Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer belt off
Hi ***** , Thanks for the quick reply. I have a maytag neptune MDE5500AYW and I only know how to get in from the front panel.
You were right!!!!! The belt is not broken. I just do not know how to put it back on. Do you know how I should put it back on from the front panel? I am so grateful to you! Thanks!
Suzanne
  • 4 more comments
  • Suzanne Nov 01, 2008
    Hi again, I took off all the screws for the back and realized that it didn't come off. I have the whole thing almost apart from the front. I see a white wheel and the belt is around the drum. I just cant fugure out how to get it back on track. It does look like the dryer at repair clinic. Thanks so much!
    OH my goodness! YOU ARE A WIZ!! I did it! It is on and drying now. It is really hot on there so I hope I do not start a fire. I had a little trouble getting it all back together. I hope I did it right because I forgot the order that the little wires that connect to the door go. I did red, grey and then white. does that matter?
    THANK YOU SO VERY MUCH!
    I am so excited that it is fixed. It does stop when I open the door and everything seems back to normal. I am so lucky that you were here today! THANKS SO MUCH!! I gave you the highest rating because you were terrific and so helpful! Suzanne
  • Anonymous Nov 06, 2008
    how does the belt go back on maytag dryer
  • Anonymous Nov 11, 2008
    How does the belt fit around the pulley?
  • butch welch May 11, 2010
    .. Can you see the motor and the pulleys from the front. Are you sure the bottom of the back panel doesnt come off. *****
    Scholar:
  • 147 Answers
found a site for you to look at.http://www.repairclinic.com/0047_8.asp .Let me know if this is the right dryer and we can go from there..*****
Posted on Nov 01, 2008
  • 2 more comments
  • butch welch Nov 01, 2008
    Unplug this thing before you do anything. The motor has a pulley on it about the size of a half dollar. The idler pulley is just above the motor. I suppose you can reach the pulley from the front.Put the belt on the motor and you may be able to figure out how to route it around the idler. It will have spring tension on it, pushing against the belt. Make sure the belt has no twists in it. I would like to have a movie of this...*****
    Im sure the white wheel is the belt tensioner. Put the belt around the motor. My guess is that you push the white pulley to the left and run the belt to the right and aroung the motor pulley.
    Please keep an eye on this thing for a day or two to make sure it works correctly. Does it stop when you open the door. Please take the time to give me a rating for helping out. You can contact me at jfw46@hotmail.com if you need more help. Let me know.
    You are Very Welcome..Thanks..Oh did you make the movie.. HA.....
WHY DOES MY NEPTUNE MATAG DRYER MDE5500AYW NOT HEAT ...AND WHERE ARE THE THERMAL SWITCH, HI LIMIT THERMOSTAT, AND HEATING ELEMENT?
All those parts are in the bottom front. TURN off the power! then open the front door and remove the 4 screw's, 2 on the hindges and 2 on the other side. Then you can close the door, and pull from the top edges of the front panel(sometimes you need a thin screw driver to free the front) the front panel will tilt forward and then you can lift it off. You will need a Ohm meter to check those parts for continuity. Make sure you remove the wires from the part you are testing.
Sep 30, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Dryer running fine but just stopped heating. lint traps all clean.Maytag Neptune MDE5500AYW. HAVE THE DOOR AND FRONT PANEL OFF ALL ELEMENTS LOOK CLEAN AND ATTATCHED. No problem with home power...
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 23, 2011 | Maytag MDE5500AYW Electric Dryer
How to unscrew blower wheel from motor shaft Maytag MDE5500AYW dryer?
If its this type that screws on, go to the front of the motor
remove the belt and attach visegrip pliers, lay dryer on its front ,
remove panel down to blower and put your right hand fingers
inside the blades and snap the wheel to the RIGHT
Be careful you can get a bad cut from the wheel housing.
This is the way I do it all the time.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 25, 2010 | Maytag MDE5500AYW Electric Dryer
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do you open the top of a Maytag Neptune dryer model #MDE5500AYW
unplug the dryer,open the door and you'll see 4 screws,2 holding the door on and 2 opposite them,remove them and the door,now pull the front off you'll see a clip that looks like an L with a screw through it on each side,take the screws out and lift the top up
Feb 10, 2010 | Maytag MDE5500AYW Electric Dryer
My neptune dryer has an interior 'fin' that is loose (mde5500ayw)
There are screws holding the fins on the outside of the drum. To get to them:
  • remove door
  • remove screws on the opposite side of the door screws (which would hold the door if it would open to the opposite side)
  • pull the top of the front panel, which was held by those screws outwards
  • remove the front panel. You'll see brackets holding the top of the dryer in place. Remove screws holding those brackets.
  • lift the top.
Good luck
Oct 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag will not run
My neptune dryer electric mde5500ayw will not start the button seemed too be struck, and how can i take the side panel off to check the fuses inside
Nov 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
MDE5500AYW Drum belt
I dont think you broke the belt, I think it may have just come off the belt tensioner. Take the bottom of the back panel off and I think you will see it hanging in there. Just put er back on.
Nov 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
195 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
