Question about LG KU990 Viewty
Bluetooth with my Viewty
Hi
I have a Viewty KU990 pelephone. Because I live on the first floor, I have very poor reception with it. The only way the person on the other end can hear me is if I go all the way to the balcony of my apt, which is at the very end of my apt and is therefore very inconvenient. I then have to stay there for the entire duration of the call. It occurred to me that since the phone can do Bluetooth, once I answer a call, I should be able to leave the phone on the balcony, put on a Bluetooth headset, and then continue the conversation anywhere in my apt. My question is whether I am correct, and if I am correct, whether there is a specific type of Bluetooth headset that won't work with my Viewty.
Thank you very much
  • 1 more comment
  • shlo77 Nov 02, 2008
    Thanks. That was helpful. 10 meters is still a lot for me, because it means I can talk inside my home and not on the balcony.
    Can you please directly address the two questions I asked? Thank you
    Thanks. I understand now. So I was right about being able to answer the phone on the balcony (i.e. pressing the button on the pelephone that answers the phone) , and then leaving the phone there and using my Bluetooth headset to talk in my home. I have never used Bluetooth before, so that point wasn't clear to me.
    To buy a headset from a shop so I can first test it, is a good idea.
    Thanks very much for all of your help.
    Thanks for giving me more helpful advice. I appreciate it.
  • 488 Answers
This is an excerpt from http://www.mobileinfo.com/Bluetooth/FAQ.htm
Q: What is the range of Bluetooth transmitter/receivers? A: Bluetooth is designed for very low power use, and the transmission range will only be 10m, about 30ft. High-powered Bluetooth devices will enable ranges up to 100m (300ft). Considering the design philosophy behind Bluetooth, even the 10m range is adequate for the purposes Bluetooth is intended for. Later versions of the Bluetooth spec may allow longer ranges.
and possible headsets are from(site only for examples of bluetooth headsets,please do see other sites) http://www.mobilecityonline.com/wireless/store/productaccessory.asp?productid=22709
as mentioned the maximum range is 10 m,do see if that helps u..also bluetooth on can drain the battery faster..
hope it helps!regards!
Posted on Nov 01, 2008
  • Lalit Varadpande
    Lalit Varadpande Nov 02, 2008
    hi! the range issue is sorted out,regards to a compatible headset i had suggested that you look at the various models online from the link and see waht u like as all of them are compatible..i would suggest that you buy one from a shop and not online cos u will be able to test it before u purchase..
    regards!
  • Lalit Varadpande
    you are welcome!you get stereo headphones in bluettooth to listen to music too but you cant use them to talk so u need a different thing for talking..
    do check the maximum range when u buy..go behind walls to check the range and clarity..make a call,see if the other person is able to hear u clearly..
    do remember leaving bluetooth on shall exhaust ur battery sooner..and dont accept any files/images via bluetooth unless u trust the source as there few viruses that can be sent via bluetooth..
    happy wireless listening to u!!
Trying to connect bluetooth
the pascode that most people use is "0000" and the other phone is the same passcode
Sep 22, 2009 | LG KU990 Viewty
Lg viewty ku990 bluetooth bd address not setny help would be appreciated, my lg viewty ku990 when trying to turn bluetooth on it comes up with the message you must set the bd address. ive looked in th
I think that the bluethoot of your pc or your LG KU990 (Viewty) Has no name. Your bluethoot address have a IP address but for the windows you need to put nthe name. Give your device a name that windows can find and vise versa. Most bluethoot softawe find the phone but sometimes you have to it in a otherway. Remove the item in the profile list of your bluethoot software that you made it for the phone. Now sometimes you have to turn off and on your phone cause there will be a program still running on the background of your phone. So when you want to find your LG KU990 (Viewty) you have to do it vise versa. Find your Pc or Laptop with your LG KU990 (Viewty) in this way the bluethoot will find the address and ask you for a security code. In this case you can make a password. EXAMPLE 1234 or NicKy what ever you want. Then the bluethoot software will setup the modem drivers of your phone so you make an connection with the bluethoot. Sometimes you have to reinstal the drivers to make the software work correctly. I hope this will help you out. Fallow the steps when the drivers will be ready to install. Best regards; Henk Muskita.
Jun 02, 2009 | LG KU990 Viewty
Lg viewty bluetooth problem
thus you have a message lock code?
Mar 31, 2009 | LG KU990 Viewty
Voice calling on my lg ku990 phone
Hi lg ku990 is compatible with your movon mk29 bluetooth visor kit as so you can make voice calls .
Turn on your Blue Tooth
Turn on voice calling function
Feb 25, 2009 | LG KU990 Viewty
How do I send audio files with bluetooth?
Do you mean you want to tranfer audio files or music files from your computer to your phone so you can enjoy music on your device? If so let me tell you that BLUETHOOTH or the SOFTWARE CD are not the best or fastest ways to sync or transfer files from your computer to your phone or vise versa, so Im going to tell you the safest, fastest, and Easiest way to do it, using your USB ,but it may require you to change settings manually on your device first. Make sure you have a Memory card,
Choose settings for USB connections
1.Find "USB connection mo..."
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press USB connection mo.... 2.Select setting
  • Press Mass storage
  • Press OK. 3.Exit
    Once you've done this and have your memory in your device, Open the MY COMPUTER folder in your computer and connect your device to your computer using the USB cord, a new Icon will appear containing the folders from your device's memory card, that way you will easily be able to transfer files back and forth without the NEED of any sofware Cd's or use slow Bluethoot.
    And Welcome to the Viewty Family! Enjoy...!
  • Dec 05, 2008 | LG KU990 Viewty
    your board is faulty and will need to be exchanged by lg for free
    Sep 08, 2008 | LG KU990 Viewty
    Bluetooth address
    i too have that problem
    Jun 21, 2008 | LG KU990 Viewty
    hi i spent hours trying to solve this ...
    finaly i found this site http://forum.gsmhosting.com/vbb/showthread.php?t=508796
    follow the instructions and you should be fine :)
    its was virus free when i used it.
    Jun 03, 2008 | LG KU990 Viewty
    LG KU990 Viewty Logo
    219 people viewed this question
    Top LG Computers & Internet Experts
    Alun Cox
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
