settings
Horizontal sensitivity
Vertical sensitivity
increase the sensivity to 100 then you will be able to roll track ball,it will work fine....
Oct 30, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Vertical red lines on screen
try a dif game and send me a msg at kickop1@ymail.com
Jun 27, 2009 | Microsoft Xbox 360 Console
The scroller does not scroll horizontally - side to side
I do not know the model number of your cordless mouse or if it has a drive ball. If it has a ball , rumove the boottom to drop out the ball then remove tjhe lent and dirt from the two rod that the ball drives. If it is the non ball type , I don't know, sorry.
Dec 29, 2008 | Logitech Cordless Mouse
Computers & Internet Logo
David Payne
David Payne
