Question about Panasonic Microwave Ovens
We have a panasonic inverter microwave model SN977. It now will not heat and it has an error message H98. My operating manual doesn't have that message. What does it mean
  • Panasonic Master
  • 9,098 Answers
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Nov 09, 2008
How do I fix the H98 error on my microwave
You haven't identified the brand, make or model but this may be helpful:
Newer Panasonic Microwaves have built in fault codes....
they look like H97, H98....
Troubleshooting of Inverter Circuit (U) and Magnetron
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
NOTE:
DO NOT try to REPAIR this Inverter Power Supply (U) and also DO NOT RE-ADJUST PRESET VOLUME on the board. It is very dangerous to repair or adjust without sufficient test equipment because this circuit handles very high voltage and very large current. Off alignment or inverter board operation is dangerous. Operating a misaligned inverter circuit is dangerous due to the very high voltage and current that is produced by this board. Defective boards must be replaced with a new one.
- Check magnetron filament for open or short to casing before proceeding to determine a good magnetron.
Alternative way to troubleshoot oven with AC Ampere meter used.
H97, H98 and H99 appears in display window a short time alter start key is pressed and no microwave oscillation with AC Ampere meter used for troubleshooting.
NOTE:
Sep 09, 2014 | Microwave Ovens
Error code H98
Hello
Unplug the microwave and plug it back in after 30 seconds to make sure the message did not appear because of a simple glitch. If it does not come up again, use the microwave as normal.
The "H98" error means that the microwave's inverter has shorted out and does not work any more. The microwave cannot transfer power to create heat, and the part has malfunctions and requires replacement. Use your microwave serial number and customer service to find the proper part for the microwave.
Your microwave comes with a warranty that will cover the inverter if the warranty is still valid. Call the number for the warranty department or bring the microwave, with receipt, back to the store you purchased it from. This will save you the hassle of replacing the par
Oct 04, 2011 | Panasonic NN-SD797S Microwave Oven
H98 error message. Micowave not heating, stops after 37 seconds
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 28, 2009 | Panasonic NN-H965 Microwave Oven
Need a manual for a panasonic inverter combi microwave oven model number NNA514A
my microwave is saying h98 what does that mean. it's a panasonic inverter.
Aug 05, 2009 | Panasonic Microwave Ovens
H98 error
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
Dec 31, 2008 | Panasonic NN-H965 Microwave Oven
Panasonic microwave no working at all
In Canada, you can find an authorized Panasonic servicer here.
Dec 27, 2008 | Maytag MMV4205 Microwave Oven
Microwave runs for only a few seconds and then an error message of H98 is displayed and quits working Microwave only used for 6 months.
In most cases, this is a problem with the inverter or a bad magnetron.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Being 6 months old means it will be repaired free of charge.
Aug 03, 2008 | Panasonic Microwave Ovens
MESSAGE DISPLAY H98
The H98 fault on a Panasonic can be a bad magnetron, inverter or control panel.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 27, 2008 | Microwave Ovens
Doesn't work
No model number?? I'd be pretty suspicious why someone removed the model / serial tag!!
I'd be even more suspicious if someone sold you a microwave with such a serious problem without informing you of it in the auction item description beforehand.
H98 means you have a bad inverter, magnetron, or control board.
You can find a troubleshooting chart for this error code here.
May 16, 2008 | Microwave Ovens
Microwave Ovens Logo
590 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
