Question about Blaupunkt DVD-ME1 DVD/CD/MP3 PLAYER Car Video Player
DVD Player - Blaupunkt DVD/CD/MP3 PLAYER Car Video
When I put in the disc in the DVD player it reads "LOAD" but does not play the disc. It was purchased as part of the package for 2003 Sedona . Please help
4 Suggested Answers
  • 3130 Answers
SOURCE: HELP!!! My cd player just skips through all song never playing....
Sorry but this unit has a problem with the tracking servo. The problem could be an alighnment, or a bad componet such as the laser assembly, tracking motor or tracking driver IC, with all of these problems the unit will need to come out of the vehicle. Good Luck
Posted on Apr 03, 2007
  • 133 Answers
SOURCE: Car in-dash dvd player went silent, I can see the video, but no sound?
I have contacted a friend who specializes in car dvd players and he said he will try to locate your problem and get back with me. please give me a day or so, but hopefully someone else might give you and answer sooner.
Posted on Aug 05, 2007
  • 5 Answers
SOURCE: No audio
FM station 88.1 or similar. Set radio to scan while dvd is playing. When the correct frequency is reached, you'll hear sound.
Posted on Feb 10, 2010
  • 14 Answers
SOURCE: How I can take off
There should be a DVD Repeat modes or "Repeat/Repeat Modes" button on your remote. Press that until it's back to "ALL" and it should play things properly again for you.
Posted on Aug 27, 2011
0 characters
1 Points
How I can take off Random play from bus blaupunkt dvd-player. It shows (Random) on left side on screen when I put DVD in and movie jumps every few minutes. Very bad to watch movies, cause have to find...
Aug 27, 2011 | Blaupunkt DVD-ME1 DVD/CD/MP3 PLAYER Car...
The dvd is not loading and will not play. the cds are working fine.
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Apr 20, 2011 | Blaupunkt DVD-ME2 Car DVD Player
DVD player says "bad disc"
are your dvd's burned or store bought? if they are store bought then this maybe a laser adjustment if they are burned you may have +r in a player that reads -r or the reverse.
Jan 29, 2011 | Audiovox AVD400A Mobile DVD Player -...
It can't read dvd disc, but if i'm using an mp3/cd its fine
Was this a burned dvd or a store bought one? Sounds like the laser that reads dvd is dirty, try to play another dvd and see what happens after cleaning.
Nov 05, 2009 | Jensen's VM9312 Car DVD Player
DVD player will not play disc.
If you are loading a store bought DVD and that it what it say's. The transport needs to be replaced. roughly 150-200. If you are loading "burned" DVD's the format may be wrong and the unit cannot read it. Best suggestion I can give you is to first buy a "Laser Lens Cleaner" on that uses fluid. Any electronics store sells them for 15-20. Run it thru the unit a couple of times then try a clean, store bought DVD. If it plays, problem solved. With your DVD's, if you have any liquid car polish like mother's or meguiars, put a couple drops on the disc and spread around with your finger, let it set a couple then buff off with a microfiber towel. This works wonders for old scratched cd's and dvd's and helps protect new ones from getting scratched. As for the Lens cleaner, run it thru every product you have that uses discs 3 or 4 times a year, it's the best preventative maintance and only maintanance you can do on a CD player DVD or PC. Hope this helps
Jun 24, 2009 | Delphi 10.2" FLIP DOWN MNTR/DVD...
Necvox hq3 does not play music cd and mp3
the dvd player tells me that the dvd is invalid . took it 2 best buy & they told me i need 2 reprogram it but i have no disc .want 2 know if this would solve my problem & where could i purchase a disc
Oct 05, 2008 | Delphi MV10021 Car DVD Player
Please insert appropriate Cd
you need i dont know what one you need but heres the web site. the cost about $150.00 to $250.00 im looking for a place to download it for free but hasn't work.
Jul 21, 2008 | Pioneer AVIC-N2 Car DVD Player
Dvd disk won't eject???
this is device do not play dvd-video, onli dvd-rom with maps for gps-navigation.
Apr 28, 2008 | Eclipse AVN5495 Car DVD Player
Panasonic cq-dvr909u
according to the manual it does not support cd-r, lemme copy this section right out of the book
The following discs cannot be played back on this product.
DVD-ROM - DVD-R/DVD-RAM - CD-ROM - VSD - CDV - CD-G - SACD - photo CD - CD-R* - some DTS CD discs - CD-EXTRA (audio-only playback possible) - DVDs with a region number other than "1" or "ALL" - discs recorded in PAL format, others.
(* Because this product has its own reading device, CD-R discs can not be played back.)
If i remember correctly somethin about a dual laser in it or somethin, I feel your pain wish it could but it does come with rca aux input that you can do headphone -> rca jack so you can hookup a mp3 player or laptop or whatever
Sep 07, 2007 | Panasonic CQ-DVR909U Car DVD Player
Blaupunkt DVD-ME1 DVD/CD/MP3 PLAYER Car Video Player Logo
27 people viewed this question
Top Blaupunkt Car Video Players Experts
xxxxxx xxx
Are you a Blaupunkt Car Video Player Expert? Answer questions, earn points and help others
