Question about Water Heaters
Hot Water Heater
I just replaced my hot water heater a week ago and now the water is lukewarm. There are no leaks outside of the tank, and the pilot light is on. The constant sound that I hear is the tank filling up with water like after the toilet has been flushed or the washing machine is in use.
  • dadsbratt Jan 01, 2009
    I have the EcoSense by Rheem 7.4 GPM Tankless Water Heater Natural Gas water heater, and the temp is set to 140 (due to my frustration)but the heater gives an error code and the water is only like warm, about 80 degrees!
  • 104 Answers
Do you have a mix vavle in line?
Posted on Nov 02, 2008
  • 42windowman Nov 06, 2008
    ? you there is this solved?
Reliance 606 natural gas water heater - model #640YORT - water does not stay hot. pilot has to be clicked to heat and then u can use hot water til tank empty and it will not continue to heat water.
If I understand correctly, the pilot light is not staying lit.
You light the pilot and water in the tank reaches temperature.
Once hot water is gone, then pilot light has to be lit again.
Gas pressure is good, and gas is flowing.
Thermostat is working at high end because it cuts off heating.
Vent is working because tank heats up.
Air intake is working.
Gas control thermostat might not be reading low temperature. Replace gas control valve.
Pilot tube might be dirty. Clean burner parts and combustion chamber, and air intake, and vent.
Backdraft might be blowing out pilot. Check for constant updraft by running water heater 5 minutes, and then light match under vent hood and see if smoke goes up.
Very hot air can put out pilot, especially when water heater located in attic. Add ventilation.
Improper vent might have water dripping back down into combustion chamber and putting out pilot light and rusting out the parts. Inspect for rusted parts and water.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Aug 09, 2011 | Reliance Natural Gas Water Heater Control
Water is leaking from a whole in the top of the water heater what is the cause
If water heater is leaking out of a hole, then tank is rusted out and needs to be replaced.
http://waterheatertimer.org/Leaking-water-heater.html
First thing is protect yourself.
Tank could rupture.
Turn off power
-Electric heater: turn off circuit breaker
-Gas heater: turn knob from ON to pilot, so pilot light stays lit.
Open bathtub spout on hot side and release pressure.
Now you're save.
When you need hot water, turn heater on for 1 hour, use hot water, then turn heater off again.
You can limp along like this for a while until heater is replaced.
I buy water heaters at Lowes, Ace, Home Depot, Sears.
Look for scratch and dent.
Look for same size that you have now.
manufactured homes require heater that is made for that application.
Propane and natural gas heaters have different burner.
Always offer 10% less than asking price on any water heater.
You need teflon tape, 10" pipe wrench, new flexible water connectors, and a drip pan, and maybe insulation blanket.
Read how to install gas water heater.
To install electric water heater, open link above because some things are same for both gas and electric.
Difference with electric is there is no gas line, and you connect wires same way that they came off.
Feb 04, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
It is leaking out of the top. not out of the hot or cold valves but out of a nut by the cold side.
Your tank is rusted out and needs to be replaced.
Link below is a troubleshoot for leaking water heater.
Protect yourself first:
If your tank is rusted, there is danger of rupture.
My friend welded his leaking tank, but he assumes the risk.
Ruptured tank can cause massive damage and water runs until it is shut off.
Hot water tank is under pressure because hot water expands and pushes against tank wall.
Turn off water to tank.
Turn off power supply:
Electric: turn off circuit breaker.
Gas: rotate knob to pilot so pilot stays lit but burner will not fire. To turn back on, rotate knob to ON.
Open hot side bathtub valve and relieve pressure on tank.
You can limp by with rusted tank by turning water heater on when hot water is needed.
Shower uses 5-9 gallons hot water
Bath uses 12-15 gallon hot water
Ordinary gas heater makes 41 gallons hot water per hour
Ordinary electric heater makes 20 gallons hot water per hour.
I buy water heaters at Lowes, Home Depot, Ace.
Look for scratch and dent models.
Buy drip pan for water heater.
Wrap electric heater totally with insulation except TP valve.
Buy new flexible connectors for water lines.
Offer 15% less than marked price on tank, because the store makes money on additional items.
> Most people can install their own electric heater since you just connect water pipes and electric wire, and it's done. Read link below since there are tips that help you buy and install electric.
> Generally people are nervous about installing gas water heater, so step-by-step instructions are shown on link below. Remember gas line is under less pressure than water line, so if you can install a water pipe, you can install gas line to water heater with crescent wrench, and soapy water to check for leaks.
How to install gas water heater:
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater, or any do-it-yourself project.
Jan 13, 2011 | Water Heaters
Rheem water heater model #82V661 serial # RH0106D11663 leaking water at lower panel. Water is coming from above wiring and control panel. Is this fixable or need to be replaced? Mfg date is 01/2006
You have 240volt electric water heater
Check both elements for leaking.
Check top of tank for leaking pipes.
If water heater is leaking from side of tank, then tank is rusted out and could rupture.
This tank must be replaced.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
My friend welded his tank to get more life out of tank, but he assumed the risk.
Hot water heaters are under pressure from heated water which expands.
If tank ruptures, water will flood out of tank and water will run until shut-off is turned OFF.
This causes major damage inside home.
Protect yourself first, and then let's talk more.
1) Turn off water at shut off located on cold water line above tank.
2) Turn off power to water heater:
Gas heater, rotate valve to 'pilot' so pilot is lit but burner does not turn ON.
Electric heater, turn off circuit breaker.
3) Open tub spout on hot side and let run a bit to relieve pressure.
4) Now your property is safe.
You can limp along with failed heater if leak is slow.
Turn heater ON when you need hot water.
Typical Gas heater makes 41 gallons hot water per hour.
Typical Electric heater makes 21 gallons hot water.
Shower uses 5-9 gallons hot water, bath uses 12-14 gallons hot water.
http://waterheatertimer.org/images/Water-heater-reference-guide-2.jpg
If you are going to install heater yourself:
Look at label on side of old tank to identify size and particulars.
I buy ordinary heaters from Lowes and Home Depot and always buy scratch-n-dent models when possible, because superficial damage to outer tank does not lower lifespan of heaters I have installed.
Buy same size heater if it worked fine before.
Buy new flexible water connectors.
Set water heater in drip pan.
Offer 10% less than price shown. Make them deal with you. Shop Ace hardware, Lowes, Home Depot. Kick the tires since you have a bit of time.
I know you have electric heater, but many folks read these answers, so I include info on gas too.
#1 rule) tankless heaters are a rich-man's toy, because tankless will never pay you back, and will become major money pit if you encounter 1 repair. Electric tankless heaters require larger electric service box. Gas tankless require larger gas line (larger gas line, more gas consumption, bigger bill unless you cut consumption)
2) How to install gas heater:
http://waterheatertimer.org/How-to-replace-gas-water-heater.html
3) How to install electric heater:
Read link above because many of same steps apply to electric.
The difference with electric, is turn off power, disconnect wires, and reconnect wires exactly like before. Set electric heater directly on insulated surface like dense blue styrafoam. Cut styrafoam in circle so it fits inside dip pan. Wrap entire electric heater with insulation blanket, except don't cover TP valve.
4) Connect bare copper jumper wire between hot and cold pipes to prevent stray current corrosion which will shorten life of tank. Make sure cold water line is grounded.
Also read:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free assistance.
For a price, fixya expert speaks to you via phone about any do-it-yourself problem.
Jan 07, 2011 | Rheem Water Heaters
Seems as though there is a whole in the tank causing wter to spew out, The whole is yhe top of the tank and appears to be very small, can this be patched or soldered?
If water heater has a hole, then water heater is rusted out and must be replaced.
Immediate problem is ruptured tank.
Water heaters are under pressure, and rusted water heaters rupture and water runs until water is shut off.
I buy ordinary heaters from Lowes and Home Depot and always look at scratch-n-dent models.
#1 rule) tankless heaters are a rich-man's toy, because tankless will never pay you back, and will become major money pit with 1 repair.
The difference with electric, is turn off power, disconnect wires, and reconnect wires exactly like before. Set electric heater directly on insulated surface like dense blue styrafoam. Cut styrafoam in a circle so it fits inside dip pan.
Also read:
Jan 01, 2011 | Water Heaters
I have a Rheem 40 gal. tank that is leaking water front the top where the vent stack is. It is pouring out. Can it be repaired?
A leaking water heater cannot be repaired, assuming it's the tank leaking and not nearby water pipe.
http://waterheatertimer.org/Water-heater-leaking.html
First thing is to protect your property from catastrophic tank failure where tank ruptures and water runs until it is shut off:
Tanks are under pressure when they are hot.
Close cold water shut-off located above tank.
Turn control knob to 'pilot' so pilot is lit but burner will not turn on.
Open hot side on tub for few moments to relieve tank pressure.
You need a new water heater.
In mean time, gas water heater makes 41 gallons hot water per hour.
Shower used 5-9 gallons hot water.
Bath uses 10-15 gallons hot water.
You can turn on water heater for short stretches and limp by until you get a new heater.
Steps for installing gas water heater:
Dec 20, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Low boy water heater leaks at point where cold water pipe enters caseing.The leak is below the threads.The caseing is rusted at the point where the pipe goes through.Can this rusted place be patched or...
1) Your water heater needs to be replaced.
It cannot be repaired.
Tanks rust out after anode rod is depleted unless anode is inspected and replaced 1-3 years.
Water softener causes anode to deplete quicker, so inspect every 2 years.
Also stray household current can cause tank to rust out. Put bare copper ground wire between hot and cold pipes on new heater.
2) First thing is protect yourself from tank rupture where water heater bursts open and water runs until it's shut off. Ruptured tanks are big topic in homeowner insurance industry today because they cause major damage inside house.
- Turn off heat source so tank is not under pressure:
Gas: Rotate dial to pilot so pilot light stays lit, but burner does not turn on
- Turn off water going into tank using shut off above tank.
- Open hot side to bathtub to relieve pressure from tank.
- Check label on side of tank to get tank specifications for replacement.
3) What to do until replacement.
You can get by for a while on leaking tank by turning it ON only when needed.
Make sure tank is full of water before turning heat source back on.
This will buy time until replacement.
Electric tank heats 21 gallons water per hour.
Gas water heater 41 gallons per hour
Shower uses 6-9 gallons hot water, bath uses 12-15 gallon hot water.
4) Additional reading so next tank lasts longer
http://waterheatertimer.org/Replace-anode-rod.html
Dec 05, 2010 | Water Heaters
Gas hot water heater will not automatically heat water, i have to manually start the burner to heat the water
Sounds like you have a bad thermostat. You can change the thermostat, but if the heater is more than 8 or 10 years old you might be better off to replace the entire heater. Thermostat replacement is easy:
1 turn off the gas 2 drain the heater 3 unscrew pilot, main burner, and thermocouple lines from bottom of thermostat. 4 unhook gas line from thermostat. 5 unscrew thermostat from heater tank. Use pipe sealer when you install new thermostat, and gas line fittings. burner and thermocouple lines seal on a taper seat and do not need sealer. after reassembly check for leaks with soapy water, not a match, light the pilot and turn up the temp. The heater may sweat quite a bit while it is heating up the first time, this is due to the cold water on the inside and the fire on the outside. some water may drip in the bottom of the heater and you might think you have a leak, but let it heat up completly, if the water is still dripping after the tank is hot then you need to find the leak.
Jun 18, 2010 | Water Heaters
Electric hot water heater gives lukewarm water
replace upper thermostat and hi limit switch. These are usualy made in one piece. On a two element heater, only one element comes on at a time
Dec 25, 2009 | Water Heaters
Leaking tp valve
It is time for a New Water Heater.....But there are a few steps you can take to "TROUBLE SHOOT" the situation. There is a Drain Valve at the Bottom of the Water Heater. You may have a build up of ....gunk...at the bottom of your water heater, if you have a floor drain in a basement or some way for the water to drain, than you can carefully loosen the drain at the bottom of the tank to FLUSH the tank.....The other option will still reqiure draining the tank and replacing the heating element.. My best Solution is to make sure the bottom of your Mobile home is Insulated Properly From the Wind and Elements. Even Bails of Hay stacked around your Foundation Can be VERY Effective.....MOSTLY THOUGH I THINK IF YOU DRAIN THE TANK AND REPLACE THE HEATING ELEMENT, your problem will be over, With proper Insulation under the Mobile. This has worked for me a few times..... Hope it helps.....Joe
Jan 10, 2009 | Water Heaters
Water Heaters Logo
139 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
